| T6963 and C-Control http://forum.lcdinfo.com/viewtopic.php?f=9&t=470 |
| Author: | Muddel [ Tue Dec 30, 2003 18:52 ] |
| Post subject: | T6963 and C-Control |
Hi, I' m trying to program a Toshiba t6963 controlled Display with a Conrad C- Control Microcontroller. I wrote the program with a description from Steve Lawther where step- by- step is shown how to build something like that. After the intialising (correct english?? thx Muddel Code: '*****Portdefinition *****
define daten byteport[1] define wr port[9] define rd port[10] define ce port[11] define cd port[12] define rst port[13] '###### variblen#### define lsb Byte define msb byte define execo byte define tarea byte define thome byte define garea byte define ghome byte rst = off rst = on ce=on #main 'gha setzen lsb = &H00 msb =&H00 execo=&H42 gosub twobyte 'garea setzen lsb = &H1e msb =&H00 execo =&H43 gosub twobyte 'tha setzen lsb= &H00 msb= &H00 execo=&H40 gosub twobyte 'tarea setzen lsb =&H01 msb=&H00 execo=&H41 gosub twobyte 'mode set execo = &H8c gosub exe 'display mode execo = &H95 gosub exe 'adresspointer lsb=&H23 msb=&H01 execo=&H24 gosub twobyte 'a darstellen lsb = &H21 execo=&Hc0 gosub onebyte '++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ '++++++ vereinfachte Routinen +++++ 'zwei Byte an LCD mit Command #twobyte gosub read_status daten = lsb gosub write_data gosub read_status daten = msb gosub write_data gosub read_status daten = execo gosub write_command return 'ein byte Daten an LCD mit Command #onebyte gosub read_status daten = lsb gosub write_data gosub read_status daten = execo gosub write_command return 'command ans LCD senden #exe gosub read_status daten=execo gosub write_command '******************************************************************************** '****Grundroutinen *** #write_data cd = off wr = off rd =on pause 1 print"BUS";daten pulse ce return #read_data cd = off rd = off wr = on pulse ce return #write_command cd = on wr = off rd= on pause 1 pulse ce return #read_status deact daten cd = on rd = off wr = on if (daten and 1 shl 1)<>2 then print "Fehler im STA1" if (daten and 1 shl 0)<>1 then print "Fehler im STA0" if (daten and 1 shl 0)<>1 then goto read_status 's.u. mit sta0 if (daten and 1 shl 1)<>2 then goto read_status 'sicherheit, stimmt STA1? wenn nein gehe zu read_status print daten pause 1 pulse ce return |
| Author: | Henri [ Tue Dec 30, 2003 22:15 ] |
What size display do you have and have you set all initialization values and memory areas correctly for your display size ? |
| Author: | Muddel [ Tue Dec 30, 2003 22:26 ] |
Hi Henry, the size of the Display is 240x 64. I dont't know if that are right initialisation values for the Display. I wrote the programm with this http://www.grote.net/bascom/files/writing_software_to_control_t6963c_based_displays.pdf description. I tryed a range of values for display mode etc. but nothing happens. the exact name for the display is Toshiba TLX- 711A. Could someone give me example- values for display-mode, text- and graphic- home and the register- settings? thx Muddel |
| Author: | Henri [ Wed Jun 16, 2004 20:38 ] |
These values at the bottom of the page should work with TLX-711A as that was the display it was developed with: http://www.skippari.net/lcd/testprog.html |
