It is currently Tue Oct 06, 2026 14:22
PostPosted: Wed Nov 03, 2004 5:51
Hello everybody,
I bought a 128x128 LCD manufatured by Xiamen (PN above) and all that I got was the LCD and a single-page "datasheet" describing interface pins and a drawing.
I've tried several ways (via LPT port, PIC uC, using LCDPower, LCDInfo, CBuilder, VB...) to drive the LCD. I could only initialize (I can barely see the display clearing). I'd like help to show something controlled (a text, a pixel...), but all others routines aren't working!!!
I'm using the PowerLCD wiring, the LCD board has a 32kb SRAM memory and I selected 8x8 font. I'm using this posted code to drive the LCD:
#define G_BASE 0x0300
#define T_BASE 0x0000
#define BYTES_PER_ROW 16
#define BASE 0x378
void WaitDisplayReady(void)
// reads the display status byte and checks
// that the display is ready before writing
// doesn't have any check in case the status byte
// can't be read so this situation may cause a lockup
  int Tmp;
       Tmp = DlPortReadPortUshort(BASE + 0x402);
       Tmp = Tmp & 0x1F;
       Tmp = Tmp | 0x20;
       DlPortWritePortUshort(BASE + 0x402, Tmp);
       do{
             DlPortWritePortUshort(BASE + 2, 0x20 + 4 + 2);     //In, CD=1, CS=0, Wr=1
             DlPortWritePortUshort(BASE + 2, 0x20 + 4 + 2 + 8); //In, CD=1, CS=0, Wr=1, Rd=0
             Tmp = DlPortReadPortUshort(BASE);
       }while ((Tmp & 3) != 3 );
       DlPortWritePortUshort(BASE + 2, 0);
void WriteData(unsigned short Data)
   WaitDisplayReady();
    DlPortWritePortUshort(BASE, Data);
    DlPortWritePortUshort(BASE + 2, 0);   // 0111 C/D low
    DlPortWritePortUshort(BASE + 2, 2);   // 0011 WR low
    DlPortWritePortUshort(BASE + 2, 3);   // 0010 CE low
    DlPortWritePortUshort(BASE + 2, 2);   // 0011 CE high
    DlPortWritePortUshort(BASE + 2, 0);   // 0111 WR high
void WriteCtrl(unsigned short Command)
    WaitDisplayReady();
    DlPortWritePortUshort(BASE, Command);
    DlPortWritePortUshort(BASE + 2, 4);      // 1111 C/D high
    DlPortWritePortUshort(BASE + 2, 4+2);      // 1011 WR low
    DlPortWritePortUshort(BASE + 2, 4+3);      // 1010 CE low
    DlPortWritePortUshort(BASE + 2, 4+2);      // 1011 CE high
void InitLCD(void)
  // Display init
  WriteData(T_BASE & 0xFF);   // Data1: LowAddress
  WriteData(T_BASE >> 8);     // Data2: HighAddress
  WriteCtrl(0x40);            // Command: 0x40 -> 01000000
  WriteData(BYTES_PER_ROW);  // Data1: Colums
  WriteData(0);              // Data2: 0
  WriteCtrl(0x41);           // Command: 0x41 -> 01000001
  WriteData(G_BASE & 0xFF);  // Data1: LowAddress
  WriteData(G_BASE >> 8);    // Data2: HighAddress
  WriteCtrl(0x42);           // Command: 0x42 -> 01000010
  WriteCtrl(0x43);           // Command: 0x43 -> 01000011
  // Internal CGROM Mode, OR Mode
  WriteCtrl(0x80); // OR Mode    // 80->10000000
  WriteCtrl(0xa7); // cursor is 8 lines high
  WriteData(0x00);
  WriteData(0x00);
  WriteCtrl(0x21); // put cursor at (x,y)
  // DisplayMode
  WriteCtrl(0x9D);
void SetLCDXY(int x, int y)
int addr;
  addr = T_BASE + (y * BYTES_PER_ROW) + x;
  WriteData(addr & 0xFF);
  WriteData(addr >> 8);
  WriteCtrl(0x24);
void SetLCDCursor(int x, int y)
  WriteData(x);
  WriteData(y);
  WriteCtrl(0x21);
void ClearLCDText(void)
  int i;
  WriteCtrl(0x24);      // address pointer to T_BASE
  for (i=0;i<2048;i++) {
        WriteData(0); WriteCtrl(0xc0); // write data and inc ptr
void ClearLCDGraph(void)
  int i;
  WriteCtrl(0x24); // address pointer to G_BASE
  for (i=0;i<2048;i++){
void PrintLCDText(char *string)
  unsigned int i;
  char c;
  for (i=0;i<strlen(string);i++){
        c = string[i] - 0x20; // conversion from ASCII to LCD characters
        if (c<0) c=0;
        WriteData(c);
        WriteCtrl(0xc0);
void SetLCDPixel(int x, int y)
  int addr;
  addr = G_BASE + (y*BYTES_PER_ROW) + (x/8);
  WriteCtrl(0x24);
  WriteCtrl(0xf8 | (7-(x % 8)));
void ClearLCDPixel(int x, int y)
  int addr;
  WriteCtrl(0x24);
  WriteCtrl(0xf0 | (7-(x % 8)));
void main(void)
  InitLCD();
  ClearLCDText();
  ClearLCDGraph();
  SetLCDXY(2,7);
  PrintLCDText("Text");
Thanks a lot!!!
Users browsing this forum: No registered users and 417 guests
