It is currently Thu Oct 01, 2026 13:49
PostPosted: Mon Jun 07, 2004 11:04
Hi;
I have a Sahrp LM64P728 640x480 Mono LCD panel. I was search pinout out diagram. I found Sharp LM64P728 pinout same Sharp LM64P722
I don't know how can I control and connect this LCD to my pc. in future I want to build own stand alone mp3 player and use this LCD. I need help to how can I control and connect this LCD to my pc.
Thank you for your help.
I have a little information about my LCD.
Pin No,Pin name/signal;
1 S (startup scan signal)
2 CP1 (input data latch signal)
3 CP2 (Data input latch signal)
4 Vdd (power suply for logic and LCD +5V)
5 Vss (GND)
6 Vee (~-16.2V)
7 Vss (GND)
8 DU0 (data Upper half area)
9 DU1
10 DU2
11 DU3
12 DL0 (data lower half area)
13 DL1
14 DL2
15 DL3
Screen area;
____________________
|1,1.....................1,640|
|....Upper half area...... |
|240,1..............240,640
|241,1 ..............41,640|
|....Lower half area.......|
|480,1..............480,640|
I apology to my bad English.
Humax 5400 Z
PostPosted: Wed Jun 09, 2004 15:51
It isn't possible to directly interface this kind panel to parallel port. You need somekind controller in between. And even then I don't know how useful this big lcd is combined with the limited datathroughput of parallel port.
Also SED1335 for example can't drive this big display but you would need some other controller from the SED series for example. These controllers also are using full address bus interface so it causes some extra work if wanted to use with LPT.
PostPosted: Mon Jun 14, 2004 16:17
Humax 5400 Z
PostPosted: Mon Jun 14, 2004 16:31
But I'm not saying it wouldn't be possible to use this display. How much experience do you have in electronics ?
I have a similar Sharp display myself that I've been planning to try driving with a selfmade controller.
PostPosted: Tue Jun 15, 2004 15:46
Since 1990. but I can't work on digital electronic or PC electronic. I'm work only industrial electronic. Now I want to make home made stand alone mp3 player to use PIC 16F877L, VSI1001 Mp3 decoder chip with Graphic LCD. I have 4 different LCD module.
1. LPH7585-2 (have controller) from Siemens gigaset 2000. I don't know how made. No any info
2. come from Siemens gigaset 3000. SAMSUNG made LCD have built in controller but I don't know part number and pin out.
3. HD44780 based 2x16 charecter LCD
4. Sahrp LM64P728 640x480 Mono LCD panel.
I made a info display to my PC. I use HD44780 based 2x16 charecter LCD on PC LPT1 port. But I don't like charecter LCD. I want to use Sharp LCD but, in my country hard to find help how can I use the controller chip and how can I find. if I found right controller chip I will made self made controller.
I'm search any info abut Sahrp LM64P728 640x480 Mono LCD on internet. If I can't find info I buy this LCD : (cheap then the ot thers and paralel interface)
Crystalfontz CFAG160160B-YYH-VU
Built-in LC7981 Controller & 4KByte SRAM 160x160 graphic mode --or-- 27 x 20 text mode using built-in 5x7 Character Generator ROM.
http://www.crystalfontz.com/products/160160b/index.html
http://www.crystalfontz.com/products/16 ... BYYHVU.pdf
Humax 5400 Z
PostPosted: Tue Jun 15, 2004 18:57
I found a little info about controller;
this company http://www.rtdusa.com/PC104/UM/video/cm110.htm use Chips and Technologies 65545 VGA controller to drive sharp mono LCD
this is datasheet Chips and Technologies 65545 VGA controller(adobe pdf format) http://www.intel.com/design/graphics/mo ... 170002.pdf
Humax 5400 Z
PostPosted: Wed Jun 16, 2004 21:09
Also epson has some controllers that might be more appropriate for a microcontroller:
http://www.epson-electronics.de/cgi-bin ... yOid=-8467
PostPosted: Sun Jun 20, 2004 15:08
Okay;
I'm stop to interest Sahrp LM64P728 640x480 Mono LCD panel. May be in future. Now I'm buy a 160x160 Graphic LCD Module made from Crystalfontz. Detail is here ---> http://www.crystalfontz.com/products/160160b/index.html
Have Built-in LC7981 controller.
This is my Mp3 project Diagram
Humax 5400 Z
PostPosted: Tue Jun 22, 2004 12:31
That is probably a wise solution considering your mp3 project. You don't want to spend too much time and energy for the display alone.
PostPosted: Tue Mar 13, 2007 1:55
Hi
I have the same LCD panel laying around with witch i want to build my own text-laptop. laptop to write only text. and i want to use this son of a bit** :D i would really appreciate if someone could give me some idea what kind of circuits or bits and pecies i have to look for. (controllers, clock generators, etc)
sorry for my bad english
thnx in advance
Users browsing this forum: No registered users and 136 guests
