It is currently Fri Oct 30, 2026 9:56
Post new topic Reply to topic  [ 163 posts ]  Go to page Previous  1 ... 6, 7, 8, 9, 10, 11  Next
PostPosted: Wed Aug 13, 2003 1:22
finally got it 8)
thanks for all the help :)
i used the first code not the one of lcd info and it worked
PostPosted: Thu Aug 21, 2003 17:45
hmm i have a question
i want winamp3 info on my lcd is that possible without a winamp plugin ?
did some research and winamp3 api is gone because they rewrote the entire code normally it should be back in some version but when that will be released... :wink:
i think it is possible but it will be to hard to do
i already got msn 6.0 info on my lcd :o
PostPosted: Fri Aug 22, 2003 11:57
I don't know other ways than a plugin for winamp3 to get the information. For winamp2 you can get some information without a plugin but I don't remember anything like this for wa3.
Good :)
PostPosted: Thu Sep 04, 2003 6:10
Hi
Check this
http://dschi-el-zeh.de/Dateien/Wa2xSendMsg.rar
and this
http://dschi-el-zeh.de/Dateien/Controll%20Winamp3.rar
extract Wa2xSendMsg to winamp3/Wacs and run Controll Winamp3 test the Plugin.
You can now work with the old winamp2x messagen.
Greetings Emil
PostPosted: Mon Sep 08, 2003 17:39
your second link doesn't work :(
PostPosted: Mon Sep 08, 2003 19:19
Hi
Go to my web scroll to down and load it from here.!
Greetings Emil
 Post subject: I'm going crazy ...
PostPosted: Mon Oct 20, 2003 23:44
I will try to explain my problem ... it's nefast because I try everything without any result ...
Let's go ...
My display is a T6963C with the PowerLCD wiring ... 240x128 (6x8 or 8x8). LCDInfo, PowerLCD, LiquidMP3 runs well in my LCD ... my problem starts when I try to program it by myself ...
I use all the code that it's in this thread of Visual Basic ...
The problem starts with the SetPixel function ... I do a loop of 0 to 239 to test if the x axis goes well, the result is this:
The loop is this:
0123-----7------456 and continues like this ... discontinued pixels :evil:
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
x ···@@@@·@@@···@@@@@@@@@@@@@@@@@@@@@@@@@@@x
x@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@x
The · are pixels, the @ are blank pixels ...
I hope somebody understand the picture, and can help me, to sovle the problem, cause im very desesperated ...
PostPosted: Fri Oct 24, 2003 22:58
The setpixel function doesn't work that well i have tried many things to get it to work but it doesn't seem to go correct
its a problem with the calculation of the positioning for the pixels i think
but you can always make a bmp file from 1 pixel and make a loop to draw the bmp in x axis and y axis on the screen.
the function to draw bmp's on LCD's is on this forum.
PostPosted: Sat Oct 25, 2003 11:48
With that functions can't be possible to display the pixels, but I have found the solution, thanks to Emil. :)
I have recoded a lot of functions. And know works :)
Now i can try the ideas that run on my mind, i will notice the results...
Thanks to all :D
PostPosted: Sat Oct 25, 2003 12:27
Hi
Have you found out what the problem with the functions was ? Personally I've used the C functions I posted in the beginning and haven't noticed any problems. But I haven't worked with VB, only C/C++.
But glad to hear that you have found a working solution. :)
PostPosted: Tue Oct 28, 2003 15:27
Heheh!
one problem you have!
Get and SetPixel is not a fast solution.
Only use GetDIBit ist a alternative.. verry fast for Animation.
Copy your Picture in the Memory and write it to your Display
with a Block of 6x8 or 8x8 Pixel.
Public Function IDriver_DisplayDrawGraphic(cntrl As Object, xoff As Long, yoff As Long, _
                                            ByVal FontWidth As Integer, ByVal FontHight As Integer, _
                                            ByVal Left As Long, ByVal Top As Long, _
                                            ByVal Width As Long, ByVal Hight As Long)
    Dim b8() As Byte
    Dim b6() As Byte
    Dim ret As Long
    Dim intAddr As Integer
    Dim X As Long
    Dim Y As Long
    Dim t As Single
    ret = GetByteArray(cntrl.hdc, cntrl.Image, 1, b8())
    ret = Convert8BitTo6Bit(b8(), b6(), DEFAULT_GRAPH_SPALTE)
    With DisplayConfig
    For Y = 0 To Hight - 1
        intAddr = .GraphHomeAddress + (((yoff + Y) + Top) * DEFAULT_GRAPH_SPALTE) + ((xoff / DEFAULT_BITS_PER_GRAPH_SPALTE) + Left)
        Call WriteData(intAddr And 255)
        Call WriteData(RShiftLong(intAddr, FontHight))
        Call WriteCtrl(CMD_SET_ADDRESS_POINTER)
        Call WriteCtrl(CMD_SET_DATA_AUTO_WRITE) 'auto write mode on
        For X = 0 To DEFAULT_GRAPH_SPALTE - 1
            WriteData b6(X, Y)
        Next X
        '//auto write mode off
        Call WriteCtrl(CMD_SET_DATA_AUTO_RESET)
    Next Y
    End With
End Function
Only this Function is hightech for LCDDrawing routine
I use not pixel to pixel (is to slow!!!)
Here is a Sample projekt
http://dschi-el-zeh.de/Dateien/Morphing.rar
NewMethode = 8 Frames per Sec = 2678,01 ms / GetDIBits
OldMethode = 4 Frames per Sec = 5675,65 ms / GetPixels
by loading 20x (240x128) Bitmaps with a loop for Morphing
always 50% Faster as Get/SetPixel
Greetings Emil
PostPosted: Wed Oct 29, 2003 12:08
Hello,
I'm trying to program my T6963C 240x128 LCD and tried some sample codes from this topic.
My problem is that with the DrawBMP function it takes more than 1 sec. to completely draw the image on my display.
With the Setpixel function my image is completely distorted, but it's much faster...
Any tips what I possibly can do ?
PostPosted: Wed Oct 29, 2003 14:37
Hi
Check my Sample
This sample Draw 8 Image with a resolution from 240x128 in 1 Sec..
Send me your source and i can help for you!
Only VB!
Greetings Emil
PostPosted: Wed Oct 29, 2003 22:18
Hello,
I've now written the following code, and it seems to work seemly well but I've only 1 little problem:
I have 5 pixels between each horizontal image-pixel of the original image.
So @@@ becomes @ @ @
Here's my code:
Public DisplayBMP(Picture as PictureBox, ByVal x as integer, Byval y as integer)
   Dim Adres as Integer
   Dim LCDwaarde as Long
   for i = 0 to picture.scaleheight
      Adres = G_BASE + ((y + i) * BYTES_PER_ROW) + (x / 6)
      WriteData (Adres and &HFF)
      WriteData (RShiftLong(Adres, 8))
      WriteCtrl (&H24)
      WriteCtrl (&HB0)
      for j = 0 to picture.scalewidth
         if picture.point(j,i) = 0 then
            WriteData(1)
         else 'Puntje = wit of andere kleur
            WriteData(0)
         end if
      next j
      WriteCtrl (&B2)
   next i
End Sub
I think I have to change something to the incrementing of my pointer or something like that...
PostPosted: Thu Oct 30, 2003 12:14
With this information, unfortunately, I cannot help you
