It is currently Fri Oct 16, 2026 13:00
PostPosted: Fri Feb 29, 2008 9:55
Hi!
I've got some problems with the initialisation my graphics display (resolution 240x128) with the t6963 controller. i'm using an Infineon XC800 controller. the reset works, but after that nothing shows up at the display except some senseless crap (but only sometimes - in most cases there is nothing to see).
Does anybody have experience with the XC800 Controller and t6963-displays?
Here is the code:
// T6963.C
// LowLevel Routinen für LCD-Displays mit T6963
#include <t6963.h>
#include <io.c>
#include <io.h>
#include <MAIN.H>
unsigned char LCD_STAT;          // Status-Byte
unsigned char LCD_DATA;
unsigned char LCD_CMD;
unsigned int t;
unsigned int i;
/**** LCD-Display-Routinen **********************************************/
void lcd_init(void)
         P1_0 = 1;
         P1_1 = 1;
         P1_2 = 1;
         P1_3 = 1;
         P1_5 = 0;
            for(i = 0; i< 1000;i++);
            //IO_vSetPin(P1_5);
            P1_5=1;
                              // ca. 125us. Reset
//        LCD_RST_H();          // Display Reset fertig
       lcd_send_data(G_BASE%256);
 lcd_send_data(G_BASE>>8);
 lcd_send_cmd(0x42);       // set graphics memory to address G_BASE
 lcd_send_data(BYTES_PER_ROW%256);
 lcd_send_data(BYTES_PER_ROW>>8);
 lcd_send_cmd(0x43);  // n bytes per graphics line
 lcd_send_data(T_BASE%256);
 lcd_send_data(T_BASE>>8);
 lcd_send_cmd(0x40);       // text memory at address T_BASE
 lcd_send_cmd(0x41);  // n bytes per text line
 lcd_send_cmd(0x81);  // mode set: Graphics OR Text, ROM CGen
 lcd_send_cmd(0xa7);  // cursor is 8 lines high
 lcd_send_data(0x00);
 lcd_send_cmd(0x21);  // put cursor at (x,y) location
 lcd_send_cmd(0x9C);
 lcd_clear_text();
 lcd_clear_graph();
         // (For cursor to be visible, need to set up position
        }                       // Display's loeschen
void lcd_status(void)
        P3_DIR = 0x00;
      P1_0 = 0;
        P1_3 = 1;             // Commando High
      P1_1 = 0;           // Read Low
      P1_2 = 0;             // Chip Enable Low
      LCD_STAT = P3_DATA;  // Status lesen
      for(t = 0; t<100;t++);
        P1_2 = 1;            // Chip Enable High
      P1_1 = 1;           // Read High
      LCD_STAT &= (0x03);   // Bits ausmaskieren
      P3_DIR = 0xff;
          /*P3_DATA=LCD_STAT;
           for(i = 0; i<1000;i++){
         for(t = 0; t<1000;t++);}
          P3_DATA = 0;
         for(t = 0; t<1000;t++);}*/
void lcd_status_am(void)
        P3_DIR = 0x00;
        P1_0 = 0;
        P1_3 = 1;           //Commando High
        P3_DIR = 0xff;
void lcd_send_cmd(char cmd)         // Commando an Display senden
            do
                  lcd_status();
            while (LCD_STAT != 0x03);
       P3_DIR = 0xFF;
        //DATA_DIR_OUT();             // Port 2 als Ausgang
          P3_DATA = cmd;           //LCD_WRITE = cmd;
        P1_1 = 1;                  //Read Low
        P1_0 = 0;                  // Write Low
        P1_0 = 1;                  // Write High
        //    P3_DATA=P0_DATA;
           /*for(i = 0; i<1000;i++){
          P3_DATA = 0;
void lcd_send_data(char dat)         // Daten an Display senden
            do
                  lcd_status();
        P3_DIR = 0xFF;             // Port 2 als Ausgang
       P1_3 = 0;                  // Commando High
      P3_DATA = dat;
             //P3_DATA=P0_DATA;
          P3_0 = 0;
         for(t = 0; t<1000;t++);} */
void lcd_send_data_am(char dat)         // Daten an Display senden
            do
                  lcd_status_am();
       P3_DATA = dat;
      P1_3 = 0;               // Daten Low
       //P3_DATA=dat;
void lcd_printp(const char *progmem_s, char adress_h, char adress_l)
        char c;
        lcd_send_data(adress_l);
        lcd_send_data(adress_h);
        lcd_send_cmd(0x24);
        lcd_send_cmd(0xB0);
      while ( (c = pgm_read_byte(progmem_s++)))
         lcd_send_str(c);
        lcd_send_cmd(0xB2);
void lcd_print(int x,int y,char *string)  // send string of characters to LCD
int i;
int c;
lcd_xy(x,y);
  for (i=0;string[i]!=0;i++) {
      c = string[i] - 0x20;     // convert ASCII to LCD char address
      if (c<0) c=0;
      lcd_send_data(c);
      lcd_send_cmd(0xc0);               // write character, increment memory ptr.
