| 8210 Help --> Henry,Zotty http://forum.lcdinfo.com/viewtopic.php?f=9&t=674 |
| Author: | pravin [ Sun May 23, 2004 21:23 ] |
| Post subject: | 8210 Help --> Henry,Zotty |
Hi, Can u please let me know the display size of 8210 if the controller used is PCD8544. I have displayed CUSTOM LOGICS ,with CUSTOM on one line and LOGICS on the second line. It works fine for all the other LCD,however when it comes to 8210 ,the display is something wierd I get the last two lines full black and CUSTOM on the third last line while LOGICS on fourth last line. What can be the possible problem . Pravin |
| Author: | Henri [ Mon May 24, 2004 22:09 ] |
| Post subject: | Re: 8210 Help --> Henry,Zotty |
pravin wrote: Hi,
Can u please let me know the display size of 8210 if the controller used is PCD8544. I have displayed CUSTOM LOGICS ,with CUSTOM on one line and LOGICS on the second line. It works fine for all the other LCD,however when it comes to 8210 ,the display is something wierd I get the last two lines full black and CUSTOM on the third last line while LOGICS on fourth last line. What can be the possible problem . Pravin My belief has been that 8210 used 84x48 display with PCD8544 controller. But I've never tested it myself. So are you testing the display with LCDInfo ? Or some of your own code ? If I'm not completely mistaken I think someone used 8210 display with LCDInfo succesfully. |
| Author: | pravin [ Tue May 25, 2004 13:56 ] |
| Post subject: | 8210 |
Hi Henry, I am checking i with the microcontroller code which i have wrote. I have the same code working for other LCD supported by PCD8544 Pravin |
| Author: | pravin [ Wed May 26, 2004 18:52 ] |
| Post subject: | problem solved |
Hi, Henry the problem is solved ,it was because of the rubber pad ,probably got damaged . its working fine with new rubber pad Thanks for the help henry Pravin |
