It is currently Fri Oct 16, 2026 13:42
PostPosted: Tue Feb 26, 2008 19:20
Hi all
Don't know if this is the correct place in this forum... if not, please remove this message!
Anyhow i tried "all possible lcd sources" mainly for PCF8833 Nokia 6610 LCD at different forums and i always get compile errors.
All hints are welcome..
Tried the GLCD.zip source dated 040414 taken from another forum i get the following when i try to compile it with WINAVR 20071221:
By the way i found the glcd.zip source at:
http://www.mikrocontroller.net/topic/12218
Best regards,
Hans
C:\make clean
-------- begin --------
Cleaning project:
Errors: none
-------- end --------
C:\make all
set -e; avr-gcc -MM -mmcu=atmega32 -I. -Os -mcall-prologues
-funsigned-char -fun
signed-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes
-Wa,-adhl
ns=test.lst -std=gnu99 test.c \
| sed 's,\(.*\)\.o[ :]*,\1.o \1.d : ,g' > test.d; \
[ -s test.d ] || rm -f test.d
avr-gcc (GCC) 4.2.2 (WinAVR 20071221)
Copyright (C) 2007 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is
NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR
PURPOSE.
Compiling: test.c
avr-gcc -c -mmcu=atmega32 -I. -Os -mcall-prologues -funsigned-char
-funsigned-bi
-Wa,-adhlns=test.l
st -std=gnu99 test.c -o test.o
In file included from test.c:2:
c:/avr/include/glcd.h:49: error: expected identifier or '(' before '}'
token
c:/avr/include/glcd.h:49: error: expected ';' before 'glcdFlags_t'
make: *** [test.o] Error 1
Press any key to continue . . .
Error as shown below:
} glcdFlags_t; <<<<<<----------
removed one "} " by using //
Then i got the :
c:/avr/include/glcd.h:52: error: expected specifier-qualifier-list
before 'extern'
Which is the line below:
extern uint8_t glcd_MemCtrl; // display RAM access and degree
of rotation
I've done the installation steps by editing and copy the requested
files... i assume....
Users browsing this forum: No registered users and 51 guests
