It is currently Mon Oct 26, 2026 17:45
 Post subject: USB480-Player
PostPosted: Wed Nov 05, 2008 17:34
Hello
Here is my Player now in Fullcolor.
Have Fun. ;)
Download here
PostPosted: Thu Nov 06, 2008 13:00
Happy to see this transformation to color for the player :)
PostPosted: Thu Nov 27, 2008 22:57
Here is a Version to control the Player over Touchscreen.
Download here
PostPosted: Thu Dec 04, 2008 11:12
"Screenshotfunktion" added and some little modifikations.
PostPosted: Fri Dec 05, 2008 10:49
Download here
While the output itself is quite nice the touch interface doesn't seen functional from here. Ie, there is no response from anywhere on the planel.
Nice effects :wink:
PostPosted: Fri Dec 05, 2008 12:46
Michael wrote:
Nice effects :wink:
Damn,the area was outside of the screen :D
Fixed and works again.
PostPosted: Fri Dec 05, 2008 13:50
Is now working.
Is this programmed for a stylus or finger touch? I'm finding the touch sensitivity of this program to be abit erratic with a stylus but more consistant with a finger.
PostPosted: Fri Dec 05, 2008 17:44
i use a Timer to get results from touchpanel
SetTimer_(WindowID(Window_0),3,600,@touchinfo())
this means ths touch works with "1.6 fps"
The 600 ms is experimental and maybe a little bit slow.
Here is the code to check the Buttonpanel
      If tpx>0 And tpy>0 And DisplayProperties\Width-tpx>xwin-50
        Select DisplayProperties\Height-tpy
          Case 10 To 50
            CallEventFunction(Window, Event, ButtonImage_0, Type)
          Case 60 To 100
            CallEventFunction(Window, Event, ButtonImage_1, Type)
          Case 110 To 150
            CallEventFunction(Window, Event, ButtonImage_2, Type)
          Case 160 To 200
            CallEventFunction(Window, Event, ButtonImage_3, Type)
          Case 210 To 250
            CallEventFunction(Window, Event, ButtonImage_4, Type)
        EndSelect
      EndIf
I make no distinction between pen and finger.
Edit
timer changed,its more "sensitive" now :D
PostPosted: Fri Dec 05, 2008 18:33
More eye candy :)
Making accurate touch interfaces should become easier with the upcoming new improved filtering and calibration.
PostPosted: Sat Dec 06, 2008 13:50
I have rewritten my touchcontrol as seperate Thread now.
The time between 2 USBD480_GetTouchPosition is now 100 ms,if the time is lower i get wrong results some times.
PostPosted: Sun Jan 11, 2009 0:32
The audio playback when using this is very scratchy....am I the only one with this problem?
PostPosted: Mon Jan 12, 2009 13:37
I haven't noticed but I'll try listening more carefully next time. Have you tried adjusting the volume and other settings?
PostPosted: Mon Jan 12, 2009 21:18
Download here
Archive is is updatet,newest fmodex-version and some modifikations
Check your Hardware and Driver.
I use onbord Soundmax HD and no Problems here.
