It is currently Mon Nov 23, 2026 15:47
PostPosted: Thu Jul 16, 2009 19:09
Hello all, i hope you are all fine.
My name is Josh and im new in this (Forum, working whit GLCD's and with this Driver T6963CFG), I'm in a proyect in which i have to show a graph in the LCD using a Microcontroller or a PIC.
Right now i only want to see if the LCD is working and want to get used to the LCD. So if any of you have some test programs to show text or images i would really preciate your help.
***DOES ANYONE KNOW HOW THE PINS OF THE LCD ARE CONECTED WITH THE LPT PINS?? IN WHICK ORDER?
any advice about how to start making work the LCD would be great!
THNX IN ADVANCE
The LCD im working on is the DS-G160128STBWW you can found the info here:
http://www.sparkfun.com/commerce/produc ... ts_id=8799
The pins connections are these:
PIN SYMBOL FUNCTION
1 FG FRAME GROUND
2 Vss Power Supply(GND)
3 Vdd Power Supply For Logic(+5V)
4 Vo Power Supply For LCD Driving (Contrast Adjust)
5 VEE NEGATIVE VOLTAGE INPUT/OUTPUT
6 /WR DATA WRITE
7 /RD DATA READl
8 /CE CHIP ENABLE FOR T6963C
9 C/D COMMAND/DATA SELECTION
10 /HALT CLOCK OPERATING STOP SIGNAL
11 /RST RESET T6963C(LOW EFFECTIVE)
12- DB0—
-19 DB7 DATA BUS
20 NC NO CONNECTION
21 LEDA LED BACKLIGHT POWER SUPPLY(+)(+5V)
PostPosted: Tue Jul 21, 2009 17:19
One wiring example for T6963C is here:
http://www.lcdstudio.com/forum/viewtopic.php?t=8639
Just connect the display databus to the LPT 8 bit bus and the control pins to the rest of the LPT outputs. The rest depends of the software.
Also you should be able to find some example code for T6963C displays in this forum:
http://forum.lcdinfo.com/viewforum.php?f=9
Just try the forum search if you don't want to manually go through each topic.