  } // end for
} // end lcd_string
void lcd_xy(int x, int y)  // set memory pointer to (x,y) position (text)
int addr;
  addr = T_BASE + (y * BYTES_PER_ROW) + x;
  lcd_set_address(addr);   // set LCD addr. pointer
} // lcd_xy()
void lcd_print(char *txt, char adress_h, char adress_l)
        char c;
        lcd_send_cmd(0x24);
        while((c = *txt)) //Solange Zeichen groeßer 0x00
         txt++; //Naechstes Zeichen
         if (c == 0) break; //Raus wenn Zeichen gleich 0
         lcd_send_str(c);
         lcd_send_cmd(0xc0);
void lcd_send_str(unsigned char lcd_dat)
        lcd_dat -= 0x20;        // 20h subtrahieren da Display nicht ASCII
        lcd_send_data_am(lcd_dat);     // Daten an Display senden
void lcd_clear_graph()    // clear graphics memory of LCD
int i;
lcd_set_address(G_BASE);     // addrptr at address G_BASE
for (i=0;i<3840;i++) {   // must be  3840 ?????????????????     5120
   lcd_send_data(0); lcd_send_cmd(0xc0);               // write data, inc ptr.
   }    // end for(i)
} // end lcd_clear_graph()
void lcd_clear_text()
 int i;
 lcd_set_address(T_BASE);     // addrptr at address T_BASE
 for (i=0;i<480;i++) {  //  must be 480   ???????????     640
 } // end for(i)
} // lcd_clear_text()
void lcd_set_address(unsigned int addr){
lcd_send_data(addr%256);
lcd_send_data(addr>>8);
lcd_send_cmd(0x24);
void lcd_printg(const char *progmem_s, char adress_h, char adress_l)
   unsigned int length =5120; //< dieses ist die Bildgroesse in Bytes
   unsigned char c;
   lcd_send_cmd(0x24);
   lcd_send_cmd(0xB0);
   while (length !=0)         //es wird ein Bild in der Groesse 128*64 Pixel
        {                   //mit Font 6*8 angezeigt
      c = pgm_read_byte(progmem_s++);
      lcd_send_strg(c);
      length--;
   lcd_send_cmd(0xB2);
void lcd_send_strg(unsigned char lcd_dat)
   lcd_send_data(lcd_dat); // Daten an Display senden
void lcd_setpixel(int column, int row)  // set single pixel in 240x64 array
int addr;       // memory address of byte containing pixel to write
  if( (column>=XMAX) || (row>=YMAX) )return;
  addr =  G_BASE + (row*BYTES_PER_ROW)  + (column/8);
  lcd_send_cmd(0xf8 | ((7-column%8)) );  // set bit-within-byte command
void lcd_clrpixel(int column, int row)
  lcd_send_cmd(0xf0 | ((7-column%8)) );  // set bit-within-byte command
void lcd_print_ram(int x,int y,char *string)  // send string of characters to LCD
int i;
int c;
lcd_xy(x,y);
      if (c<0) c=0;
      lcd_send_data(c);
  } // end for
} // end lcd_string
void show(char * s,int start_line,int how_many_line){
int addr,i;
addr =  G_BASE +start_line*30;
lcd_send_cmd(0xB0);
for(i=0;i<how_many_line*30;i++){
   lcd_send_data(s[i]);
lcd_send_cmd(0xB2);
void lcd_pixel(int column, int row,char show)
if(show)
else
Name:   Int To Ascii Hex
Parameters:
      dest_string
         Pointer to a buffer will the string will reside
      min_digits
         Specifies the minimum number of characters the output string will
         have. Leading zeros will be written as '0' characters.
Returns:
      A pointer to the string's NULL character in the string that was just
      created.
Description:
      This function is used to convert a passed unsigned int into a ASCII
      string represented in Hexidecimal format.
char * IntToAsciiHex(char * dest_string,int min_digits,unsigned int value)
   unsigned int i, total_digits = 0;
   char buff[4];
   for(i=0;i<4;i++)
      buff[i] = (char)(value & 0x0F);
      value = value >> 4;
      if( buff[i] <= 9)
         buff[i] += '0';
      else
         buff[i] = (char)(buff[i] - 0xA + 'A');
      if(buff[i] != '0')
         total_digits = i+1;
   if( total_digits <    min_digits)
      total_digits = min_digits;
   i = total_digits;
   while(i)
      *dest_string++ = buff[i-1];
      i--;
   *dest_string = 0;
   return dest_string;
Name:   Int To Ascii Dec
Parameters:
      dest_string
      min_digits
Returns:
      created.
Description:
      string represented in base 10 decimal format.
char * IntToAsciiDec(char * dest_string,int min_digits,unsigned int value)
   const unsigned long base10[] = {1,10,100,1000,10000,100000};
   unsigned int tmp;
   char buff[5];
   for(i=0;i<5;i++)
      tmp = (int)( value % base10[i+1] );
      value -= tmp;
      buff[i] = (char)( tmp / base10[i] );
      buff[i] += '0';
      if(buff[i] != '0')
         total_digits = i+1;
   i = total_digits;
   while(i)
      i--;
   *dest_string = 0;
   return dest_string;
thanks for the help
Users browsing this forum: No registered users and 50 guests
