It is currently Sun Nov 08, 2026 23:25
PostPosted: Wed Dec 31, 2008 12:42
Does anyone have a working library using software SPI to interface with this controller/screen through a PIC 18f4550?
I have coded one, but it is not working. I have the screen's backlight on, but since they power up in sleep, I am not sure if my custom SPI function is doing things correctly. By stepping through with the debugger, the appropriate ports light up (I have some LEDs attached for debugging), but still nothing appears on the screen. I have never used the screen before so I dont know if it is defective or not, but I doubt it is. It was brand new and still has the plastic over the LCD panel.
My board I am using outputs a switched ground, so I am sending everything through an inverter (74LS04) and then to the screen. I looked at the max time is 15ns for the inverter. I am sending each instruction out for 1 clock cycle which is 1/12us so it should be plenty of time.
I have no idea how to test it, I just want it to turn a different colour so I know it works!
I have adapted some code I found, and I hope someone can spot something immediately wrong with it. Nothing is displaying on the screen at all, just the backlight is on, and it is blue.
Full Code (Starts at LCDmain())
//// Nokia 6100 LCD with Epson S1D15G10 Controller
////  sample initialization program for PIC18F458 in CCS C
////  Modify code by ETT
////  WATCHARIN KAOROP
//// START OF HEADER FILE ////
#include <p18cxxx.h>
typedef signed char int8;
typedef unsigned char uint8;
typedef int int16;
typedef unsigned int uint16;
typedef short long int24;
typedef unsigned short long uint24;
typedef long int32;
typedef unsigned long uint32;
//#define LCD_RESET   PORTDbits.RD1 // Digital Output 9  --> Digital Output 3
//#define LCD_CS      PORTDbits.RD0 // Digital Output 8  --> Digital Output 2
//#define SPI_CLK     PORTBbits.RB1 // Analogue Input 10 --> Digital Output 0
//#define SPI_DO      PORTCbits.RC7 // Digital Output 7  --> Digital Output 1
#define LCD_RESET   PORTDbits.RD7 // Digital Output 15
#define LCD_CS      PORTDbits.RD6 // Digital Output 14
#define SPI_CLK     PORTDbits.RD4 // Digital Output 12
#define SPI_DO      PORTDbits.RD5 // Digital Output 13
//#bit SSPEN = 0x14.5   // bit to turn on/off hardware SPI
//#bit SSPEN = 0xFC6.5
// Epson S1D15G10 Command Set
// #include "bmp.h"
#include <delays.h>
// #include "font.h"
/** P R I V A T E  P R O T O T Y P E S ***************************************/
void delay_ms(int);
//void output_low(int);
//void output_high(int);
/** G L O B A L  D E F I N I T I O N S  ***************************************/
#define DISON       0xaf
#define DISOFF      0xae
#define DISNOR      0xa6
#define DISINV      0xa7
#define SLPIN       0x95
#define SLPOUT      0x94
#define COMSCN      0xbb
#define DISCTL      0xca
#define PASET       0x75   // 00,131
#define CASET       0x15   // 00,131
#define DATCTL      0xbc
#define RGBSET8     0xce
#define RAMWR       0x5c
#define RAMRD       0x5d
#define PTLIN       0xa8
#define PTLOUT      0xa9
#define RMWIN       0xe0
#define RMWOUT      0xee
#define ASCSET      0xaa
#define SCSTART     0xab
#define OSCON       0xd1
#define OSCOFF      0xd2
#define PWRCTR      0x20
#define VOLCTR      0x81
#define VOLUP       0xd6
#define VOLDOWN     0xd7
#define TMPGRD      0x82
#define EPCTIN      0xcd
#define EPCOUT      0xcc
#define EPMWR       0xfc
#define EPMRD       0xfd
#define EPSRRD1     0x7c
#define EPSRRD2     0x7d
#define NOP         0x25
#define ENDPAGE     131
#define ENDCOL      131
//a few basic colors
#define RED         0xE0                           // Color Code
#define GREEN       0x1C
#define BLUE        0x03
#define YELLOW      0xFC
#define MAGENTA     0xE3
#define CYAN        0x1F
#define BLACK       0x00
#define WHITE       0xFF
////  START OF MAIN .C SOURCE FILE ////
//#include "<path to .h file cut from above>"
//#use fast_io(C)
/* Table Font Size 5x7 Pixel */
// #pragma udata gpr1
rom const unsigned char font[475] =
   0x00 , 0x00 , 0x00 , 0x00 , 0x00 ,                  // Sp
   0x00 , 0x06 , 0x5F , 0x06 , 0x00 ,                      // !
