It is currently Tue Nov 03, 2026 3:33
PostPosted: Sat Sep 27, 2003 23:45
it would be great to select screen paused from the ini file. For exampe:
[Screen3]
Enable=1
Interval=5000
Graphic2=text(25,70,1,$time$)
Graphic1=text(32,0,2,$weekday$)
Graphic3=text(50,35,2,$date$)
screen=paused
so i would be able to go through screen 1 and 2 with intervall and then
stay at screen 3 until i give CTRL-X Command for next screen!
What do you think about this Idea??
PostPosted: Tue Sep 30, 2003 17:58
Not a bad idea. Things will be somewhat different in the new LCDInfo but it shouldn't be a problem to add this into it.
PostPosted: Wed Oct 01, 2003 2:19
Thank's,
and I'll hope you do.
How long will it take for a new relase of LCDInfo?
Or is it possible to get a beta version with the pause feature in?
If so, please mail to Imco@gmx.de
Last but not least, let me say thank you for your great Job and all
the Support and the time you spent for all the Users around the world!!
THANKS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
PostPosted: Sat Oct 04, 2003 11:39
I won't give any release times now. I've tried that in past but usually that just has not worked out.
Also at the moment there's no beta version that would fit to your needs.
Glad to hear that I've been able to help. :)
PostPosted: Sun Dec 05, 2004 4:20
Henri, has that pause feature been added to build 18?
PostPosted: Sun Dec 05, 2004 17:25
Well basically you can make the screen rotation stop in some screen by just not adding the screen change action to the screen. But this also means that you'll then be stuck to that screen as there are no keyboard shortcuts to move manually.
