It is currently Tue Aug 25, 2026 13:39
Post new topic Reply to topic  [ 47 posts ]  Go to page 1, 2, 3, 4  Next
 Post subject: NEW DESIGNER !!
PostPosted: Mon Apr 12, 2004 21:22
1.1.2
icons now also appear on
http://www.hypertransport.de/designer/lcdinfoscreendesigner1.1.2.rar
(( not needed with build 18 of LCDInfo anymore )
works only with :
www.hypertransport.de/designer/lcdinfo.exe
and .NET 1.1
http://www.microsoft.com/downloads/deta ... layLang=en
Changelog:
1.1.2
- fixed bug: pluginimages disappeared after leave the dragarea ( thx for the report Vric )
1.1.1
- icons for plugins added
- icons also appear on loaded screens, so now you see where the vars come from
1.1
- Size of previewscreen now depends on configuration done in lcdinfo under driver
- loading of seperate screens is posibble
- added option to stop/restart lcdinfo..so its easier to review a saved screen on the lcd
- size of pluginimages is 1:1 + name
Fixes:
- removed saving bug
- removed display bug
- removed bug where the position and fieldsize were calculated wrong ( text disappears from preview )
- removed drag&drop bug ( draghandles still flashes for short time)
- performance on startup increased
- removed loading bug (specific screen) thx@henri
PostPosted: Mon Apr 12, 2004 22:28
Looks good :) Screen designer is something many have been waiting.
PostPosted: Tue Apr 20, 2004 0:00
a little update:
link: *removed*
PostPosted: Tue Apr 20, 2004 17:34
Wow that's one FAST PC you got there 8O . Looks good, can't wait till we get a chance at it :wink: .
/yes ICQ suxx
PostPosted: Fri Apr 23, 2004 7:34
why fast pc ?
yes q icq...but for some reason i use it :P
PostPosted: Sun Apr 25, 2004 22:11
new demonstration video : summary of some weekendwork
www.hypertransport.de/designer/animation.rar
PostPosted: Tue Apr 27, 2004 10:07
Looks better after every update :)
PostPosted: Tue Apr 27, 2004 10:32
Now that looks very sweet :D
*shrug* you wouldn't have time to make a version for LiQuiD-MP3 (with XML configs) would you.... *whistles innocently*
Creator of LiQuiD-MP3
PostPosted: Fri Apr 30, 2004 22:59
next update
please ignore some drawing bugs...removed right now :D
www.hypertransport.de/designer/someupdate.rar :oops:
PostPosted: Thu May 06, 2004 23:06
another update..this time a bit funny because i found a bug while capturing :D.. so you will se a crash at the end :roll:
The pluginvariables are loaded directly from lcdinfo...if you look close, there is also a bug :D
www.hypertransport.de/designer/demo+crash.rar
TODO:
save aniomation in own xml
load animations via drag&drop
PostPosted: Fri May 07, 2004 10:39
Relampago wrote:
why fast pc ?
Probably your capturing software, everything moves so damn fast 8O
Any chance of us having a go at your beta screen designer :wink:
PostPosted: Sat May 08, 2004 21:53
FIRST RELEASE: www.hypertransport.de/designer/Release.rar
You need the .NET Framework...this software is full C#
a demovideo is following later....
Some hints:
- copy both files in your directory where lcdinfo.exe is located
- drag and drop pluginvariables from the left tree to the screen
- drag&drop saved animations
- drag&drop bitmaps from your explorer
TODO:
-lcdinfo can not be run at same time
- with "load existing screens" you select your lcddirectory e.g. 320x240 or what ever
- only 320x240 lcds are supported, ok thats simple so for small lcds simply edit in the upperleft corner :D
- bug in treeview of lcdinfo vars
- you need a newer build of lcdinfo where a path bug is removed
- screen.xml editing issnt implemented
- pluginvars can only be setted one time on a screen
PostPosted: Sat May 08, 2004 22:08
Vielen dank Relampago, i'll have a go at it next week.
/P.S. see you June 15th Portugal :wink:
 Post subject: .NET 1.1 Framework
PostPosted: Mon May 10, 2004 9:16
Here the dld link for .NET 1.1
Please post every bug :roll:
 Post subject: new version .. have fun
PostPosted: Mon May 10, 2004 22:45
alpha 1.1
works only with :
Changelog:
Fixes:
