It is currently Mon Nov 09, 2026 9:11
PostPosted: Tue Nov 12, 2002 20:34
This is a reply to this post:
http://gathering.tweakers.net/forum/lis ... 0#15942210
Remboooo wrote:
I downloaded the sourcecode, but the compiler complains about a missing includefile "vcl.h"...
What compiler are you using ?
PostPosted: Tue Nov 12, 2002 21:18
I'm using Visual C++.
I made a Win32 Application project and added all the source files (.cpp and .h), and pressed compile. That's when i got the error.
PostPosted: Tue Nov 12, 2002 21:37
Then it's no wonder that it gives the error message as LCDInfo is made with Borland C++Builder. So I don't think you can use Visual C++ to work with LCDInfo source but if needed I can make you a simple KS0108 test project for Visual C++.
PostPosted: Tue Nov 12, 2002 23:22
Ah that would be very nice :)
But don't let me be to much of a bother to you ;)
PostPosted: Wed Nov 13, 2002 16:22
That shouldn't be a problem as I already have some code. I just need to put it to a simple test app. It could for example write some text to the display.
Maybe I'll look at it tonight.
PostPosted: Wed Nov 13, 2002 20:14
Here's a quick KS0108 test for visual c++. It has two screens: first one uses two different fonts and the second one shows a bitmap.
http://www.skippari.net/lcd/sekalaista/ks0108test.zip
PostPosted: Wed Nov 13, 2002 23:03
Thank you so very much!!!!!!
I'm sure i can build something useful from this code :D
PostPosted: Fri Nov 15, 2002 0:59
It works , at least on the Data international Displays there isn´t any garbled display , at least till now :roll:
SAmtech
