It is currently Thu Oct 29, 2026 7:31
Post new topic Reply to topic  [ 163 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7, 8 ... 11  Next
PostPosted: Sun Feb 23, 2003 14:08
Ok, now i have a BMP in TXT file with hexadecimal values.
But now, what i want, is to DISPLAY to LCD this TXT File, what do you do this ? What do you do to DISPLAY Hexadecimal values in the LCD !?¿?!¿?!¿?
PostPosted: Sun Feb 23, 2003 17:00
Are anyone here ¿?¿? :roll: :roll: :roll: :roll:
I need your help please. :wink:
PostPosted: Mon Feb 24, 2003 15:45
Is it just me or wasn't here more posts yesterday ?
edit:
Just noticed that Emil has deleted all his posts in this thread. So I guess there's no need to retrieve the missing posts from backups :wink:
PostPosted: Tue Feb 25, 2003 0:06
Buff, there are something that don't run ...
When I clear the LCD, or when I draw bitmaps, there are some pixels that doesn't paint. It's like the functions doesn't be good, or something else, but i'm cracking up !
I want if someone has or had the same problem and have solutiones, how can solve this !!??
Thanks.
PostPosted: Tue Feb 25, 2003 0:15
Are you using busy flag checking ? Or maybe you could try a delay instead of that.
PostPosted: Tue Feb 25, 2003 0:18
I use the functions that you posted here, i think that doesn't use any delay.
Example:
Public Sub ClearLCDGraph()
        Dim shtCont As Short
        WriteData(G_BASE And &HFF)
        WriteData(RShiftLong(G_BASE, 8))
        WriteCtrl(&H24) 'address pointer to G_BASE
        For shtCont = 1 To NUM_PIXELS
            WriteData(0)
            WriteCtrl(&HC0) 'write data and inc ptr
        Next
    End Sub
Other example:
    Public Sub sbrDrawLCDHex(ByVal pvstrPoints() As String)
        Dim shtAdreça As Short
        Dim shtcont As Short
        shtAdreça = G_BASE '+ (0 * BYTES_PER_ROW) + (0 / 6)
        WriteData(shtAdreça And &HFF)
        WriteData(RShiftLong(shtAdreça, 8))
        WriteCtrl(&H24)
        For shtcont = 1 To UBound(pvstrPoints)
            WriteData(CInt("&H" & pvstrPoints(shtcont)))
            WriteCtrl(&HC0)
        Next
    End Sub
PostPosted: Tue Feb 25, 2003 7:31
Hi
Cancel
Greetings Emil
PostPosted: Tue Feb 25, 2003 9:17
The delay and busy flag checking, if used, are in the WriteData() and WriteCommand() functions. Have a look at the first C code I posted to this thread.
PostPosted: Tue Feb 25, 2003 13:12
Hi! The WaitDisplay Function in WriteData and in WriteCommand, i decided not to use it, because doesn't seem to be run with my LCD, it writes worst, and i have the same problem of non drawing pixels (a few).
I think it's problem of adresses, but i'm losted.
PostPosted: Tue Feb 25, 2003 14:04
I can't write SetLCDPixel in two first and two last columm.. and WaitDisplay Function don't work.. result only big negative number, it's loop always.. And PictureBox.Point(x.y) always result maxium long value..
Only WriteLCDText work good..
Sorry bad english text..
Rengas joka ei vedä, se jarruttaa - Nissan Sunny 1.6 SLX 4x4
PostPosted: Tue Feb 25, 2003 14:25
The waitdisplay function run properly, with the setpixel there are pixels that doesn't show, but i dont know why ...
PostPosted: Tue Feb 25, 2003 20:05
You could try putting a delay in place of the WaitDisplayReady().
PostPosted: Tue Feb 25, 2003 20:36
The waitDisplay function don't make a delay ¿? I think tht this don't seem to be a delay problem, because all are drawn except a few bits. -_-'
I'm being crazy, whats possible that there are pixels that don't draw !!! :? :? :? :? :? . And when i'm trying to display a whole image in Hexadecimal values, it seems that divide the lcd display in two.
Example:
This is the LCD
|·····cccccc···········ccc|
This is the BMP
ccccccc
ccccccc
ccccccc
It's like divide the display, i don't understand anything :evil: :evil:
I hope you understand the draw.
PostPosted: Tue Feb 25, 2003 23:37
How many bits are you trying to write in one byte ? If you have your display set for 6x8 font you need to send 6 bits in one byte.
PostPosted: Tue Feb 25, 2003 23:55
I'm putting 8 bits, but you're right, the font is set to 6x8.
This will be that I've to put only 6 bits, right ?
But then, how i can do this ¿? If I have "FF" value this can't be represented only with 6 bits !!??
Thank you
