It is currently Tue Sep 15, 2026 13:25
PostPosted: Sat Feb 01, 2003 22:29
http://www.skippari.net/lcd/sekalaista/vfdani.zip
Here's a little prog to show animations on the Noritake VFD. I've no idea how the timings will work for others as I've only been playing with my display for couple hours but I'm interested to hear about your results.
It's a command line tool and you give it the name of the animation definition file as parameter. The zip has one called ani.txt included.
Here's example of the definition file:
100
First row is how many times you want to repeat the animation, second is the pause between frames in milliseconds and rest is the animation frames. The frame bitmaps have to be 128x64 1bit to work.
The prog needs the WinIO driver to access parallel port but if you have administrator rights it will autoload the driver.
EDIT:
Optional brightness setting included.
 Post subject: The Animation prog
PostPosted: Sat Feb 01, 2003 22:50
Well, I tried the animation prog... And it worked as listed... but when I tried to make a change in the configuration, (To the 5 or the 25) with a text editor (on ani.txt) it gave me the exception kinda errors...
Looks nice, just wondering if the configuration requires a different type of text editor... I was just using edit from the command line, Didn't try winVI or anything yet...
PostPosted: Sat Feb 01, 2003 22:54
Well, I decided to edit in Notepad instead, and it worked... Must be extra spaces or something screws it up, and were added by edit...
Works great now.
PostPosted: Sat Feb 01, 2003 23:49
I updated the program with a check that tries to prevent this problem.
PostPosted: Mon Feb 03, 2003 22:13
Version for FLECOM's wiring:
http://www.skippari.net/lcd/sekalaista/ ... flecom.zip
PostPosted: Mon Feb 24, 2003 22:35
Robert sent me this animation today: http://www.skippari.net/lcd/sekalaista/THX_Movie.zip
PostPosted: Mon Feb 24, 2003 23:16
Well , coool movie , can you make one of these players for the Normal LCD owners :D (i'm have a such imagination :D)
Samtech
XP 2000+
A7N8X Dlx
256 Mb DDR PC3200 OCZ
GF 4 Ti 4200 128 DDR
180 Gb
Studio PCTV Pro
PostPosted: Tue Feb 25, 2003 0:10
How about this KS0108 version ?
http://www.skippari.net/lcd/sekalaista/ ... mation.zip
PostPosted: Tue Feb 25, 2003 4:16
Whata can i realy say about this ???
Well to be honest your are spoiling us with this :wink:
BEAUTIFUL !!!!!!
Simply great !!!
And the Blinkenlights player is also great !!!
Realy a Job weel done 8)
Keep up the Excelent Work.
Samtech
XP 2000+
A7N8X Dlx
180 Gb
Studio PCTV Pro
 Post subject: Ohhh.... I Like!!!
PostPosted: Sat Mar 15, 2003 9:38
One quick question, can you give command line for brightness, I run mine around 40%~70% (Day/night) and I have smoked plexi in front for filter, so at 6% I don't see much.
Thank you sooo much for such a kewl little tool!!!
PostPosted: Sun Mar 16, 2003 11:11
Brightness setting included now.
 Post subject: W00T W00T!!!
PostPosted: Mon Mar 17, 2003 2:03
Thank you :D :D :D
Works super!
PostPosted: Mon Mar 17, 2003 10:07
Good to hear that you like it :D
Users browsing this forum: No registered users and 546 guests
