It is currently Tue May 26, 2020 22:16
 Post subject: next version
PostPosted: Wed May 12, 2004 22:42
new Version:
- added some icons
- removed unneeded controls (ok they were never seen :D )
-todo
- icons in left treeview, so you see where the variables are from ( maybe you cant read :) )
- sizes of plugin variables
PostPosted: Thu May 13, 2004 21:04
all new version now in first post 8O
PostPosted: Fri May 21, 2004 0:05
I don't know if I'm supose to write here but
I have a sugestion. Could it be possible to make a "Zoom" on the LCD Workspace ?
I mean, I work on a 128*64 LCD, and when configuring with the lcdinfoscreendesigner.exe, it's so small. Hard to work with.
Just a sugestion.
Also, is there a way to look for pop3 with the designer ?
PostPosted: Sat May 22, 2004 2:10
-oh yes zoom should be in the next version, if there is a next version :)
pop3 ? no.. the deisgner works offline to lcdinfo..so there is no "real" connection
PostPosted: Sat May 22, 2004 12:41
Hoi
Ich gehe mal davon aus, das du mich so verstehst, jedenfalls bekomme ich beim starten deines Programmes
Fehler in der Anwendung
Anwendung konnte nicht richtig initialisiert werden (0xc0000135. Klicken sie auf OK um die Anwendung zu schließen.
Liegts an mir oder an deinem Programm.
Ich benutze Windoof XP und SP2
Thx und MFG
C0R4X
PostPosted: Sat May 22, 2004 15:27
you need .NET 1.1 . Do you have that ?
PostPosted: Sat May 22, 2004 17:23
Öhm, noe...
Wo bekomm ich des?
C0R4X
ah, habs bei ms gefunden... ma schaun
C0R4X
PostPosted: Fri May 28, 2004 12:08
is someone working with it ?
- till now only zoom is requested 8O
:oops:
PostPosted: Sun May 30, 2004 2:28
Well I don't have my LCD yet, but testing this software. I have many time this error when the screen get loaded quite a bit (ex: putting 2 spectrum in winamp and text.
When I get this problem, one of the item desapear off the screen, when you select it on the list (at left) I get this error:
************** Exception Text **************
System.NullReferenceException: Object reference not set to an instance of an object.
at lcdinfoscreendesigner.PickBox.SelectControl(Object sender, EventArgs e)
at lcdinfoscreendesigner.Designer.pluginTree_AfterSelect(Object sender, TreeViewEventArgs e)
at System.Windows.Forms.TreeView.OnAfterSelect(TreeViewEventArgs e)
at System.Windows.Forms.TreeView.TvnSelected(NMTREEVIEW* nmtv)
at System.Windows.Forms.TreeView.WmNotify(Message& m)
at System.Windows.Forms.TreeView.WndProc(Message& m)
at System.Windows.Forms.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 1.0.5000.0
Win32 Version: 1.1.4322.573
CodeBase: file:///c:/windows/microsoft.net/framework/v1.1.4322/mscorlib.dll
System
CodeBase: file:///c:/windows/assembly/gac/system/1.0.5000.0__b77a5c561934e089/system.dll
System.Drawing
CodeBase: file:///c:/windows/assembly/gac/system.drawing/1.0.5000.0__b03f5f7f11d50a3a/system.drawing.dll
System.DirectoryServices
CodeBase: file:///c:/windows/assembly/gac/system.directoryservices/1.0.5000.0__b03f5f7f11d50a3a/system.directoryservices.dll
System.Messaging
CodeBase: file:///c:/windows/assembly/gac/system.messaging/1.0.5000.0__b03f5f7f11d50a3a/system.messaging.dll
System.ServiceProcess
CodeBase: file:///c:/windows/assembly/gac/system.serviceprocess/1.0.5000.0__b03f5f7f11d50a3a/system.serviceprocess.dll
System.Data
CodeBase: file:///c:/windows/assembly/gac/system.data/1.0.5000.0__b77a5c561934e089/system.data.dll
Assembly Version: 1.0.1594.30686
Win32 Version: 1.0.1594.30686
CodeBase: file:///D:/64128/lcdinfo_test/lcdinfoscreendesigner.exe
CodeBase: file:///c:/windows/assembly/gac/system.windows.forms/1.0.5000.0__b77a5c561934e089/system.windows.forms.dll
Accessibility
CodeBase: file:///c:/windows/assembly/gac/accessibility/1.0.5000.0__b03f5f7f11d50a3a/accessibility.dll
System.Xml
CodeBase: file:///c:/windows/assembly/gac/system.xml/1.0.5000.0__b77a5c561934e089/system.xml.dll
************** JIT Debugging **************
To enable just in time (JIT) debugging, the config file for this
application or machine (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the machine
rather than being handled by this dialog.
PostPosted: Mon May 31, 2004 16:41
cant reproduce...could you give me a step-by-step
PostPosted: Mon May 31, 2004 23:25
ok here is step by step
Create new screen, give name
Adding a Winamp Viz in bottom of the LCD
Adding a Secon viz right after the first one
adding some text Plugin (always Winamp)
one of the Viz will desapear and if I select it in the list, I get this error.
If you can't reproduce it, tell me which software you use for making video, I will make one
PostPosted: Mon May 31, 2004 23:47
Well I finally made a Video of it
you can find it here
PostPosted: Tue Jun 01, 2004 12:08
thx...fixed, redownload :)
PostPosted: Tue Jun 01, 2004 15:10
Working perfectly !
Only thing missing is a zoom area feature :lol:
