It is currently Mon Nov 23, 2026 15:08
PostPosted: Thu May 05, 2011 15:22
Hello,
I have a MC SiLabs C8051F410 and display NHD-240128WG-BYGH-VZ000C (T6963C controller), connected to it. Scheme of connection I can provide.
And I have such a problem: I want to display any letter or number, but I can see only one line on my display, that blinking with a frequency, depending on a frequency of MC kernel.
I've read a lot of information and try a lot of variants of code, but I've not found any solution of this problem. I'll be more than happy, if somebody help me to solve this problem!
There is my code:
#include <c8051f410.h> // SFR declarations
#include <stdio.h>
#include <string.h>
sbit D0 = P1^0;
sbit D1 = P1^1;
sbit D2 = P1^2;
sbit D3 = P1^3;
sbit D4 = P1^4;
sbit D5 = P1^5;
sbit D6 = P1^6;
sbit D7 = P1^7;
sbit CD = P2^0;
sbit RD = P2^1;
sbit WR = P2^2;
sbit CE = P2^3;
sbit RS = P2^4;
sbit MD = P2^5;
sbit FS = P2^6;
void oscillatorInit (void);
void portInit (void);
void delay (int);
void writeLcdData (char);
void writeLcdCommand (char);
int readLcdStatus (void);
void lcdInit (void);
int i,j;
void main (void)
PCA0MD &= ~0x40; // WDTE = 0 (clear watchdog timer enable)
portInit(); // Initialize Port I/O
oscillatorInit (); // Initialize Oscillator
lcdInit (); // Initialize LCD
if (!readLcdStatus ()) return;
writeLcdCommand(0x80); //set display mode (OR mode)
writeLcdData(0x00);
writeLcdData(0x17); //text home address = 1700h
writeLcdCommand(0x40); //text home address set
writeLcdData(0x28);
writeLcdData(0x00); //text area address = 0028h
writeLcdCommand(0x41); //text area control set
writeLcdData(0x00);
writeLcdData(0x00); //graphic home address = 0000h
writeLcdCommand(0x42); //graphic home address set
writeLcdData(0x28);
writeLcdData(0x00); //graphic area = 0028h
writeLcdCommand(0x43); //graphic area control set
writeLcdCommand(0x9C); //text ON graph ON
//writeLcdCommand(0x98); //text OFF graph ON
//writeLcdCommand(0x94); //text ON graphic OFF
writeLcdData(0x7A);
writeLcdData(0x17); //text area address = 177Ah
writeLcdCommand(0x24); //set address pointer
writeLcdData(0x15); //any data ('5')
writeLcdCommand(0xC0); //data write and inc ADP
void lcdInit(void)
RS = 0;
delay(100);
RS = 1;
void writeLcdData (char valueData)
while (!readLcdStatus());
CD = 0;
delay (100);
WR = 0;
CE = 0;
P1 = valueData;
delay (100);
WR = 1;
CE = 1;
CD = 0;
P1 = 0xFF;
void writeLcdCommand (char valueCommand)
CD = 1;
delay (100);
WR = 0;
CE = 0;
P1 = valueCommand;
delay (100);
WR = 1;
CE = 1;
CD = 0;
P1 = 0xFF;
CD = 1;
RD = 0;
WR = 1;
CE = 0;
delay (100);
P1 |= 0xFF;
delay(100);
if (D0 != 1 && D1 !=1)
return 0;
else
return 1;
void delay (int tmp)
for (i = tmp; i > 0; i--);
return;
OSCICN |= 0x85; //Configure internal oscillator for
// 24.5/4 Mhz (~6 Mhz)
P1MDIN |= 0xFF; // Make switch pins digital
P2MDIN |= 0xFF;
P1MDOUT |= 0x00; // Make switch pins open-drain
P2MDOUT |= 0x00;
XBR1 = 0x40; // Enable crossbar and enable
PostPosted: Fri May 13, 2011 17:55
I have found the topic with the same proble, as mine.
viewtopic.php?f=9&t=1333
And no one solve this problem.
Please help me!
PostPosted: Mon May 23, 2011 12:07
still waiting for updates...
streaming tv
