| PIC Adapted Rotine to T6963C LCD 240x64 http://forum.lcdinfo.com/viewtopic.php?f=9&t=2963 |
| Author: | Pbranquinho [ Mon Apr 05, 2010 1:29 ] |
| Post subject: | PIC Adapted Rotine to T6963C LCD 240x64 |
Hi. I was adapted the rotine developed by John P. Beale, write to work with PC parallel port, to work with PIC microcontroler. Original rotine: http://www.skippari.net/lcd/controlt6963c_c.txt Adapted rotine: /* ---------------------------------------------------------- * Program to control a T6963C-based 240x64 pixel LCD display * using the Microchip PIC16F648A Microcontroller * written in CCS C++ * * Original Written by John P. Beale May 3-4, 1997 beale@best.com * Adapted by PlÃnio Branquinho Apr 5, 2010 plinio.branquinho@hotmail.com * * Based on information from Steve Lawther, * "Writing Software for T6963C based Graphic LCDs", 1997 which is at * http://ourworld.compuserve.com/homepage ... t6963c.pdf * * and the Toshiba T6963C data sheet, also on Steve's WWW page * * and info at: http://www.citilink.com/~jsampson/lcdindex.htm * http://www.cs.colostate.edu/~hirsch/LCD.html * http://www.hantronix.com/ * ----------------------------------------------------------*/ // Pin numbers refer to pins on PIC16F648A. // Recall that SEL (pin 17), LF (14), and STROBE (1) control ouputs // are inverted, but Init (16) is true. // // LCD pin numbering for TOSHIBA TLX-711A-E0 (uses T6963C controller) // // LCD Pin ----- PC Port Pin Status Reg. bit // ------------------------------------------ // C/D (8) <--> RA1(17) /SEL 3 // /WR (5) <--> RA6(16) Init 2 // /RD (6) <--> RA7(14) /LF 1 // /CE (7) <--> RA0(1) /Strobe 0 // ----------------------- // D0 (11) <--> RB0(2) D0 // D1 (12) <--> RB1(3) D1 // D2 (13) <--> RB2(4) D2 // D3 (14) <--> RB3(5) D3 // D4 (15) <--> RB4(6) D4 // D5 (16) <--> RB5(7) D5 // D6 (17) <--> RB6(8) D6 // D7 (18) <--> RB7(9) D7 // GND (2) <--> GND // -------------------------------------------------------------- // FG (1) frame ground // +5V (3) LCD logic supply // -7.8V (4) LCD display contrast // FS (19) font select // RST (10) active low // -------------------------------------------------------------- #bit CE = 0x05.0 // CE (7) <--> RA0 #bit RD = 0x05.7 // RD (6) <--> RA7 #bit WR = 0x05.6 // WR (5) <--> RA6 #bit CD = 0x05.1 // C/D (8) <--> RA1 /* ----- Definitions concerning LCD internal memory ------ */ #define G_BASE 0x0200 // base address of graphics memory #define T_BASE 0x0000 // base address of text memory #define BYTES_PER_ROW 40 // how many bytes per row on screen /* This will be 30 with 8x8 font, 40 with 6x8 font, for both Text & Graphics modes. Font selection by FS pin on LCD module: FS=High: 6x8 font. FS=Low: 8x8 font. */ /* ----------------------------------------------------------- */ #define XMAX 239 // limits of (x,y) LCD graphics drawing #define XMIN 0 #define YMAX 63 #define YMIN 0 #include <string> void dput(int dbyte); // write data byte to LCD module int dget(void); // get data byte from LCD module int sget(void); // check LCD display status pbrt void cput(int dbyte); // write command byte to LCD module void lcd_setup(); // make sure control lines are at correct levels void lcd_init(); // initialize LCD memory and display modes void lcd_print(char *string); // send string of characters to LCD void lcd_clear_graph(); // clear graphics memory of LCD void lcd_clear_text(); // clear text memory of LCD void lcd_xy(int x, int y); // set memory pointer to (x,y) position (text) void lcd_setpixel(int column, int row); // set single pixel in 240x64 array #define home() dput(T_BASE%256);dput(T_BASE>>8);cput(0x24); // upper-left void lcd_clear_graph() // clear graphics memory of LCD { long int i; dput(G_BASE%256); dput(G_BASE>>8); cput(0x24); // addrptr at address G_BASE for (i=0;i<2560>>8); cput(0x24); // addrptr at address T_BASE for (i=0;i<320;i++) { dput(0); cput(0xc0); // write data, inc ptr. } // end for(i) } // lcd_clear_text() /* ----------------------------------------------------------- */ void lcd_print(char *string) // send string of characters to LCD { int i; int c; for (i=0;i<strlen(string);i++) { c = string[i] - 0x20; // convert ASCII to LCD char address if (c<0>>8); cput(0x24); // set LCD addr. pointer cput(0xf8 | (5-(column%6)) ); // set bit-within-byte command } // end lcd_setpixel() /* ----------------------------------------------------------- */ void lcd_xy(int x, int y) // set memory pointer to (x,y) position (text) { int addr; addr = T_BASE + (y * BYTES_PER_ROW) + x; dput(addr%256); dput(addr>>8); cput(0x24); // set LCD addr. pointer } // lcd_xy() /* ============================================================== * Low-level I/O routines to interface to LCD display * based on four routines: * * dput(): write data byte * cput(): write control byte * dget(): read data byte (UNTESTED) * sget(): read status * ============================================================== */ void lcd_setup() // make sure control lines are at correct