It is currently Mon Aug 24, 2026 20:19
Post new topic Reply to topic  [ 74 posts ]  Go to page Previous  1, 2, 3, 4, 5
PostPosted: Tue Oct 06, 2009 16:53
Do you mind trying this: http://mylcd.sourceforge.net/files/touch.rar
This is my touch tester for the display, but importantly it will provide some debug information.
PostPosted: Thu Oct 08, 2009 23:04
Hello Michael
Here is the testresult
PostPosted: Fri Oct 09, 2009 12:21
Hello Sylvio,
It seems that you're still using the older firmware version. Perhaps I've mistakenly assumed 0x700 is the latest for everyone. It's probably best to contact Henri.
PostPosted: Sat Oct 10, 2009 16:23
Hi Michael
It's true that the very latest firmware version haven't been actively distributed yet. But as it has some good improvements I think it is time to get it into wider use. No point not taking advantage of the improvements in new software development. Like for example the increased raw data transfer rate that can be over 70% more than before and the improved display update protocol that can reduce the transferred amount of data to a fraction of what it was before.
Anyone who wishes to update to the latest firmware just send me an email and we'll get you updated. Before releasing this as a public downloadable update package I want to work to improve the update tool to make some checks to determine what is the correct way to update for that unit. As I know there are still some units out there that haven't been updated to the new improved bootloader/firmware system that was introduced around last May so those units need a slightly different update procedure.
PostPosted: Thu Jun 24, 2010 22:41
Updated VLCStream to support VLC 1.1
Changes'n'fixes:
Intrinsic skin support. Now comes with four completed skin sets. .psd source files are also included.
Config screen.
Auto and manual aspect ratio selection.
Various Visualization modes.
Mouse input control.
Subtitle selection.
DVD playback with chapter selection.
.. other stuff..
(bin 4.3MB) http://mylcd.sourceforge.net/files/vlcstream070.7z
(src 180K) http://mylcd.sourceforge.net/files/vlcstream070-src.7z
VLCStream supports the USBD480 in composite mode only.
PostPosted: Mon Aug 23, 2010 16:31
Hi Michael
I see I never replied here. It's great to see updates to these. I have been playing with the new version and I have liked it. Still need to give it another try to test more of the features.
PostPosted: Fri Oct 29, 2010 12:38
Henri wrote:
Hi Michael
Hi Henri,
That previous version actually had a bug (flaky fps) when used with WinXp/Vista/Win7, but went unnoticed as I use Win2k where it was fine.
PostPosted: Fri Oct 29, 2010 13:01
Updated VLCStream
Changes'n'fixes:
New FlatPlain skin.
New meta data and artwork screen. This allows viewing whatever id3tags are contained within the file.
Overhauled the playlist screen. Among other things it's is now possible to 'flick' through the playlist for easier access.
..other stuff.
(bin 1.9MB) http://mylcd.sourceforge.net/files/vlcstream072.7z
(src 2.9MB) http://mylcd.sourceforge.net/files/vlcstream072-src.7z
(src includes the photoshop .psd files)
- Files are currently offline. Will repost shortly.
PostPosted: Wed Nov 10, 2010 12:36
Small update to VLCStream:
Fixed the meta tag issue and updated the Playlist layout (artwork is now scrollable along with the track titles).
(bin 1.9MB) http://mylcd.sourceforge.net/files/vlcstream073-bin.7z
(src 2.9MB) http://mylcd.sourceforge.net/files/vlcstream073-src.7z
New playlist layout:
PostPosted: Fri Feb 25, 2011 4:54
Everything works, except for the touchscreen. I can't seem to figure out the problem. I am using the LIBUSB-win32 drivers as of yesturday. I found the "touch.rar" and executed it but is gave a an error of "USBD480 HID interface not found", any ideas?
PostPosted: Thu Mar 03, 2011 0:11
I use the USBD480 through libusb0 and HID via the composite interface, ie; your USBD480 must be preconfigured in composite mode. The appls also expect firmware version 0x700.
Updated touch and backlight adjuster: http://mylcd.sourceforge.net/files/touch.zip
PostPosted: Sat Mar 05, 2011 4:09
So, how do I exactly change the LCD to composite mode? I am very new to this and a bit confused too...
PostPosted: Sun Mar 06, 2011 23:42
You'll need to contact Henri for that.
PostPosted: Mon Aug 01, 2011 19:19
I've updated VLCStream once more, with many new features including a new playlist and playlist manager (multiple playlists), new UI, an internal command prompt for total control, along with lots of other stuff. ...and there are also a few easter eggs, too.
grab it here: http://sourceforge.net/projects/mylcd/f ... r/download
