It is currently Sun Feb 15, 2026 19:00
PostPosted: Wed Feb 04, 2004 13:32
Is there anybody able to start LCDinfo and an other prog in a same time :?:
I'tried to make a batch file under w98 to start LCDinfo and MBM. This last one start well but LCDinfo make a :
LCDINFO a causé une défaillance de page dans
le module LCDINFO.EXE à 0167:0040238c.
Registres :
EAX=00000000 CS=0167 EIP=0040238c EFLGS=00010246
EBX=00000000 SS=016f ESP=0065fa48 EBP=00420878
ECX=0065fca4 DS=016f ESI=0065fa38 FS=5867
EDX=00000002 ES=016f EDI=00420190 GS=0000
Octets à CS : EIP :
8b 00 8b 70 14 8b 48 18 3b f1 74 18 56 8b cd e8
État de la pile :
bff552f6 780c26ce 00400000 00000000 7803b6d0 0065fb12 0065fa38 004209c8 00781fc0 00000003 00000000 00000000 00000000 0041b520 00000000 00000000
Any idea :P
PostPosted: Sun Feb 08, 2004 13:01
It might be because MBM plugin in LCDInfo tries to access MBM before it's fully initialized. Or it could be also something else. You should first start MBM and after some time after that LCDInfo. If MBM isn't started first then LCDInfo can't open the MBM shared memory to get the MBM values.
Maybe you could add some delay in the batch file between executing the programs ?
PostPosted: Mon Feb 09, 2004 15:41
I try to start only LCDinfo by the batch file but I have got the same error. It's like LCDinfo doesn't like to be started by batch file. Perhaps Dos code ? :cry:
PostPosted: Thu Feb 12, 2004 16:19
I tried starting LCDInfo from .bat file and it seems to run fine here. But I didn't test this in windows start, but only while windows was already running and made the .bat file, put lcdinfo there and double clicked the file.
Have you been trying this at windows start ?
PostPosted: Fri Apr 02, 2004 18:22
Computer drive me somtimes crazy ! :roll:
When I first post this question I'got an error at each time when I try to start togheter LCDinfo + MBM through my bat file.
So I left it. :cry:
Today I'try just for test my shortcut of my bat file and everithing goes well ! 8O
Sorry for this Henri :x
PostPosted: Fri Apr 02, 2004 18:42
try putting a delay in? so lcdinfo starts say 10 secs after everything else, as it has to be the last thing that starts.
PostPosted: Sat Apr 03, 2004 13:22
Yep It's what I did and it works now.
This is my lcdinfo.bat file
@echo off
REM START LCDINFO by siz
start "D:\Program Files\Motherboard Monitor 5\MBM5.exe"
choice /t:o,10>nul
start "C:\WINDOWS\Bureau\lcd_info Build 16\lcdinfo.exe"
exit
You can change the time that the batch have to wait in the choice unit :!:
Have fun :D
