| wierd problem with lcd http://forum.lcdinfo.com/viewtopic.php?f=9&t=801 |
| Author: | jijita [ Mon Aug 30, 2004 8:36 ] |
| Post subject: | wierd problem with lcd |
i'm using a wg12864b lcd ks0108 i figured out how to write to it but there's a problem whenever i write something to the controller CS2 it will write automatically on both controllers the thing that was meant to be on controller CS2 only then in the same program if i choose to write on CS1 i can't. and if in another code i choose the CS1 controller and write something on it it is written only onthat controller ;but if in the same code i choose after this CS2 to write on i can't write anything please can anyone tell me what may be the problem i'm really confused |
| Author: | jijita [ Mon Aug 30, 2004 8:39 ] |
here is the code for the right controller if i try to add something to write on the left controller i can't: list p=16f877 #include <p16f877.inc> LCD_DATA EQU PORTC ; LCD data lines interface LCD_DATA_TRIS EQU TRISC LCD_CTRL EQU PORTA ; LCD control lines interface LCD_TEMP EQU 0x020 ; LCD subroutines internal use R1 EQU 0x21 R2 EQU 0x22 DELAY EQU 0x023 ; Used in DELAYxxx routines X_DELAY EQU 0x024 ; Used in X_DELAYxxx routines ; PORTA control bits LCD_E EQU 2 ; LCD Enable control line LCD_RW EQU 1 ; LCD Read/Write control line LCD_RS EQU 0 ; LCD Register-Select control line CS1 EQU 3 CS2 EQU 4 Rst EQU 5 ORG 0X00 GOTO main main BCF STATUS,RP1 ;turns to Bank 1 BSF STATUS,RP0 MOVLW 0x06 ; Configure all pins MOVWF ADCON1 ; as digital inputs BSF STATUS,RP0 MOVLW B'00000111' OPTION CLRF TRISA MOVLW H'00' MOVWF TRISC BCF STATUS,RP0 CLRF PORTA CLRF PORTC BSF LCD_CTRL, LCD_RS ; Set LCD in command BSF PORTA,5 NOP NOP NOP NOP NOP NOP NOP NOP NOP NOP NOP NOP NOP NOP NOP NOP NOP NOP NOP NOP CALL DELAI CALL DELAI BCF PORTA,5 NOP NOP NOP NOP NOP NOP NOP NOP NOP NOP CALL DELAI BSF PORTA,5 CALL DELAI CALL DELAI CALL DELAI CALL DELAI CALL DELAI CALL DELAI CALL DELAI CALL DELAI CALL DELAI CALL DELAI CALL DELAI CALL DELAI NOP NOP NOP NOP NOP NOP NOP NOP NOP NOP NOP NOP NOP NOP NOP NOP NOP NOP NOP NOP NOP NOP NOP NOP NOP NOP NOP NOP NOP NOP NOP NOP NOP NOP NOP NOP NOP NOP NOP NOP NOP NOP NOP NOP NOP NOP NOP NOP NOP NOP MOVLW H'07' CALL WRITE_COMMAND1 MOVLW H'40' ;Set Y Column Address >From 0 CALL WRITE_COMMAND1 MOVLW H'B8' ;Set Page From 0 CALL WRITE_COMMAND1 MOVLW H'C0' ;Set Display Start Line CALL WRITE_COMMAND1 MOVLW H'3F' ;Set Display ON CALL WRITE_COMMAND1 SHOWC: CLRF R1 CLRF R2 SCLOOP1: MOVLW H'B8' ;Set Page Address FROM 00H ADDWF R1,W ;Command B8H~BFH CALL WRITE_COMMAND1 ; CALL WRITE_COMMAND2 MOVLW 0x40 ;Set Column Address FROM 40H CALL WRITE_COMMAND1 ; CALL WRITE_COMMAND2 SCLOOP2 CALL table CALL WRITE_DATA1 INCF R2,1 MOVLW D'15' SUBWF R2,W BTFSC STATUS,Z GOTO clea GOTO SCLOOP2 clea CLRF R2 clearing INCF R2,1 MOVLW H'FF' CALL WRITE_DATA1 MOVLW D'45' SUBWF R2,W BTFSC STATUS,Z GOTO finale GOTO clearing table MOVF R2,W ADDWF PCL,1 RETLW H'8C' RETLW H'92' RETLW H'92' RETLW H'62' RETLW H'80' RETLW