| Display Problem with Dataimage 128x64 Graphic LCD http://forum.lcdinfo.com/viewtopic.php?f=9&t=964 |
| Author: | Anoop [ Mon Jan 03, 2005 7:28 ] |
| Post subject: | Display Problem with Dataimage 128x64 Graphic LCD |
Dear All, I am Designing New Display with Dataimage 128x64 Graphic LCD, But the problem is that it is showing the same text message on both side of Controller i.e CS1 & CS2 insteed of the hole message as string.Can anybody help me out. with thanks in advance! Anoop Tiwari[/code] |
| Author: | Syridian [ Mon Jan 17, 2005 4:41 ] |
If you could provide more information on the model of the display, someone might be interested in taking a look for you. But if you leave all the work to us, then why would we bother? Model No. and any other info, links to datasheets... Anyway. |
| Author: | Henri [ Mon Jan 17, 2005 13:19 ] |
How are you handling the CS1 and CS2 pins in your code ? Normally you should only have one side of the display enabled at a time as the display is made of two 64x64 parts and with the CS signals you select which one is currently used. |
| Author: | Anoop [ Thu Jan 20, 2005 7:06 ] |
| Post subject: | Pls Check the code as below |
[quote="Henri"]How are you handling the CS1 and CS2 pins in your code ? Normally you should only have one side of the display enabled at a time as the display is made of two 64x64 parts and with the CS signals you select which one is currently used Pls check this code As I marked note in LCD_Write_Char Subroutine As(LCD_Page_Set() & LCD_Column_Set() ) After removing this 2 subroutines only half of display glow otherwise no Display at all. /**************Start********************************/ #include <stdio.h> #include <io320.h> // SFR declarations #include <Font.h> #define DISPLAY_ON 0x3F #define DISPLAY_OFF 0x3E #define DISPLAY_START_LINE 0xC0 #define DISPLAY_PAGE_SET 0xB8 #define DISPLAY_COLUMN_SET 0x40 sbit LCD_E = P3^0; //pin for Display Enable sbit LCD_RS =P3^1; //pin for register select sbit LCD_CS0 =P3^2; //pin for Controller1 Chip select sbit LCD_CS1 =P3^3; //pin for Controller2 Chip select sbit LCD_RW =P3^4; //pin for read/write #define RIGHT 0 #define LEFT 1 #define BUSY 0x80 unsigned char CursorX, CursorY; #define LINE1 0 #define LINE2 1 #define LINE3 2 #define LINE4 3 #define LINE5 4 #define LINE6 5 #define LINE7 6 #define LINE8 7 /****************SUB ROUTIENS**************************************/ void Delay(unsigned int wait); void LCD_init(void); void LCD_clear_scrn(void); void LCD_test(void); void LCD_Putstr(unsigned char *ptr); void LCD_Page_Set(unsigned char xAddr); void LCD_Column_Set(unsigned char yAddr); void LCD_Data_Write(unsigned char Data); void LCD_Start_Line(unsigned char start); void LCD_Command_Write(unsigned char command); void LCD_Write_Char(unsigned char c); void LCD_Set_Address(unsigned char x,unsigned char y); unsigned char LCD_Data_Read(void); void LCD_Select_Side(unsigned char LcdSide); void LCD_Wait_Busy(void); void LCD_Set_Dot (unsigned char x, unsigned char y); void LCD_Rectangle (unsigned char x,unsigned char y,unsigned char a,unsigned char b); /*******************************************************************/ /******************MAIN PROGRAM************************************/ void main(void) { P1 = 0x00; P3 = 0x00; LCD_init(); LCD_test(); } /******************************************************************/ void LCD_init(void) { LCD_Select_Side(LEFT); LCD_Command_Write(DISPLAY_ON); LCD_Command_Write(DISPLAY_START_LINE); LCD_Command_Write(DISPLAY_PAGE_SET); LCD_Command_Write(DISPLAY_COLUMN_SET); LCD_Select_Side(RIGHT); LCD_Command_Write(DISPLAY_ON); LCD_Command_Write(DISPLAY_START_LINE); LCD_Command_Write(DISPLAY_PAGE_SET); LCD_Command_Write(DISPLAY_COLUMN_SET); LCD_Start_Line(0); LCD_Set_Address(0,0); } /*******************************************************************/ void LCD_test(void) { LCD_clear_scrn(); LCD_Set_Address(4,LINE2); LCD_Putstr("P1 12.500V 05.000A"); LCD_Set_Address(4,LINE3); LCD_Putstr("cv cc "); LCD_Set_Address(4,LINE4); LCD_Putstr("P2 12.500 05.000A"); LCD_Set_Address(4,LINE5); LCD_Putstr("cv cc "); LCD_Set_Address(4,LINE6); LCD_Putstr("output on/off "); LCD_Set_Address(4,LINE7); LCD_Putstr("Remote ovp/ocp"); LCD_Rectangle(0,0,64,128); } /*******************************************************************/ void LCD_Putstr(unsigned char *ptr) { while(*ptr) { LCD_Write_Char(*ptr); ptr++; } } /*******************************************************************/ void LCD_clear_scrn(void) { unsigned char x, y; LCD_CS0 = 1; for(y =0; y <8; y++) { LCD_Page_Set(0); LCD_Column_Set(y); for(x =0; x< 64; x++)LCD_Data_Write(0x00); } LCD_CS0 = 0; LCD_CS1 = 1; for(y =0; y <8; y++) { LCD_Page_Set(0); LCD_Column_Set(y); for(x =0; x< 64; x++)LCD_Data_Write(0x00); } LCD_CS1 = 0; } /******************************************************************/ void LCD_Write_Char(unsigned char c) { unsigned char i = 0, x; unsigned char Data; if(CursorX >128) { CursorX =0; CursorY++; if(CursorY ==8)CursorY =0; } if(CursorX <64) { LCD_CS0 = 1; x =CursorX; } else { LCD_CS1 = 1; x =CursorX - 64; } LCD_Page_Set(x); /* After removing this only half part of LCD Displayed the Text*/ LCD_Column_Set(CursorY); /* After removing this only half part of LCD Displayed the Text*/ do{ Data =Font[((c - 0x20) * 5)+i ]; LCD_Data_Write(Data); i++; CursorX++; if(CursorX ==64) { LCD_CS0 = 0; LCD_CS1 = 1; } else if(CursorX ==128) { LCD_CS0 = 1; LCD_CS1 = 0; CursorX =0; CursorY++; if(CursorY ==8)CursorY =0; } if(CursorX <64)x =CursorX; else x =CursorX - 64; LCD_Page_Set(x); /* After removing this only half part of LCD Displayed the Text*/ LCD_Column_Set(CursorY); /* After removing this only half part of LCD Displayed the Text*/ } while(i<5); CursorX++; if(CursorX ==128)CursorX =0; else LCD_Data_Write(0x00); LCD_CS0 = 0; LCD_CS1 = 0; LCD_Start_Line(0); } /*****************************************************************/ void LCD_Start_Line(unsigned char start) { LCD_Select_Side(LEFT); LCD_Command_Write(DISPLAY_START_LINE | (start)); LCD_Select_Side(RIGHT); LCD_Command_Write(DISPLAY_START_LINE | (start)); } /******************************************************************/ void LCD_Data_Write(unsigned char Data) { LCD_Wait_Busy(); LCD_RS = 1; LCD_RW = 0; P1 = Data; LCD_E = 1; Delay(20); LCD_E = 0; } /******************************************************************/ void LCD_Command_Write(unsigned char Command ) { LCD_Wait_Busy(); LCD_RS = 0; LCD_RW =0; P1 = Command; LCD_E =1; Delay(20); LCD_E =0; } /*************Read Data From LCD************************************/ unsigned char LCD_Data_Read(void) { LCD_Wait_Busy(); P1 = 0x00; LCD_RS =1; //Data Mode LCD_RW =1; // Read Mode LCD_E =1; Delay(20); LCD_E =0; Delay(20); return P1; } /******************************************************************/ void LCD_Wait_Busy(void) { P1 = 0x00; LCD_RS =0; //Instruction Mode LCD_RW =1; // Read Mode LCD_E =1; Delay(20); LCD_E =0; while(P1 & 0x7F ==BUSY); //test the Busy Bit } /******************************************************************/ void LCD_Set_Address(unsigned char x,unsigned char y) { LCD_Page_Set(x); LCD_Column_Set(y); } /*****************From left to right(0 : 63)**********************/ void LCD_Page_Set(unsigned char xAddr) { LCD_Select_Side(LEFT); LCD_Command_Write(DISPLAY_PAGE_SET | xAddr); LCD_Select_Side(RIGHT); LCD_Command_Write(DISPLAY_PAGE_SET | xAddr); } /****************From top to bottom(0 : 7)************************/ void LCD_Column_Set(unsigned char yAddr) { LCD_Select_Side(LEFT); LCD_Command_Write(DISPLAY_COLUMN_SET | yAddr); LCD_Select_Side(RIGHT); LCD_Command_Write(DISPLAY_COLUMN_SET | yAddr); } /*******************************************************************/ void Delay(unsigned int wait) { while(wait!