   0x07 , 0x03 , 0x00 , 0x07 , 0x03 ,                      // ,
   0x24 , 0x7E , 0x24 , 0x7E , 0x24 ,                      // #
   0x24 , 0x2B , 0x6A , 0x12 , 0x00 ,                      // $
   0x63 , 0x13 , 0x08 , 0x64 , 0x63 ,                      // %
   0x36 , 0x49 , 0x56 , 0x20 , 0x50 ,                      // &
   0x00 , 0x07 , 0x03 , 0x00 , 0x00 ,                      // //
   0x00 , 0x3E , 0x41 , 0x00 , 0x00 ,                      // (
   0x00 , 0x41 , 0x3E , 0x00 , 0x00 ,                      // )
   0x08 , 0x3E , 0x1C , 0x3E , 0x08 ,                      // *
   0x08 , 0x08 , 0x3E , 0x08 , 0x08 ,                      // +
   0x00 , 0xE0 , 0x60 , 0x00 , 0x00 ,                      // ,
   0x08 , 0x08 , 0x08 , 0x08 , 0x08 ,                      // -
   0x00 , 0x60 , 0x60 , 0x00 , 0x00 ,                      // .
   0x20 , 0x10 , 0x08 , 0x04 , 0x02 ,                      // /
   0x3E , 0x51 , 0x49 , 0x45 , 0x3E ,                      // 0
   0x00 , 0x42 , 0x7F , 0x40 , 0x00 ,                      // 1
   0x62 , 0x51 , 0x49 , 0x49 , 0x46 ,                      // 2
   0x22 , 0x49 , 0x49 , 0x49 , 0x36 ,                      // 3
   0x18 , 0x14 , 0x12 , 0x7F , 0x10 ,                      // 4
   0x2F , 0x49 , 0x49 , 0x49 , 0x31 ,                      // 5
   0x3C , 0x4A , 0x49 , 0x49 , 0x30 ,                      // 6
   0x01 , 0x71 , 0x09 , 0x05 , 0x03 ,                      // 7
   0x36 , 0x49 , 0x49 , 0x49 , 0x36 ,                      // 8
   0x06 , 0x49 , 0x49 , 0x29 , 0x1E ,                      // 9
   0x00 , 0x6C , 0x6C , 0x00 , 0x00 ,                      // :
   0x00 , 0xEC , 0x6C , 0x00 , 0x00 ,                      // ;
   0x08 , 0x14 , 0x22 , 0x41 , 0x00 ,                      // <
   0x24 , 0x24 , 0x24 , 0x24 , 0x24 ,                      // =
   0x00 , 0x41 , 0x22 , 0x14 , 0x08 ,                      // >
   0x02 , 0x01 , 0x59 , 0x09 , 0x06 ,                      // ?
