| HD61830 programing (VB); graphic LCD http://forum.lcdinfo.com/viewtopic.php?f=9&t=451 |
| Author: | Flavius [ Tue Dec 09, 2003 16:11 ] |
| Post subject: | HD61830 programing (VB); graphic LCD |
| Author: | Henri [ Thu Dec 11, 2003 9:48 ] |
I think you need to be slightly more specific Do you have some question about HD61830 ? |
| Author: | cdragos69 [ Sat Jan 24, 2004 13:36 ] |
Ok, here is some help, my library for HD61830 (put on a LMG6401PLGE display). It is written in DOS, but it's faster than Windows libraries because most of them use DLPortIO driver, which is quite slow. Since I don't have much experience with Windows programming, next one will be a library for microcontrollers (Atmel MEGA and then PIC16 or 18), maybe with a small digital oscilloscope application if this period of coming home from work at 10 in the evening will come finally to an end... here is the link (with thanks to Henri): http://www.skippari.net/lcd/sekalaista/lcd_hd61830_lib.zip |
| Author: | Henri [ Sat Jan 24, 2004 16:39 ] |
cdragos69 wrote: maybe with a small digital oscilloscope application
Hey, this sounds very interesting. If you get to work on this I'd like to know more about your design. Have you thought of what kind AD converter you'd use ? |
| Author: | cdragos69 [ Mon Jan 26, 2004 10:03 ] |
You will get the entire code for it The only problem is that the work doesn't allow me to do anything extra at this moment, I hope that this will be the last week of this busy period. Anyway, I will keep you informed ... |
