It is currently Sun Nov 01, 2026 9:30
Post new topic Reply to topic  [ 23 posts ]  Go to page 1, 2  Next
 Post subject: Windows Media Player
PostPosted: Thu Dec 04, 2003 10:58
WMP plugin: i'm working on it
may be done in one day or two...
PostPosted: Fri Dec 05, 2003 9:39
It's done
my ftp was done this night so i wasn't able to put it, but i sent it to Henri by mail.
I will try again to put it this afertnoon
now i'm going to work on the clock thing :)
PostPosted: Sat Dec 06, 2003 19:37
Yep, I have tested the plugin and it works very well. First I tried with WMP8 and it didn't work at all but then I upgraded to WMP9 and it started working immediately.
There's few little things to fix and then it would be good for use. As I have the source I could put it available here but it happened that I forgot to take backup of the SDK compatible with build 14 and now I have made changes to achieve better binary compatibility so I can't compile plugins for build 14. I'll try to be more careful when build 15 comes available.
PostPosted: Sat Dec 06, 2003 19:43
ok...
what should be fixed..
oh yes, the problem with the spectrum
will work on this when i will have time
PostPosted: Mon Dec 08, 2003 13:36
Just to make sure, I have to use WMP9? and do I need to install any plugin like with the winamp support?
I have the dll now and I want to start testing it :)
Rudi Grobler
PostPosted: Mon Dec 08, 2003 15:12
Yes, it looks like WMP9 is needed. You need some plugins for WMP too and if everything goes fine they'll be available later today as I don't have access to them at the moment.
PostPosted: Mon Dec 08, 2003 16:00
the dll should be available here:
http://www.ifrance.com/Dark-Elf/wmplcd.zip
beware... there is a bug in the lcdinfo dll, if you start lcdinfo (and you configured it to work with wmp) without starting wmp9, this will crash lcdinfo
you only have to open wmp once (you could close it after, it will work also)
i will correct this when i will be back at home, this is a few work...
PostPosted: Mon Dec 08, 2003 21:46
updated & problem solved
PostPosted: Thu Dec 18, 2003 23:28
Build 15 of LCDInfo now includes the updated dll for this plugin. For rest of the files and installation instructions you should look here: http://www.ifrance.com/Dark-Elf/wmplcd.zip
PostPosted: Thu Dec 18, 2003 23:32
PostPosted: Wed Dec 24, 2003 10:54
the mem eater bug is corrected ;) it will be in he next release and on my ftp certainly tonight
PostPosted: Fri Dec 26, 2003 1:00
ok uploaded, same place as usual ;):
PostPosted: Sun Feb 01, 2004 20:22
I try to use this plug in for LCDInfo, but I don't know which variables i have to use in the xml files... is there a list or something in which i can find them?
PostPosted: Mon Feb 02, 2004 8:24
Have a look at the log.txt file created when you run lcdinfo. It creates a list of all plugins and there variables
Rudi Grobler
PostPosted: Mon Feb 02, 2004 22:52
do you know read me???
there is also a list inside it!