   0x3E , 0x41 , 0x5D , 0x55 , 0x1E ,                      // @
   0x7E , 0x09 , 0x09 , 0x09 , 0x7E ,                      // A
   0x7F , 0x49 , 0x49 , 0x49 , 0x36 ,                      // B
   0x3E , 0x41 , 0x41 , 0x41 , 0x22 ,                      // C
   0x7F , 0x41 , 0x41 , 0x41 , 0x3E ,                      // D
   0x7F , 0x49 , 0x49 , 0x49 , 0x41 ,                      // E
   0x7F , 0x09 , 0x09 , 0x09 , 0x01 ,                      // F
   0x3E , 0x41 , 0x49 , 0x49 , 0x7A ,                      // G
   0x7F , 0x08 , 0x08 , 0x08 , 0x7F ,                      // H
   0x00 , 0x41 , 0x7F , 0x41 , 0x00 ,                      // I
   0x30 , 0x40 , 0x40 , 0x40 , 0x3F ,                      // J
   0x7F , 0x08 , 0x14 , 0x22 , 0x41 ,                      // K
   0x7F , 0x40 , 0x40 , 0x40 , 0x40 ,                      // L
   0x7F , 0x02 , 0x04 , 0x02 , 0x7F ,                      // M
   0x7F , 0x02 , 0x04 , 0x08 , 0x7F ,                      // N
   0x3E , 0x41 , 0x41 , 0x41 , 0x3E ,                      // O
   0x7F , 0x09 , 0x09 , 0x09 , 0x06 ,                      // P
   0x3E , 0x41 , 0x51 , 0x21 , 0x5E ,                      // Q
   0x7F , 0x09 , 0x09 , 0x19 , 0x66 ,                      // R
   0x26 , 0x49 , 0x49 , 0x49 , 0x32 ,                      // S
   0x01 , 0x01 , 0x7F , 0x01 , 0x01 ,                      // T
   0x3F , 0x40 , 0x40 , 0x40 , 0x3F ,                      // U
   0x1F , 0x20 , 0x40 , 0x20 , 0x1F ,                      // V
   0x3F , 0x40 , 0x3C , 0x40 , 0x3F ,                      // W
   0x63 , 0x14 , 0x08 , 0x14 , 0x63 ,                      // X
   0x07 , 0x08 , 0x70 , 0x08 , 0x07 ,                      // Y
   0x71 , 0x49 , 0x45 , 0x43 , 0x00 ,                      // Z
   0x00 , 0x7F , 0x41 , 0x41 , 0x00 ,                      // [
   0x02 , 0x04 , 0x08 , 0x10 , 0x20 ,                      // Back slash
   0x00 , 0x41 , 0x41 , 0x7F , 0x00 ,                      // ]
   0x04 , 0x02 , 0x01 , 0x02 , 0x04 ,                      // ^
   0x80 , 0x80 , 0x80 , 0x80 , 0x80 ,                      // _
   0x00 , 0x03 , 0x07 , 0x00 , 0x00 ,                      // `
   0x20 , 0x54 , 0x54 , 0x54 , 0x78 ,                      // a
   0x7F , 0x44 , 0x44 , 0x44 , 0x38 ,                      // b
   0x38 , 0x44 , 0x44 , 0x44 , 0x28 ,                      // c
   0x38 , 0x44 , 0x44 , 0x44 , 0x7F ,                      // d
   0x38 , 0x54 , 0x54 , 0x54 , 0x18 ,                      // e
   0x08 , 0x7E , 0x09 , 0x09 , 0x00 ,                      // f
   0x18 , 0xA4 , 0xA4 , 0xA4 , 0x7C ,                      // g
   0x7F , 0x04 , 0x04 , 0x78 , 0x00 ,                      // h
   0x00 , 0x00 , 0x7D , 0x00 , 0x00 ,                      // i
   0x40 , 0x80 , 0x84 , 0x7D , 0x00 ,                      // j
   0x7F , 0x10 , 0x28 , 0x44 , 0x00 ,                      // k
   0x00 , 0x00 , 0x7F , 0x40 , 0x00 ,                      // l
   0x7C , 0x04 , 0x18 , 0x04 , 0x78 ,                      // m
   0x7C , 0x04 , 0x04 , 0x78 , 0x00 ,                      // n
   0x38 , 0x44 , 0x44 , 0x44 , 0x38 ,                      // o
   0xFC , 0x44 , 0x44 , 0x44 , 0x38 ,                      // p
   0x38 , 0x44 , 0x44 , 0x44 , 0xFC ,                      // q
   0x44 , 0x78 , 0x44 , 0x04 , 0x08 ,                      // r
   0x08 , 0x54 , 0x54 , 0x54 , 0x20 ,                      // s
   0x04 , 0x3E , 0x44 , 0x24 , 0x00 ,                      // t
   0x3C , 0x40 , 0x20 , 0x7C , 0x00 ,                      // u
   0x1C , 0x20 , 0x40 , 0x20 , 0x1C ,                      // v
   0x3C , 0x60 , 0x30 , 0x60 , 0x3C ,                      // w
   0x6C , 0x10 , 0x10 , 0x6C , 0x00 ,                      // x
   0x9C , 0xA0 , 0x60 , 0x3C , 0x00 ,                      // y
