It is currently Mon Nov 23, 2026 16:02
 Post subject: 6610 how to with a pic
PostPosted: Thu Jun 03, 2004 15:04
Hello,
I'm working on the 6610 lcd connected to a pic 18F452. It works well. But It is not easy to understand how using the color parameters.
Did anyone have found a bitmap converter to hex file to send to the lcd ?
Or has anyone know how to convert easily a bitmap image in a sequence of byte for the 6610 ? I use the patern RRRRGGGG BBBBRRRR GGGGBBBB on 3x8bit.
Thanks for helping
BB
 Post subject: 6610 lcd
PostPosted: Sun Jan 02, 2005 15:17
Hi Biggbob,
I'm trying to do the same thing here (connect pic 18 to nokia 6610 lcd), but so far the display is unresponsive. It might help me out if you could post (or send me) some source code for me to look at. Or maybe even a hex file so I can check my setup.
Thanks,
bart
PostPosted: Wed Jan 12, 2005 23:29
look at this:
http://www.comunicom.com.py/juno/3595/
i hope it might help you
regards! ;)
PostPosted: Mon Jan 17, 2005 0:31
hi! ill find this:
http://www.myplace.nu/mp3/download/file ... r_v312.zip
http://www.myplace.nu/mp3/yabbse/index.php?topic=1.0
try to find section that send an image from MMC (multimedia card) to display.
regards! ;)
PostPosted: Mon Jan 17, 2005 22:56
hi! check this:
http://www.pacalaconcurso.com/modules.p ... cle&sid=25
s2!
