It is currently Wed Nov 04, 2026 4:57
Forum locked This topic is locked, you cannot edit posts or make further replies.  [ 15 posts ]
 Post subject: VCL50.BPL missing
PostPosted: Wed Nov 06, 2002 15:32
computergeekguy wrote:
hey henri i trued to run LCD info on my win2k PC and it says that it needs a file "VCL50.BPL" what is this all about???
VCL50.BPL is a runtime library the program uses. You can download it here: http://www.skippari.net/lcd/Vcl50.zip (640KB)
I haven't included it in the lcdinfo zip because of the size and because many people already have it. You can extract the file to the lcdinfo directory or to windows/system.
PostPosted: Thu Nov 07, 2002 4:16
ok now i am getting a "Could not Acess driverLINUX driver" and "E AcessViolation" i downloaded the NT version because i have win2k. what am i doing wrong?
PostPosted: Thu Nov 07, 2002 13:19
Do you have the DriverLINX drivers installed ?
You can download the installation package (port95nt.exe) here:
http://www.skippari.net/lcd/port95nt.exe
PostPosted: Fri Nov 08, 2002 3:15
it still doesn't work. i downloaded and installed the software on the other end of your hyperlink, still nothing. i can open up the configuration window. do i need a LCD attached to run the software?
PostPosted: Fri Nov 08, 2002 9:54
Does it give any error messages ?
You should be able to run the software without display. Only situation where display would be needed is if you have selected busy flag checking for T6963C. In the configuration there's a selection for no display.
PostPosted: Sat Nov 09, 2002 2:51
nope just the same error messages that i recieved before. i don't get it.
PostPosted: Sat Nov 09, 2002 11:08
Are you using administrator rights while installing ? This could be one reason why in doesn't work.
It should also work without installing any drivers if you copy the DLPORTIO.SYS and DLPORTIO.DLL to the LCDInfo directory and use an account with administrator rights. This way LCDInfo loads the drivers on the fly but administrator rights are required for this.
Someone was having similar problems in the "DLPORTIO.SYS missing" thread and he had to edit registry by hand to make it work.
PostPosted: Sat Nov 09, 2002 23:56
Yap , that should be the problem , try to login as administrator , currently i'm using Win XP , and it Works great , just instaled de Driverlinx and tried it and it worked , if this doesn´t works you have to try to add them manualy has Henry said.
Good Luck :wink:
SAmtech
PostPosted: Wed Nov 13, 2002 9:06
i got LCD info to run and all but now my LCD displays Garbled messages. is this bad? i swear that i wired it correctly. is there a setting that i missed? i am really confused. :(
-Computergeekguy
PostPosted: Wed Nov 13, 2002 16:01
-Computergeekguy
I created a new thread for this one:
http://www.skippari.net/phpBB2/viewtopic.php?t=53
 Post subject: Re: VCL50.BPL missing
PostPosted: Sat Apr 05, 2003 21:24
I need vcl50.bpl. Thank's!
http://www.skippari.net/lcd/Vcl50.zip (640KB) DON'T RUN
PostPosted: Sat Apr 05, 2003 21:32
I was getting too much traffic on my site and I had to move some files:
http://www.lcdinfo.com/lcd/files/Vcl50.zip
 Post subject: vcl50.bpl
PostPosted: Wed Oct 22, 2003 15:06
:oops:
where do you download vcl50.bpl?
the site below do not work
PostPosted: Wed Oct 22, 2003 18:15
Here --> http://www.lcdinfo.com/lcd/files/Vcl50.zip
Bye !! :D
PostPosted: Thu Oct 23, 2003 15:11
:P
thanks ~```