   0x64 , 0x54 , 0x54 , 0x4C , 0x00 ,                      // z
   0x08 , 0x3E , 0x41 , 0x41 , 0x00 ,                      // {
   0x00 , 0x00 , 0x7F , 0x00 , 0x00 ,                      // |
   0x00 , 0x41 , 0x41 , 0x3E , 0x08 ,                      // }
   0x02 , 0x01 , 0x02 , 0x01 , 0x00 ,                      // ~
void pset(unsigned char color, unsigned char x, unsigned char y);
void spi_command(int8);
void spi_data(int8);
void spi_do(int8);
void LCD_Set_Box(unsigned char x1,
                 unsigned char y1,
             unsigned char x2,
             unsigned char y2);
void LCD_Fill_Screen(unsigned char color,
                     unsigned char x1,
                  unsigned char y1,
                  unsigned char x2,
                  unsigned char y2);
void LCD_Initial(void);
void Draw_Color_Bar(void);
void LCDWrite130x130bmp(void);
void LCD_Print_Char(unsigned char fcolor,
               unsigned char bcolor,
               unsigned char x,
               unsigned char y,char c);
void LCD_Print_String(unsigned char fcolor,
                  unsigned char x,
                  unsigned char y,char *text);
void LCDmain()
   int i,index;
   char String_Buff[30];                           // String Array Buffer
   //setup_adc_ports(NO_ANALOGS);
   //setup_adc(ADC_OFF);
   //setup_comparator(NC_NC_NC_NC);
   //setup_spi(SPI_MASTER|SPI_L_TO_H|SPI_XMIT_L_TO_H|SPI_CLK_DIV_4);
   // Already Commented Out   // setup_spi(SPI_MASTER|SPI_L_TO_H|SPI_XMIT_L_TO_H);
   //setup_timer_0(RTCC_INTERNAL|RTCC_DIV_1);
   //setup_timer_1(T1_DISABLED);
   //setup_timer_2(T2_DISABLED, 0, 1);
   //set_tris_c(0x00);   // all outputs, can change to mask only hardware SPI bits if needed
   LCD_Initial();
   while(1)
   Draw_Color_Bar();
   delay_ms(2000);
   LCD_Fill_Screen(RED,0,0,131,131);
   delay_ms(1000);
   LCD_Fill_Screen(GREEN,0,0,131,131);
   delay_ms(1000);
   LCD_Fill_Screen(BLUE,0,0,131,131);
   delay_ms(1000);
   LCD_Fill_Screen(YELLOW,0,0,131,131);
   delay_ms(1000);
   LCD_Fill_Screen(MAGENTA,0,0,131,131);
   delay_ms(1000);
   LCD_Fill_Screen(CYAN,0,0,131,131);
   delay_ms(1000);
   LCD_Fill_Screen(BLACK,0,0,131,131);
   delay_ms(1000);
   // LCDWrite130x130bmp();
   delay_ms(2000);
   spi_command(DATCTL);                                // datctl
   spi_data(0x00);
   spi_data(0);
   spi_data(0x01);
   spi_data(0);
   LCD_Fill_Screen(BLACK,0,0,131,131);                 // Fill Screen with Black Color
   sprintf(String_Buff," TEST ET-LCD6610 ");
   LCD_Print_String(YELLOW, BLACK, 7, 5,String_Buff);
   sprintf(String_Buff," WWW.ETTEAM.COM ");
   LCD_Print_String(CYAN, BLACK, 7, 15,String_Buff);
   sprintf(String_Buff," TEST RED COLOR ");
   LCD_Print_String(RED, BLACK, 7, 30,String_Buff);
   sprintf(String_Buff," TEST GREEN COLOR ");
   LCD_Print_String(GREEN, BLACK, 7, 45,String_Buff);
   sprintf(String_Buff," TEST BLUE COLOR ");
   LCD_Print_String(BLUE, BLACK, 7, 60,String_Buff);
   sprintf(String_Buff," TEST WHITE COLOR ");
   LCD_Print_String(WHITE, BLACK, 7, 75,String_Buff);
   sprintf(String_Buff," TEST MAGENTA COLOR ");
   LCD_Print_String(MAGENTA, BLACK, 7, 90,String_Buff);
   sprintf(String_Buff," TEST CYAN COLOR ");
   LCD_Print_String(CYAN, BLACK, 7, 105,String_Buff);
   sprintf(String_Buff," TEST YELLOW COLOR ");
   LCD_Print_String(YELLOW, BLACK, 7, 120,String_Buff);
   delay_ms(5000);
void pset(unsigned char color, unsigned char x, unsigned char y){
//  sets the starting page(row) and column (x & y) coordinates in ram,
//  then writes the colour to display memory.  The ending x & y are left
//  maxed out so one can continue sending colour data bytes to the 'open'
//  RAMWR command to fill further memory.  issuing any other command
//  finishes RAMWR.
