| Help :'( >> T6963c + 80c51 http://forum.lcdinfo.com/viewtopic.php?f=9&t=636 |
| Author: | hwj [ Tue May 04, 2004 21:21 ] |
| Post subject: | Help :'( >> T6963c + 80c51 |
Hello, i'm trying to program a 80c51 MPU to drive a P-12864-F LCD (powertip, 128x64)... I'm using C language and i have a lot of difficulties... plus it's for my studies' final project I guess all my initialisations are correct (thanks to the T6963 datasheet) but i can't display anything I use the status check and the LCD seams to be ready as the STA0 & STA1 bits are set to 1. If anyone can give me a simple sample code for 80x51 i'll be very glad Thank you in advance Chris as Hwj (excuse my english...) |
| Author: | Henri [ Wed May 05, 2004 18:11 ] |
For a simple example code in C you might find this useful: http://www.skippari.net/phpBB2/viewtopic.php?t=362 It's for AVR but that shouldn't matter here. |
| Author: | hwj [ Sun May 30, 2004 11:37 ] |
hello.... i still have problemsto make my LCD work ... i think my hardware connections are wrong.... First, what should i connect on the backlight pins (A & K) ?? Plus, in the datasheet http://www.powertip.com.tw/product/PG%20SERIES/PG%2012864-F.PDF, what is the OPERATION VOLTAGE Vop ???? I'm suppling my µC and my LCD with 5V on the pin Vcc... I still have nothing on my display and i'm sure that my code is right... i test it with a logical analyser Thank U in advance all... Chris |
