http://forum.lcdinfo.com/
Nokia color LCDs (Philips / Epson)
http://forum.lcdinfo.com/viewtopic.php?f=9&t=586
Page 5 of 20
Author:  gafar [ Wed Feb 16, 2005 18:24 ]
Post subject:  lcd_color
Henri,
I initialize the lcd but i don´t get to send information.
I need send the color table before??
You can help send the color red?
My source code in msp430 1222
Reset
bic.b #reset,&P3OUT ;colocar nivel 0 do BIT7 no reset LCD NOKIA
call #To_aqui
bis.b #reset,&P3OUT
mov #0100h,R6 ;reset
call #Comando
mov #1100h,R6 ;sleep
call #Comando
mov #0300h,R6 ;booster
call #Comando
call #To_aqui
mov #2900h,R6 ;lcd on
call #Comando
call #To_aqui
mov #1300h,R6 ;normal
call #Comando
mov #2000h,R6 ;inv_off
call #Comando
mov #0ba00h,R6 ;data order
call #Comando
mov #3600h,R6 ;memory data acess
call #Comando
mov #0800h,R6 ;rgb
call #Dados
mov #3a00h,R6 ;set color
call #Comando
mov #0200h,R6 ;rgb
call #Dados
Call #Pos_x
Call #Pos_y
mov #2c00h,R6 ;dados
call #Comando
here i send the 02h to lcd, but lcd stay white.
Author:  J1M [ Thu Feb 17, 2005 17:55 ]
hi im trying to do a library for PCF8833 with a PIC18F2520, but i cant init my display this is my code, whats wrong?
Thanks for your help! :)
Author:  J1M [ Fri Feb 18, 2005 1:19 ]
ive modified the code (up), but ive the same problem... im trying to put all the screen in red.
xao!
Author:  J1M [ Fri Feb 18, 2005 20:31 ]
nobody?? please ive compiled the code more than 100 times!! :(
thanks
Author:  gafar [ Fri Feb 18, 2005 22:15 ]
Jim,
try use the invert mode comand 21h . I can initialize, but a have the same problem, i can send x and y, invert lcd.
The colour nothing, only clear lcd with colour white.
look in
http://www.deramon.de/nokia6610lcd.php
http://www.apetech.de/nokia6100.php
Author:  J1M [ Fri Feb 18, 2005 22:39 ]
ive found a 'little' error into the output of bits ..... its modified in the code below.
now lcd seems to do 'something' but... no color! its suppouse im drawing a red background but.... nothing append.. ill try with invert mode...
thanks gafar! ;)
Author:  llornkcor [ Sat Feb 19, 2005 5:16 ]
I had the same problem when using the EPSON version of the screen. When i initialised the screen it comes on with a dull golden glow. I solve my problem by adjusting the voltages to the LED+ pin (pin 10). My volatage was too high making the contrast too high so I couldn't see any changes to pixels. Lower voltages should help.
Author:  J1M [ Sat Feb 19, 2005 13:22 ]
thanks for your reply llornkcor, im using philips version (brown board), and i think there isnt a problem o led voltages, i try with a low level and a high level and... nothing append... :oops:
thanks ;)
Author:  Henri [ Sat Feb 19, 2005 18:04 ]
It is already about year since I last worked with these displays so I don't remember anymore how things exactly work. To refresh my memory I would have to read the datasheets again.
But these links posted earlier look like they would have some nice example code to use and see how the initialization and other things work.
I will bookmark these for myself to have a closer look when I next time work with these displays.
Author:  J1M [ Sat Feb 19, 2005 20:28 ]
thanks henri, now i can send images to the display :) (was a stupid wire...) ... ill finish the library with PIC and ill post it.
Salu2!
Author:  J1M [ Mon Feb 21, 2005 15:20 ]
hi!
Henri, ive a problem with mi library, when i send an image to the display, that is my result
As you can see, the img ist complete, the functions are this:
void gclcd_img(void)
gclcd_setarea(X_START, X_END, Y_START, Y_END);
gclcd_cmd(MEMWRITE);
for(i=0; i<(PIXELX*PIXELY)/2; i++)
gclcd_data(imagen[i]);
imagen code:
static const unsigned char imagen [19200]={
0x42, 0x4D, 0x3E, 0x47, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x36, 0x04, 0x00, 0x00, 0x28, 0x00......... continue until 19200 hex values...
Thnks!
Author:  gafar [ Tue Feb 22, 2005 0:05 ]
Post subject:  Bingo
Hi all,
I can to send data to lcd after use comand the contrast. Next step is send image.
Thanks the all for help-me.
Author:  gafar [ Tue Mar 01, 2005 13:25 ]
Post subject:  LCD
This my first work with lcd. I damaged the leds because i don´t used resistor.
Author:  J1M [ Sat Mar 05, 2005 0:48 ]
hi all! im publish a preliminary version of my library v0.1 with a pic18F
http://foros.solocodigo.com/index.php?showtopic=13883
im looking for a program, or source code (PC) that convert an image (bmp 256) to RGB8 .. and hex values... in other words... a simple converter rgb8 with an output in hexadecimal...
thanks!
Author:  lcdmania [ Mon Mar 07, 2005 3:39 ]
See this rgb8 convertert.
I not tested it.
http://www.lcdmania.net/files/RGB8_CONVERTER.exe
Junior
Page 5 of 20 All times are UTC + 2 hours
http://www.phpbb.com/