  x += 2;                  // for some reason starts at 2
  spi_command(PASET);   // page start/end ram
  spi_data(x);
  spi_data(ENDPAGE);
  spi_command(CASET);   // column start/end ram
  spi_data(y);
  spi_data(ENDCOL);
  spi_command(RAMWR);    // write
  spi_data(color);
void spi_command(int8 dat)
      LCD_CS = 0;      // enable chip
   /* SPI DATA BIT 9 */
   SPI_DO = 0;     // output low on data out (9th bit low = command)
   SPI_CLK = 0;
   Delay1TCY();        // send clock pulse
   SPI_CLK = 1;
   spi_do(dat);
   //SSPEN=1;                 // turn hardware SPI back on
   //spi_write(dat);          // make PIC do the work for the command byte
   LCD_CS = 1;     // disable
void spi_data(int8 dat)
   SPI_DO = 1;    // output high on data out (9th bit high = data)
   SPI_CLK = 0;
   SPI_CLK = 1;
   spi_do(dat);
   //spi_write(dat);          // make PIC do the work for the data byte
void spi_do(int8 dat)
   int i;
   i = 0;
   /* SPI DATA BITS 1 through 8 */
   for(i = 1; i <= 8; i++) // setup a loop of 8 iterations, one for each bit
      if (dat > (unsigned)127)  // test the most significant bit
         SPI_DO = 1;; // if it is a 1 (ie. B1XXXXXXX), set the master out pin high
      else
         SPI_DO = 0; // if it is not 1 (ie. B0XXXXXXX), set the master out pin low
      dat = dat << 1;
      SPI_CLK = 0;
      SPI_CLK = 1;
/* Initial LCD-NOKIA6610 */
   // reset display
   SPI_CLK = 0;
   SPI_DO = 0;
   LCD_CS = 1;
   LCD_RESET = 0;
   delay_ms(100);
   LCD_RESET = 1;
   SPI_CLK = 1;
   //init'd, now drop CS to send commands/data and raise when finished
   spi_command(NOP);
    spi_command(DISCTL);  // display control
    spi_data(0x0C);      // 12 = 1100 - CL dividing ratio [don't divide] switching period 8H (default)
    spi_data(0x20);      // 32 = (128/4)-1 (round up) number of display lines for scanning
    spi_data(0x0C);      // 12 = 1100 - number of lines to be inversely highlighted
    spi_data(0x00);
    spi_command(COMSCN);  // common scanning direction
    spi_data(0x01);
    // 0 0 0 =   1 -> 80   81 -> 160
    // 0 0 1 =   1 -> 80   81 <- 160
    // 0 1 0 =   1 <- 80   81 -> 160
    // 0 1 1 =   1 <- 80   81 <- 160
    spi_command(OSCON);  // internal oscialltor ON
    spi_command(SLPOUT);  // sleep out
    spi_command(VOLCTR);  // electronic volume, this is the contrast/brightness
    spi_data(0x23);   // volume (contrast) setting - fine tuning
    spi_data(0x03);   // internal resistor ratio - coarse adjustment
    spi_command(PWRCTR);  // power ctrl
    spi_data(0x0f);      //everything on, no external reference resistors
    delay_ms(100);
    spi_command(DISINV);  // invert display mode
    spi_command(DATCTL);  // data control
    spi_data(0x00);   // normal display of page/column address, page scan direction
    spi_data(0x00);   // normal RGB arrangement
    spi_data(0x01);   // 8-bit grayscale
    spi_command(RGBSET8);   // setup 8-bit color lookup table  [RRRGGGBB]
  //RED
    spi_data(0);
    spi_data(2);
    spi_data(4);
    spi_data(6);
    spi_data(8);
    spi_data(10);
    spi_data(12);
    spi_data(15);
    // GREEN
    spi_data(0);
    spi_data(2);
    spi_data(4);
    spi_data(6);
    spi_data(8);
    spi_data(10);
    spi_data(12);
    spi_data(15);