levels { CE=1; //HI; // disable chip RD=1; //HI; // disable reading from LCD WR=1; //HI; // disable writing to LCD CD=1; //HI; // command/status mode set_tris_b(0x00); //DATAOUT; // make 8-bit parallel port an output port } // end lcd_setup() /* ----------------------------------------------------------- */ void lcd_init() // initialize LCD memory and display modes { dput(G_BASE%256); dput(G_BASE>>8); cput(0x42); // set graphics memory to address G_BASE dput(BYTES_PER_ROW%256); dput(BYTES_PER_ROW>>8); cput(0x43); // n bytes per graphics line dput(T_BASE%256); dput(T_BASE>>8); cput(0x40); // text memory at address T_BASE dput(BYTES_PER_ROW%256); dput(BYTES_PER_ROW>>8); cput(0x41); // n bytes per text line cput(0x80); // mode set: Graphics OR Text, ROM CGen cput(0xa7); // cursor is 8 lines high dput(0x00); dput(0x00); cput(0x21); // put cursor at (x,y) location cput(0x97); // Graphics & Text ON, cursor blinking // (For cursor to be visible, need to set up position) } // end lcd_init() /* ----------------------------------------------------------- */ int sget(void) // get LCD display status byte { int lcd_status; set_tris_b(0xFF); //DATAIN; // make 8-bit parallel port an input CD=1; //HI; // bring LCD C/D line high (read status byte) RD=0; //LO; // bring LCD /RD line low (read active) CE=0; //LO; // bring LCD /CE line low (chip-enable active) lcd_status = portb; //inp(pdata); // read LCD status byte CE=1; //HI; // bring LCD /CE line high, disabling it RD=1; //HI; // deactivate LCD read mode set_tris_b(0x00); //DATAOUT; // make 8-bit parallel port an output port return(lcd_status); } // sget() /* ----------------------------------------------------------- */ void dput(int dbyte) // write data byte to LCD module over par. port // assume PC port in data OUTPUT mode { do {} while ((0x03 & sget()) != 0x03); // wait until display ready CD=0; //LO; WR=0; //LO; // activate LCD's write mode portb = dbyte; //outp(pdata, byte); // write value to data port CE=0; //LO; // pulse enable LOW > 80 ns (hah!) CE=1; //HI; // return enable HIGH WR=1; //HI; // restore Write mode to inactive // using my P5/75 MHz PC with ISA bus, CE stays low for 2 microseconds } // end dput() /* ----------------------------------------------------------- */ int dget(void) // get data byte from LCD module { int lcd_byte; do {} while ((0x03 & sget()) != 0x03); // wait until display ready set_tris_b(0xFF); //DATAIN; // make PC's port an input port WR=1; //HI; // make sure WRITE mode is inactive CD=0; //LO; // data mode RD=0; //LO; // activate READ mode CE=0; //LO; // enable chip, which outputs data lcd_byte = portb; //inp(pdata); // read data from LCD CE=1; //HI; // disable chip RD=1; //HI; // turn off READ mode set_tris_b(0x00); //DATAOUT; // make 8-bit parallel port an output port return(lcd_byte); } // dget() /* ----------------------------------------------------------- */ void cput(int dbyte) // write command byte to LCD module // assumes port is in data OUTPUT mode { do {} while ((0x03 & sget()) != 0x03); // wait until display ready portb = dbyte; //outp(pdata, byte); // present data to LCD on PC's port pins CD=1; //HI; // control/status mode RD=1; //HI; // make sure LCD read mode is off WR=0; //LO; // activate LCD write mode CE=0; //LO; // pulse ChipEnable LOW, > 80 ns, enables LCD I/O CE=1; //HI; // disable LCD I/O WR=1; //HI; // deactivate write mode } // cput() /* ----------------------------------------------------------- */ Enjoy :-) |
| Author: | Pbranquinho [ Tue Apr 06, 2010 22:33 ] |
| Post subject: | A little example to use. |
Following a little example to use the "adapted rotine" First you coppy all rotine and save as file like "24064PGB.c". Now you can use this file like a library. I make a simple project to print "TEST" on display, I copy all source here. Souce code: #include <16F648A> #FUSES NOWDT //No Watch Dog Timer #FUSES INTRC_IO //Internal RC Osc, no CLKOUT #FUSES PUT //Power Up Timer #FUSES NOPROTECT //Code not protected from reading #FUSES NOBROWNOUT //No brownout reset #FUSES NOMCLR //Master Clear pin used for I/O #FUSES NOLVP //No low voltage prgming, B3(PIC16) or B5(PIC18) used for I/O #FUSES NOCPD //No EE protection #use delay(clock=4000000) #byte porta=5 //Define a Porta de Saida a como PortA, do registrador 5h #byte portb=6 //Define a Porta de Saida b como PortB, do registrador 6h #include <24064PGB> char texto[20]; void main() { setup_timer_0(RTCC_INTERNAL|RTCC_DIV_1); setup_timer_1(T1_DISABLED); setup_timer_2(T2_DISABLED,0,1); setup_comparator(NC_NC_NC_NC); setup_vref(FALSE); //Setup_Oscillator parameter not selected from Intr Oscillator Config tab // TODO: USER CODE!! porta=0; portb=0; set_tris_a(0x00); // todo como saÃda set_tris_b(0x00); // todo como entrada porta=0; portb=0; lcd_setup(); lcd_init(); lcd_clear_text(); cput(0x97); // Graphics & Text ON, cursor blinking lcd_xy(0,0); texto = "TESTE"; do{ delay_ms(5000); lcd_print(texto); lcd_xy(0,0); }while(true); } |
