It is currently Tue Oct 06, 2026 14:10
PostPosted: Fri Jun 19, 2009 19:57
I was wondering if anyone knew what type of LCD is used in the GP2X F200 handheld device? I took it apart and there are no serial numbers or anything else to identify it with, I will upload a screenshot later on, need to wait for my cellphone battery to recharge before i can do that however.
Any help would be appreciated as I would like to avoid buying an LCD for a project I am going to start working on if I can somehow manage to get this one working.
Thanks.
Edit:
ok, so after a bit more searching and what not, I found out it is a Top-Sun TS35ND2501 3.5 Inch LCD. I will continue searching to see if I can find any documents on it or anything, has anyone had any experience with this lcd?
edit 2: I found a document for it that explains the pin out and everything, should have done more searching before i posted this, but I would still be interested in finding out if anyone has had any experience with this LCD and any success in using it.
PostPosted: Tue Jun 23, 2009 10:24
According to the datasheet I found here:
http://www.fancyview.com/product/tft-lc ... 060321.pdf
that looks like pretty standard digital input TFT panel.
A display like this usually needs a relatively powerful LCD controller to drive it. So depending of the other parts in your project you might find it easy or then more challenging to drive the display.
Users browsing this forum: No registered users and 125 guests
