It is currently Thu Sep 10, 2026 17:16
PostPosted: Tue May 04, 2004 21:21
Hello,
i'm trying to program a 80c51 MPU to drive a P-12864-F LCD (powertip, 128x64)...
I'm using C language and i have a lot of difficulties... plus it's for my studies' final project :?
I guess all my initialisations are correct (thanks to the T6963 datasheet) but i can't display anything :(
I use the status check and the LCD seams to be ready as the STA0 & STA1 bits are set to 1.
If anyone can give me a simple sample code for 80x51 i'll be very glad :wink: It would help me to find my errors...
Thank you in advance :)
Chris as Hwj
(excuse my english...)
PostPosted: Wed May 05, 2004 18:11
For a simple example code in C you might find this useful:
http://www.skippari.net/phpBB2/viewtopic.php?t=362
It's for AVR but that shouldn't matter here.
PostPosted: Sun May 30, 2004 11:37
hello....
i still have problemsto make my LCD work ... i think my hardware connections are wrong....
First, what should i connect on the backlight pins (A & K) ??
Plus, in the datasheet http://www.powertip.com.tw/product/PG%20SERIES/PG%2012864-F.PDF, what is the OPERATION VOLTAGE Vop ???? :? :?
I'm suppling my µC and my LCD with 5V on the pin Vcc...
I still have nothing on my display and i'm sure that my code is right... i test it with a logical analyser
Thank U in advance all...
Chris
Users browsing this forum: No registered users and 611 guests