    //BLUE
    spi_data(0);
    spi_data(4);
    spi_data(9);
    spi_data(15);
    spi_command(NOP);  // nop
   LCD_Fill_Screen(WHITE,0,0,131,131);
   spi_command(DISON);                // Display On
/*  (x1,y1)                  */
/*                    (x2,y2)   */
                 unsigned char y1,
             unsigned char x2,
             unsigned char y2)
   spi_command(CASET);                              // Page Start/Eend ram
   spi_data(x1);
   spi_data(x2);
   spi_command(PASET);                              // Column Start/End ram
   spi_data(y1);
   spi_data(y2);
/* Fill Screen With Color */
                     unsigned char x1,
                  unsigned char y1,
                  unsigned char x2,
                  unsigned char y2)
  unsigned int j;
  unsigned int total_bytes1;
  unsigned int total_bytes2;
  unsigned int total_bytes;
  LCD_Set_Box(x1, y1, x2, y2);
  spi_command(RAMWR);
  total_bytes1 = (x2 - x1 + 1);
  total_bytes2 = (y2 - y1 + 1);
  total_bytes = total_bytes1 * total_bytes2;
  for (j = 0; j < total_bytes; j++)
    spi_data(color);
/* Create 4-Bar Color */
   LCD_Fill_Screen(RED,0,0,131,33);
   LCD_Fill_Screen(GREEN,0,34,131,66);
   LCD_Fill_Screen(BLUE,0,67,131,99);
   LCD_Fill_Screen(WHITE,0,100,131,131);
   unsigned int j; // loop counter
   // Data control (need to set "normal" page address for Olimex photograph)
   spi_data(0x00); // P1: 0x00 = page address normal, column address normal, address scan in column direction
   spi_data(0x01); // P2: 0x01 = RGB sequence B-> G-> R(Invert Direction)
   spi_data(0x02); // P3: 0x02 = Grayscale -> 16
   // Display OFF
   spi_command(DISOFF);
   // Column address set (command 0x2A)
   spi_command(CASET);
   spi_data(0);
   spi_data(131);
   // Page address set (command 0x2B)
   spi_command(PASET);
   spi_data(0);
   spi_data(131);
   // WRITE MEMORY
   spi_command(RAMWR);
  // for(j = 0; j < 25740; j++)
     for (j=0;j<sizeof(picture);j++)
      spi_data(picture[j]);
   // Data control (return to "inverted" page address)
   spi_data(0x00); // P1: 0x01 = page address inverted, column address normal, address scan in column direction
   spi_data(0x01); // P3: 0x02 = Grayscale -> 16
   // Display On
   spi_command(DISON);
/* Print Char on Screen */
               unsigned char x,
   unsigned int i;
   LCD_Set_Box(x,y,x,y+7);
   spi_command(RAMWR);
   for(i=0;i<8;i++)
     if (1<<i & c)
        spi_data(fcolor);
     else
        spi_data(bcolor);
/* Print String on Screen */
                  unsigned char x,
   unsigned char c;
   unsigned char t;
   unsigned int i;
   unsigned int j;
   while(*text != 0)
     t = *text;
     i = t - 32;
     i = i * 5;
     for(j = i; j < i+5; j++)
       c = font[j];
       LCD_Print_Char(fcolor, bcolor, x++, y, c);
     LCD_Print_Char(fcolor, bcolor, x++, y, 0);
     text++;
void delay_ms(int time)
   int time_i;
   for(time_i = 0; time_i < time; time_i++)
      Delay100TCYx (120);
void output_low(int PIN)
   PIN = 0;
void output_high(int PIN)
   PIN = 1;
[/code]
PostPosted: Thu Jan 01, 2009 9:37
anyone?
PostPosted: Tue Oct 20, 2009 10:28
NVergunst wrote:
anyone?
Greetings,
I have the same problem.
May be the problem is in the fuses/configuration.
We'll see....
best regards.
