It is currently Thu Oct 29, 2026 5:53
PostPosted: Sun Mar 23, 2003 14:49
i started to build an lcd by using this (http://www.moddingtech.de/content.php?c ... &page=glcd) tutorial.
the wiring should be correct and exact.
now to my problem:
the lines 3 to 6 are shown in black.
line1 displays the content of line1, line3 and line5 at the same time.
line2 displays the contect of line2, line4 and line6 also at the same time.
(noticed by passing the test from your program with '#')
line7 + 8 are working correct
could it be damaged or caused by a software mistake ?
PostPosted: Sun Mar 23, 2003 16:23
Do you have your parallel port mode set to ECP/EPP ? Usually that gives the best results.
Some kind wiring problem (noise/interference) might be possible also. This could cause problems with timing.
New LCD modules are very seldom broken but of course something may happen while handling the module but my guess would be that your lcd module is fine and the problem is somewhere else.
PostPosted: Sun Mar 23, 2003 18:29
how can i change my paralell port to ECP/EPP , i found nothing so far
PostPosted: Mon Mar 24, 2003 0:47
The parallel port mode settings can usually be found in the BIOS.
