It is currently Sat Apr 27, 2024 6:00
Post new topic Reply to topic  [ 20 posts ]  Go to page Previous  1, 2
PostPosted: Wed Jun 11, 2003 21:38
Thanks for the asciicat link.
Implementing this much custom characters in only 200 bytes is kinda hard I believe. One 5x8 character takes 5 bytes if the bytes are rotated and stored in vertical order. So 200 bytes would mean 40 characters. I guess your best bet would be to use the 128 characters in the CG-ROM and then add as much custom characters as can be made to fit.
Are you working on a fixed hardware design ? One way to add more space for fonts would be to use external eeprom chip.
I guess the font data could be compressed using some algorithm but how much of the 200 bytes would that algorithm take then ?
Sorry, I don't have any good ideas at the moment if the situation is that we have a fixed hardware design and we should implement 256 custom characters using only 200 bytes. :(
PostPosted: Wed Jun 11, 2003 21:44
I got your email, Henri. Thanks again.
PostPosted: Wed Jun 11, 2003 21:53
Hi Henri
I not understand your problem!
White my litle english....
You can have 512 Custom Chars when you will (not from the Hardware!)
Paint your own Text.gif File (Show Winamp) and write "Paint" the Char
to the screen of the LCD this is simple.
You can use the Picture1.paintpictur or the API BitBlt
Then you have no more Problem with Chars.
Greetings Emil
PostPosted: Wed Jun 11, 2003 22:10
Emil, the problem in this particular situation is that the display isn't connected to a computer but to a microcontroller (or something similar, this wasn't defined exactly) where there isn't much free space to use and in this case we have 200 bytes or even less.
We can save one 5x7 font to 5 bytes so 256 characters would take 5*256=1280 bytes that is much more than 200 bytes available.
I hope you understand this now.
PostPosted: Wed Jun 11, 2003 22:33
Hi
Sorry!
Yes.
Problem with my english
Greetings Emil