=0) { wait--; } } /******************************************************************/ void LCD_Select_Side(unsigned char LcdSide) { if(LcdSide ==LEFT) { //Switch to left Side LCD_E =0; LCD_RS =0; LCD_CS0 =1; LCD_CS1 =0; LCD_RW =1; LCD_Command_Write(DISPLAY_COLUMN_SET); } else { //Switch to rigth Side LCD_E =0; LCD_RS =0; LCD_CS0 =0; LCD_CS1 =1; LCD_RW =1; LCD_Command_Write(DISPLAY_COLUMN_SET); } } /******************************************************************/ void LCD_Set_Dot(unsigned char x, unsigned char y) { unsigned char Temp; if(x <64) { LCD_CS0 =1; LCD_Page_Set(x); LCD_Column_Set(y/8); Temp = LCD_Data_Read(); Temp = LCD_Data_Read(); LCD_Page_Set(x); LCD_Data_Write(Temp | (1<<(y%8))); LCD_CS0 =0; } else { LCD_CS1 =1; LCD_Page_Set(x -64); LCD_Column_Set(y/8); Temp = LCD_Data_Read(); Temp = LCD_Data_Read(); LCD_Page_Set(x -64); LCD_Data_Write(Temp | (1<<(y%8))); LCD_CS0 =0; } LCD_Start_Line(0); } /******************************************************************/ void LCD_Rectangle(unsigned char x,unsigned char y,unsigned char a,unsigned char b) { unsigned char j; for(j=0; j<a; j++) { LCD_Set_Dot(x, y + j); LCD_Set_Dot(x + b - 1, y + j); } for(j=0; j<b; j++) { LCD_Set_Dot(x + j, y ); LCD_Set_Dot(x + j, y + a - 1); } } /********************************************************************/ [/code] |
| Author: | Anoop [ Thu Jan 20, 2005 7:30 ] |
| Post subject: | Re: Pls Check the code as below |
Anoop wrote: Henri wrote: How are you handling the CS1 and CS2 pins in your code ? Normally you should only have one side of the display enabled at a time as the display is made of two 64x64 parts and with the CS signals you select which one is currently used Pls check this code As I marked note in LCD_Write_Char Subroutine As(LCD_Page_Set() & LCD_Column_Set() ) After removing this 2 subroutines only half of display glow otherwise no Display at all. & Data sheet in pdf As:- http://www.dataimage.com.tw/en/product/ ... AYA-01.pdf thanks in advance Henri !! Anoop /**************Start********************************/ #include <stdio.h> #include <io320.h> // SFR declarations #include <Font.h> #define DISPLAY_ON 0x3F #define DISPLAY_OFF 0x3E #define DISPLAY_START_LINE 0xC0 #define DISPLAY_PAGE_SET 0xB8 #define DISPLAY_COLUMN_SET 0x40 sbit LCD_E = P3^0; //pin for Display Enable sbit LCD_RS =P3^1; //pin for register select sbit LCD_CS0 =P3^2; //pin for Controller1 Chip select sbit LCD_CS1 =P3^3; //pin for Controller2 Chip select sbit LCD_RW =P3^4; //pin for read/write #define RIGHT 0 #define LEFT 1 #define BUSY 0x80 unsigned char CursorX, CursorY; #define LINE1 0 #define LINE2 1 #define LINE3 2 #define LINE4 3 #define LINE5 4 #define LINE6 5 #define LINE7 6 #define LINE8 7 /****************SUB ROUTIENS**************************************/ void Delay(unsigned int wait); void LCD_init(void); void LCD_clear_scrn(void); void LCD_test(void); void LCD_Putstr(unsigned char *ptr); void LCD_Page_Set(unsigned char xAddr); void LCD_Column_Set(unsigned char yAddr); void LCD_Data_Write(unsigned char Data); void LCD_Start_Line(unsigned char start); void LCD_Command_Write(unsigned char command); void LCD_Write_Char(unsigned char c); void LCD_Set_Address(unsigned char x,unsigned char y); unsigned char LCD_Data_Read(void); void LCD_Select_Side(unsigned char LcdSide); void LCD_Wait_Busy(void); void LCD_Set_Dot (unsigned char x, unsigned char y); void LCD_Rectangle (unsigned char x,unsigned char y,unsigned char a,unsigned char b); /*******************************************************************/ /******************MAIN PROGRAM************************************/ void main(void) { P1 = 0x00; P3 = 0x00; LCD_init(); LCD_test(); } /******************************************************************/ void LCD_init(void) { LCD_Select_Side(LEFT); LCD_Command_Write(DISPLAY_ON); LCD_Command_Write(DISPLAY_START_LINE); LCD_Command_Write(DISPLAY_PAGE_SET); LCD_Command_Write(DISPLAY_COLUMN_SET); LCD_Select_Side(RIGHT); LCD_Command_Write(DISPLAY_ON); LCD_Command_Write(DISPLAY_START_LINE); LCD_Command_Write(DISPLAY_PAGE_SET); LCD_Command_Write(DISPLAY_COLUMN_SET); LCD_Start_Line(0); LCD_Set_Address(0,0); } /*******************************************************************/ void LCD_test(void) { LCD_clear_scrn(); LCD_Set_Address(4,LINE2); LCD_Putstr("P1 12.500V 05.000A"); LCD_Set_Address(4,LINE3); LCD_Putstr("cv cc "); LCD_Set_Address(4,LINE4); LCD_Putstr("P2 12.500 05.000A"); LCD_Set_Address(4,LINE5); LCD_Putstr("cv cc "); LCD_Set_Address(4,LINE6); LCD_Putstr("output on/off "); LCD_Set_Address(4,LINE7); LCD_Putstr("Remote ovp/ocp"); LCD_Rectangle(0,0,64,128); } /*******************************************************************/ void LCD_Putstr(unsigned char *ptr) { while(*ptr) { LCD_Write_Char(*ptr); ptr++; } } /*******************************************************************/ void LCD_clear_scrn(void) { unsigned char x, y; LCD_CS0 = 1; for(y =0; y <8; y++) { LCD_Page_Set(0); LCD_Column_Set(y); for(x =0; x< 64; x++)LCD_Data_Write(0x00); } LCD_CS0 = 0; LCD_CS1 = 1; for(y =0; y <8; y++) { LCD_Page_Set(0); LCD_Column_Set(y); for(x =0; x< 64; x++)LCD_Data_Write(0x00); } LCD_CS1 = 0; } /******************************************************************/ void LCD_Write_Char(unsigned char c) { unsigned char i = 0, x; unsigned char Data; if(CursorX >128) { CursorX =0; CursorY++; if(CursorY ==8)CursorY =0; } if(CursorX <64) { LCD_CS0 = 1; x =CursorX; } else { LCD_CS1 = 1; x =CursorX - 64; } LCD_Page_Set(x); /* After removing this only half part of LCD Displayed the Text*/ LCD_Column_Set(CursorY); /* After removing this only half part of LCD Displayed the Text*/ do{ Data =Font[((c - 0x20) * 5)+i ]; LCD_Data_Write(Data); i++; CursorX++; if(CursorX ==64) { LCD_CS0 = 0; LCD_CS1 = 1; } else if(CursorX ==128) { LCD_CS0 = 1; LCD_CS1 = 0; CursorX =0; CursorY++; if(CursorY ==8)CursorY =0; } if(CursorX <64)x =CursorX; else x =CursorX - 64; LCD_Page_Set(x); /* After removing this only half part of LCD Displayed the Text*/ LCD_Column_Set(CursorY); /* After removing this only half part of LCD Displayed the Text*/ } while(i<5); CursorX++; if(CursorX ==128)CursorX =0; else LCD_Data_Write(0x00); LCD_CS0 = 0; LCD_CS1 = 0; LCD_Start_Line(0); } /*****************************************************************/ void LCD_Start_Line(unsigned char start) { LCD_Select_Side(LEFT); LCD_Command_Write(DISPLAY_START_LINE | (start)); LCD_Select_Side(RIGHT); LCD_Command_Write(DISPLAY_START_LINE | (start)); } /******************************************************************/ void LCD_Data_Write(unsigned char Data) { LCD_Wait_Busy(); LCD_RS = 1; LCD_RW = 0; P1 = Data; LCD_E = 1; Delay(20); LCD_E = 0; } /******************************************************************/ void LCD_Command_Write(unsigned char Command ) { LCD_Wait_Busy(); LCD_RS = 0; LCD_RW =0; P1 = Command; LCD_E =1; Delay(20); LCD_E =0; } /*************Read Data From LCD************************************/ unsigned char LCD_Data_Read(void) { LCD_Wait_Busy(); P1 = 0x00; LCD_RS =1; //Data Mode LCD_RW =1; // Read Mode LCD_E =1; Delay(20); LCD_E =0; Delay(20); return