It is currently Sat Sep 19, 2026 10:30
Post new topic Reply to topic  [ 163 posts ]  Go to page Previous  1 ... 7, 8, 9, 10, 11  Next
PostPosted: Thu Oct 30, 2003 12:54
Hi Emil,
What information do you need ?
The current problem is that every pixel I write, takes about 6 pixels on the lcd. So it shifts 6 positions to the right in stead of 1...
PS: I also wanted to try your code with the hex-converted bmp's. But were can I find the code of these functions ?:
GetByteArray(cntrl.hdc, cntrl.Image, 1, b8())
Convert8BitTo6Bit(b8(), b6(), DEFAULT_GRAPH_SPALTE)
PostPosted: Thu Oct 30, 2003 14:11
Hi JohnVanBeton
I wouldn't like to publish this Function
You this Function sends me your source code and I build there one.
Greetings Emil
PostPosted: Thu Oct 30, 2003 18:19
Here's some C code for the 8 to 6 pixel conversion. Using this code I've been able to write full screen animations at speeds up to 30FPS in my tests.
The conversion is very simple so with some thinking it should be possible to convert to VB (and if someone converts it to VB I wouldn't mind if the converted code was posted here to help others ;) ).
void WriteBuffer(unsigned char *LcdData[])
   unsigned char byte1, byte2, byte3, lcdbyte1, lcdbyte2, lcdbyte3, lcdbyte4;
   int addr;
   if(font_width == 6)
      for(int y = 0 ; y < ypixels; y++)
         addr =  G_BASE + (y * BYTES_PER_ROW_GFX);
         WriteData(addr % 256);
         WriteData(addr >> 8);
         WriteCtrl(0x24);
         WriteCtrl(0xb0);
         for(int i=0;i<buffer_bytes_per_row;i+=3)
            byte1 = (*LcdData)[y*buffer_bytes_per_row+i];
            byte2 = (*LcdData)[y*buffer_bytes_per_row+i+1];
            byte3 = (*LcdData)[y*buffer_bytes_per_row+i+2];
            lcdbyte1 = (byte1 >> 2) & 0x3F;
            WriteData(lcdbyte1);
            lcdbyte2 = (((byte1 << 4) | ((byte2 >> 4) & 0xF)) & 0x3F);
            WriteData(lcdbyte2);
            lcdbyte3 = (((byte2 << 2) | ((byte3 >> 6) & 0x3)) & 0x3F);
            WriteData(lcdbyte3);
            lcdbyte4 = (byte3 & 0x3F);
            WriteData(lcdbyte4);
         WriteCtrl(0xb2);
   else if(font_width == 8)
   // following 8x8 font code haven't been tested yet
   // so expect some stupid mistake there
         WriteCtrl(0x24);
         WriteCtrl(0xb0);
         for(int i=0;i<buffer_bytes_per_row;i++)
            WriteData((*LcdData)[y*buffer_bytes_per_row+i]);
         WriteCtrl(0xb2);
PostPosted: Thu Oct 30, 2003 21:26
Hi Henri
With which processor (MHZ)
I have a AMD Athlon XP2000+ (1675 MHZ)
You loaded 30 Image with 1 Sec.????
( This is Realtime Movie)
I cannot believe this
Send me a simple Sample as EXE! I will check this.
Greetings Emil
PostPosted: Thu Oct 30, 2003 21:47
Hi
I have translate it (not self checked)
Option Explicit
Private OnBits(0 To 31) As Long
Public Sub WriteBuffer(LcdData() As Byte, font_width As Integer, ypixels As Long)
Dim byte1      As Byte
Dim byte2      As Byte
Dim byte3      As Byte
Dim lcdbyte1   As Byte
Dim lcdbyte2   As Byte
Dim lcdbyte3   As Byte
Dim lcdbyte4   As Byte
Dim addr       As Integer
Dim Y            As Integer
Dim I            As Integer
    If font_width = 6 Then
        For Y = 0 To ypixels
            addr = G_BASE + (Y * BYTES_PER_ROW_GFX)
            Call WriteData(addr And 256)
            Call WriteData(RShiftLong(addr, 8))
            Call WriteCtrl(&H24)
            Call WriteCtrl(176) 'auto write mode on
            For I = 0 To buffer_bytes_per_row + 3
                byte1 = LcdData(Y * buffer_bytes_per_row + I)
                byte2 = LcdData(Y * buffer_bytes_per_row + I + 1)
                byte3 = LcdData(Y * buffer_bytes_per_row + I + 2)
                lcdbyte1 = (RShiftLong(byte1, 2)) And &H3F
                Call WriteData(lcdbyte1)
                lcdbyte2 = (((LShiftLong(byte1, 4)) Or ((RShiftLong(byte2, 4)) And &HF)) And &H3F)
                Call WriteData(lcdbyte2)
                lcdbyte3 = (((LShiftLong(byte2, 2)) Or ((RShiftLong(byte3, 6)) And &H3)) & &H3F)
                Call WriteData(lcdbyte3)
                lcdbyte4 = (byte3 And &H3F)
                Call WriteData(lcdbyte4)
            Next I
            Call WriteCtrl(178)  'auto write mode off
        Next Y
    ElseIf font_width = 8 Then
        '// following 8x8 font code haven't been tested yet
        '// so expect some stupid mistake there
                Call WriteData((LcdData(Y * buffer_bytes_per_row + I)))
            Next I
        Next Y
    End If
End Sub
Public Function LShiftLong(ByVal Value As Long, _
                           ByVal Shift As Integer) As Long
        Call MakeOnBits
        If (Value And (2 ^ (31 - Shift))) Then GoTo OverFlow
        LShiftLong = ((Value And OnBits(31 - Shift)) * (2 ^ Shift))
        Exit Function
OverFlow:
        LShiftLong = ((Value And OnBits(31 - (Shift + 1))) * (2 ^ (Shift))) Or &H80000000
End Function
Public Function RShiftLong(ByVal Value As Long, _
        Dim hi As Long
        Call MakeOnBits
        If (Value And &H80000000) Then hi = &H40000000
        RShiftLong = (Value And &H7FFFFFFE) \ (2 ^ Shift)
        RShiftLong = (RShiftLong Or (hi \ (2 ^ (Shift - 1))))
End Function
Private Sub MakeOnBits()
        Dim j As Integer
        Dim v As Long
        For j = 0 To 30
            v = v + (2 ^ j)
            OnBits(j) = v
        Next j
        OnBits(j) = v + &H80000000
End Sub
Which data are submitted here 'LcdData()'
Which data are submitted here 'buffer_bytes_per_row'
Greetings Emil
PostPosted: Fri Oct 31, 2003 0:34
hi
PostPosted: Sat Nov 01, 2003 17:03
LcdData is an array that has the bitmap data.
