It is currently Thu Jul 23, 2026 1:22
Post new topic Reply to topic  [ 41 posts ]  Go to page 1, 2, 3  Next
 Post subject: USB LCD in progress
PostPosted: Thu May 01, 2003 15:51
Few days ago I finally decided to put my FT245BM chip in use. I soldered small wires to all 32 pins of the chip so I could use it without a PCB and to my surprise windows recognised the chip when I plugged it in the USB port.
If someone else if planning to build something similar and you don't have a PCB I recommend everyone buying one of the small evaluation modules rather than doing it the way I did. Although the result was better than I expected I wouldn't like to do that soldering job again. ;)
Other parts I'm currently using are PIC16F877 and 240x64 T6963C display.
I wrote some simple code to the PIC and made a test program to windows. In my first tests writing a full screen bitmap took 118 ms so I think the speed is ok for the first test. I'm currently running the PIC at 10 MHz and I'm planning to bump the speed to 20 MHz to see if it makes any good. Something I was very impressed with was the fact that I didn't see any cpu usage increase when I wrote full screen bitmaps in loop to the lcd.
These were just the first results I got so it will be interesting to see if there's going to be any improvement later.
I could also try this with AVR but I just happened to have the PIC already connected to the LCD so I chose it for the first tests.
PostPosted: Fri May 02, 2003 13:38
8) Pictures 8)
 Post subject: Why FT245?
PostPosted: Sun May 04, 2003 1:49
Why FT245 instead normal USB interface? At this moment I'm working on 16F877 and PTDUSBD12 combo. Datasheet looks very promising.
BTW, my older USB interface with Motorola MC68HC908JB8 and SED1520 based LCD works fine, simple, and slow (~250ms for 122x32) on 3MHz chip. http://listener.pisem.net/03%20USB-LCD.jpg
P.S. Sorry for my english
PostPosted: Sun May 04, 2003 10:43
the ftdi is a usb interface :). Its near the same like the philips. And why dont use hardware available instead of buying new :D
PostPosted: Sun May 04, 2003 13:12
Pictures might be coming later if I get access to equipment to take them.
I chose FT245BM because it looked like a good chip with good drivers to me. And I already had one FT245BM waiting. ;) What I've seen so far has been very positive.
I'm not familiar with the Philips chip but I think it's a good choice also.
 Post subject: and another solution ;)
PostPosted: Wed May 21, 2003 20:19
an2135 1 Mb/s :)
yes Henri it works
PostPosted: Sat May 31, 2003 11:01
can you post the shematic?
PostPosted: Sun Jun 01, 2003 0:03
If you mean schematics for my version, I don't yet have any schematics done but I was going to make a version using a pcb and for that I'm going to draw some schematics.
PostPosted: Sun Jun 01, 2003 22:47
PostPosted: Sun Jun 01, 2003 23:18
ok thx
und das programm?!?!
PostPosted: Mon Jun 02, 2003 8:51
Anonymous wrote:
ok thx
which programm ?
at first i have to start with the programming :D
and than i thought to do a lcdinfo driver :!:
PostPosted: Mon Jun 02, 2003 13:18
ok, when do you think that the first beta version(s) release?
PostPosted: Mon Jun 02, 2003 16:57
*g* no comment ... you better ask henri when he will be finished :D
PostPosted: Thu Jun 19, 2003 15:14
Has anybody considered trying one of the PICs that has USB communication built in, or is that not any good for this job?
 Post subject: Posibility ?
PostPosted: Thu Jun 19, 2003 18:33
There are any possibility to connect a T6963C int the USB port ?
Greetings
Users browsing this forum: No registered users and 68 guests