P1; } /******************************************************************/ void LCD_Wait_Busy(void) { P1 = 0x00; LCD_RS =0; //Instruction Mode LCD_RW =1; // Read Mode LCD_E =1; Delay(20); LCD_E =0; while(P1 & 0x7F ==BUSY); //test the Busy Bit } /******************************************************************/ void LCD_Set_Address(unsigned char x,unsigned char y) { LCD_Page_Set(x); LCD_Column_Set(y); } /*****************From left to right(0 : 63)**********************/ void LCD_Page_Set(unsigned char xAddr) { LCD_Select_Side(LEFT); LCD_Command_Write(DISPLAY_PAGE_SET | xAddr); LCD_Select_Side(RIGHT); LCD_Command_Write(DISPLAY_PAGE_SET | xAddr); } /****************From top to bottom(0 : 7)************************/ void LCD_Column_Set(unsigned char yAddr) { LCD_Select_Side(LEFT); LCD_Command_Write(DISPLAY_COLUMN_SET | yAddr); LCD_Select_Side(RIGHT); LCD_Command_Write(DISPLAY_COLUMN_SET | yAddr); } /*******************************************************************/ void Delay(unsigned int wait) { while(wait!=0) { wait--; } } /******************************************************************/ void LCD_Select_Side(unsigned char LcdSide) { if(LcdSide ==LEFT) { //Switch to left Side LCD_E =0; LCD_RS =0; LCD_CS0 =1; LCD_CS1 =0; LCD_RW =1; LCD_Command_Write(DISPLAY_COLUMN_SET); } else { //Switch to rigth Side LCD_E =0; LCD_RS =0; LCD_CS0 =0; LCD_CS1 =1; LCD_RW =1; LCD_Command_Write(DISPLAY_COLUMN_SET); } } /******************************************************************/ void LCD_Set_Dot(unsigned char x, unsigned char y) { unsigned char Temp; if(x <64) { LCD_CS0 =1; LCD_Page_Set(x); LCD_Column_Set(y/8); Temp = LCD_Data_Read(); Temp = LCD_Data_Read(); LCD_Page_Set(x); LCD_Data_Write(Temp | (1<<(y%8))); LCD_CS0 =0; } else { LCD_CS1 =1; LCD_Page_Set(x -64); LCD_Column_Set(y/8); Temp = LCD_Data_Read(); Temp = LCD_Data_Read(); LCD_Page_Set(x -64); LCD_Data_Write(Temp | (1<<(y%8))); LCD_CS0 =0; } LCD_Start_Line(0); } /******************************************************************/ void LCD_Rectangle(unsigned char x,unsigned char y,unsigned char a,unsigned char b) { unsigned char j; for(j=0; j<a; j++) { LCD_Set_Dot(x, y + j); LCD_Set_Dot(x + b - 1, y + j); } for(j=0; j<b; j++) { LCD_Set_Dot(x + j, y ); LCD_Set_Dot(x + j, y + a - 1); } } /********************************************************************/ [/code] |
| Author: | errol_ [ Wed Mar 02, 2005 16:56 ] |
Hello Anoop Tiwari, I wrote a programm for an equal display by myself. To display your data correctly, you should (try to) manipulate the LCD_CS-variables in the LCD_Column_Set-Routine only. So if you want to change the CS-value, call your LCD_Column_Set-routine Execute the LCD_Column_Set- and LCD_Page_Set-routines every time you write a column/byte on the display. This might slow down your programm, but it avoids displaying errors. Your routines could look like this: void LCD_Column_Set(unsigned char yAddr) //yAddr=0..127 { LCD_CS0=(yAddr<64?LEFT:RIGHT); LCD_CS1=LCD_CS0?0:1; LCD_E = 1; LCD_RS =0; LCD_RW =1; P1 = DISPLAY_COLUMN_SET | ((y<64) ? y : (y-64)); LCD_E = 0; } void LCD_Page_Set(unsigned char xAddr) //xAddr=0..7 { LCD_E = 1; LCD_RS =0; P1 = DISPLAY_PAGE_SET | xAddr; _nop_(); _nop_(); _nop_(); _nop_(); LCD_E = 0; } void LCD_Write_Char(unsigned char c) { ... if(CursorY>123){ CursorY=0; CursorX=(CursorX+1)%8; } ... do{ LCD_Column_Set(CursorY); LCD_Page_Set(CursorX); Data =Font[((c - 0x20) * 5)+i ]; LCD_Data_Write(Data); i++; CursorY++; } while(i<5); ... } The LCD_Select_Side-routine is unnecessary/obsolete. I hope this could help to solve your problem... errol_ |
| Author: | errol_ [ Wed Mar 02, 2005 17:18 ] |
I exchanged the x- and y-cursor variables, because the display is organized like this:
regards errol_ |
