It is currently Fri Oct 30, 2026 22:07
 Post subject: Noritake GU256x64-372
PostPosted: Wed Apr 07, 2004 15:54
Driver for GU256x64-372 VFD included in build17.
Driver has been reported to be also working with GU256x64-352 and GU256x64-340.
PostPosted: Sat Apr 17, 2004 22:57
Good job Henri, it's looking incredible. Takes some time to get used to XML way of editing screens :? .
At least i know there are most likely only 47 other people in this word that can enjoy LCDInfo on a 256x64 VFD :wink: .
Thxxxx!
PostPosted: Sat Apr 17, 2004 23:45
The driver takes slightly more cpu time than most others if there's a lot of things moving (= lots of data to write) because of the way the memory is arranged in the display. It might be possible to optimize it later.
PostPosted: Mon Apr 19, 2004 4:56
I noticed that this display seems to be using only 84x48 pixels of the display. Is this because of it being a very early beta, or am I doing something wrong. Also good job so far! :mrgreen:
PostPosted: Mon Apr 19, 2004 12:46
The default screen is 84x48 in size. You can have a look here for some instructions for modifying the screens to fit your needs: http://www.skippari.net/phpBB2/viewtopic.php?t=386
PostPosted: Mon Apr 19, 2004 13:36
yes i can confirm it works properly :wink: .
BTW may i ask where you got your 256x64-372 display from? Just curious...
PostPosted: Wed Jul 06, 2005 11:40
Works and looks great on my -355 .
Henry
Is there any way of being able to control the brightness of the vfd within info , a fade/pulse would be nice :D ?