H'FE' RETLW H'92' RETLW H'92' RETLW H'92' RETLW H'80' RETLW H'8C' RETLW H'92' RETLW H'92' RETLW H'62' RETLW H'00' WRITE_COMMAND1 MOVWF LCD_TEMP ; Command to send is in W ;Write Command To CS1 BCF LCD_CTRL,CS2 BSF LCD_CTRL,CS1 BCF LCD_CTRL, LCD_RW ; Set LCD in read mode BCF LCD_CTRL, LCD_RS ; Set LCD in command mode MOVF LCD_TEMP, W MOVWF LCD_DATA BSF LCD_CTRL, LCD_E ; LCD E-line High NOP NOP NOP NOP CALL DELAI BCF LCD_CTRL, LCD_E ; LCD E-line Low RETURN ;****************************************************************************** WRITE_DATA1 MOVWF LCD_TEMP ; Command to send is in W ;Write Command To CS1 BCF LCD_CTRL,CS2 BSF LCD_CTRL,CS1 BCF LCD_CTRL, LCD_RW ; Set LCD in read mode BSF LCD_CTRL, LCD_RS ; Set LCD in command mode MOVF LCD_TEMP, W MOVWF LCD_DATA BSF LCD_CTRL, LCD_E ; LCD E-line High NOP CALL DELAI BCF LCD_CTRL, LCD_E ; LCD E-line Low RETURN ;****************************************************************************** WRITE_COMMAND2 MOVWF LCD_TEMP ; Command to send is in W BCF LCD_CTRL,CS1 ;Write Command To CS1 BSF LCD_CTRL,CS2 BCF LCD_CTRL, LCD_RW ; Set LCD in read mode BCF LCD_CTRL, LCD_RS ; Set LCD in command mode MOVF LCD_TEMP, W MOVWF LCD_DATA BSF LCD_CTRL, LCD_E ; LCD E-line High NOP CALL DELAI BCF LCD_CTRL, LCD_E ; LCD E-line Low RETURN ;****************************************************************************** DELAI MOVLW D'255' MOVWF DELAY REPEAT DECFSZ DELAY,1 GOTO REPEAT RETURN ;LCDINIT ; Busy-flag is not yet valid ; CLRF LCD_CTRL ; ALL PORT output should output Low. ; power-up delay ; MOVLW 0x050 ; CALL X_DELAY500 ; MOVLW 0x030 ; 8-bit-interface, 2-lines ; CALL LCDPUTCMD ;MOVLW 0x009 ; CALL X_DELAY500 ; MOVLW 0x030 ; 8-bit-interface, 2-lines ; CALL LCDPUTCMD ;CALL X_DELAY500 ; MOVLW 0x030 ; 8-bit-interface, 2-lines ; CALL LCDPUTCMD ;MOVLW 0x030 ; 8-bit-interface, 2-lines ; CALL LCDPUTCMD ;MOVLW 0x008 ; 8-bit-interface, 2-lines ; CALL LCDPUTCMD ;MOVLW 0x001 ; 8-bit-interface, 2-lines ; CALL LCDPUTCMD ;MOVLW 0x007 ; 8-bit-interface, 2-lines ; CALL LCDPUTCMD finale NOP END |
| Author: | Henri [ Mon Aug 30, 2004 15:44 ] |
| Post subject: | Re: wierd problem with lcd |
jijita wrote: whenever i write something to the controller CS2 it will write automatically on both controllers the thing that was meant to be on controller CS2 only This would happen if you have the both CS pins selected at the same time. Quote: then in the same program if i choose to write on CS1 i can't.
and if in another code i choose the CS1 controller and write something on it it is written only onthat controller ;but if in the same code i choose after this CS2 to write on i can't write anything please can anyone tell me what may be the problem i'm really confused Sounds like there's something wrong in the way you are setting the CS pins. You might try looking at the earlier posts in this forum as there were example codes for this controller. |
| Author: | jijita [ Mon Aug 30, 2004 21:32 ] |
thank you henri for your help i'll try the old posts |
