It is currently Sat Oct 31, 2026 10:53
Post new topic Reply to topic  [ 163 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7, 8, 9 ... 11  Next
PostPosted: Wed Feb 26, 2003 1:09
Hi Marc
Public Sub sbrDrawLCDHex(ByVal pvstrPoints() As String)
Array string must be ByRef
Greetings Emil
PostPosted: Wed Feb 26, 2003 1:46
No because i don't write the results in this matrix.
PostPosted: Wed Feb 26, 2003 13:37
Marc wrote:
But then, how i can do this ¿? If I have "FF" value this can't be represented only with 6 bits !!??
Currently you have your array size at 3840 (128*30) ? Now you need to make array that is 128*40 = 5120 and then save only 6 bits per byte.
I guess you are currently reading 8 bits one by one from the bitmap and then saving the byte to the array ? Now you need to read only 6 bits at a time and leave the 2 bits empty. I hope I've understood right how you are doing it now.
PostPosted: Wed Feb 26, 2003 14:31
Exactly, now i have a 3840 (128 * 30) array. Ok i will try with the 5120 bytes array, with 6 bits, per byte. Later i will comment the result.
PostPosted: Wed Feb 26, 2003 23:27
Well, Henri, with an array of 5120, my display it's equal than with the 3840 array, 8O 8O 8O 8O 8O .
Well, I create a matrix of 5120 with a BMP, with the FAST LCD Designer (first i convert it to a file of hexadecimal values, and then i fill the matrix).
With the matrix that i have created, I use this function to fill the LCD:
        Dim shtAdreça As Short
        Dim shtcont As Short
        shtAdreça = G_BASE '+ (0 * BYTES_PER_ROW) + (0 / 6)
        WriteData(shtAdreça And &HFF)
        WriteData(RShiftLong(shtAdreça, 8))
        WriteCtrl(&H24)
        For shtcont = 1 To UBound(pvstrPoints)
            'WriteData(CInt("&H" & pvstrPoints(shtcont)))
            WriteData(CInt(pvstrPoints(shtcont)))
            WriteCtrl(&HC0)
        Next
    End Sub
Do you know where is the problem ¿?
PostPosted: Thu Feb 27, 2003 13:23
Does the Fast LCD Designer save the data in 6 bits per byte format ?
PostPosted: Thu Feb 27, 2003 15:20
When you save the bitmap in a BAS archive, you can put 6x8 or 8x8.
I supose that if i put 6x8, the lcd designer will save the file with 6 bits, is it ¿?
Well, we supose that the file is in 6 bits per Byte. My display doesn't work properly too... :? :? :? :? I'm so desanimated ! ...
PostPosted: Thu Feb 27, 2003 21:40
Did you save it as "Image" or "Image array" in the Fast LCD Designer ? I just did some testing and first tried to save as array but got some strange results. Then I saved as 6 bit Image and the file looked like it could be ok.
PostPosted: Thu Feb 27, 2003 22:04
Yes, I save the file like Image, and with a 6X8, and the result is the same. Two posts ago i put the code that i use to display the bimpat, could be the problem there ¿?
It's very frustating ! 8O 8O 8O 8O
PostPosted: Thu Feb 27, 2003 22:11
I had a look at the code but didn't notice anything special. But as I know nothing about VB I might not even notice if there was some problem.
PostPosted: Thu Feb 27, 2003 23:19
Hi Marc
I have written a new routine for Drawing Bitmap please check it..
It's work for me whit no problem
(Ok it's for SED1330)
Cancel
It's recoment you set the Picture.Scalemode=3
I use it with fellow comand
LCD1330.DrawGraph Picture2, 0, 0, 240, 128
LCD1330 is the Name of my Class "ignore it"
Greetings Emil :)
PostPosted: Thu Feb 27, 2003 23:34
Thanks for the function, I will try it :D :D :D :D
PostPosted: Thu Feb 27, 2003 23:58
HI Marc
It's High recoment you set the Background from the picturebox to *** white ***
otherwise you get pixel error in indicate!!!!!
Greetings Emil
PostPosted: Mon Mar 03, 2003 19:04
Hi Marc
Work your projekt now?
i have found a Problem in my routine
Greetings Emil
PostPosted: Tue Mar 04, 2003 2:00
No I can't tried your function.
What function don't run ?
bye
Users browsing this forum: No registered users and 53 guests