buffer_bytes_per_row is the number of bytes per bitmap row
For example 240x128 bitmap:
buffer_bytes_per_row = 240/8 = 30
and LcdData is array of 30*128 bytes = 3840 bytes
I'll send you some sample exe to test but first I'll have to find the sources and test them with some T6963C display myself. I think the tests I mentioned were done in early January maybe and I should have the sources still somewhere. The processor used was 1200MHz Athlon.
It might have been that the 30fps was with 240x64 display so with 240x128 display it would be 15fps only. But in the next couple days you should be able to test it yourself when I have something to send you.
Which wiring are you using ?
PostPosted: Sun Nov 02, 2003 2:13
@Henri
Thanks for the answer.
My wiring is:
WR = 1
CE = 16
CD = 17
RD = 14
Greetings Emil
PostPosted: Fri Nov 28, 2003 19:17
Emil Weiss wrote:
Use this
Dim hi As Long
    MakeOnBits
End Function
Dim j As Integer, _
        v As Long
    For j = 0 To 30
        v = v + (2 ^ j)
        OnBits(j) = v
    Next j
End Sub
    MakeOnBits
    If (Value And (2 ^ (31 - Shift))) Then Exit Function
End Function
Greetings Emil
Hi Emil,
Can you please tell me how I have to declare "onbits" in VBNet 2002 because I still get an error on this one. I can't declare it global.
Greets
Suge
PostPosted: Fri Nov 28, 2003 20:04
hi
you must set "Private OnBits(0 To 31) As Long" as array
With VB6 'i use not vbnet 2002'
Greetings Emil
PostPosted: Sat Nov 29, 2003 0:39
[dutch mode] Hallo suge ik ben ook van belgie west vlaanderen :p
maar ga even in engels typen ;) [/dutch mode]
I have vb .net 2003 and you can use the >> and the << just like in C
don't know if they work for 2002 but i'm 99% sure
so for example:
This is in vb 6.0 and earlier:
This is for vb .net
Call WriteData(addr >> 8)
So:
RShiftLong = >>
LShiftLong = <<
(i don't write Call but you may if you want to :p)
I switched from vb 6.0 to vb .net a few months back and i must say i love it more then 6.0 ;)
Also a little note:
Don't use Integer i did it in the beginning and nothing worked i just changed everything that is Integer to Short and all works now.
PostPosted: Sat Nov 29, 2003 1:05
Hello again,
i have a question:
How can bitmap data be placed in an LcdData array ?
PostPosted: Sun Dec 07, 2003 1:12
somebody that can help ??
PostPosted: Thu Dec 11, 2003 9:42
You can just read the bitmap data from bmp file and put it in the LcdData array. There are BMP file specifications and file header information available somewhere in net. Then you can read from the header the picture dimensions and also the position at where the picture data itself starts in the file. Then just seek to the correct position and read the picture data to the array.
Something to remember is that every scanline in the bmp file is aligned at 4 bytes. Let's say you have a 100x100 picture. You need 13 bytes to represent one scanline data. But as every scanline is padded to 4 byte boundary there will be 3 extra empty bytes that you need to ignore. So the total length for the scanline data will be 16 bytes and after that the next scanline data begins.
PostPosted: Thu Jan 22, 2004 13:21
Hi
Can someone please help me with showing a bmp on my 240*128-lcd.
I'm using the following function to draw the bmp:
Public Function DisplayBMP(Picture As PictureBox, ByVal X As Integer, ByVal Y As Integer)
   Dim Adres As Integer
   Dim LCDwaarde As Long
   Dim I As Long
   Dim J As Long
   For I = 0 To 127
      Adres = G_BASE + ((Y + I) * BYTES_PER_ROW) + (X / 6)
      WriteData (Adres And &HFF)
      WriteData (RShiftLong(Adres, 8))
      WriteCtrl (&H24)
      WriteCtrl (&HB0)
      For J = 0 To 239
         If Picture.Point(J, I) = 0 Then
            WriteData (1)
         Else 'Puntje = wit of andere kleur
            WriteData (0)
         End If
      Next J
      WriteCtrl (&HC0)
   Next I
End Function
and I use the followint to call the function:
Call DisplayBMP(Picture1, 0, 0)
But I just can't let it work :?
Anyone an idea?
Suge
Users browsing this forum: No registered users and 518 guests
