It is currently Tue Jun 09, 2026 23:04
PostPosted: Wed Jun 30, 2004 23:20
I'm wire what Henri said on his site in T6963-schematic, but I don'tsee anywhere on my lcd .... Anybody help !!!
My LCD had build-on negative invertor (-16V)
PostPosted: Sat Jul 03, 2004 3:09
Is that your LCD ?
http://www.mostron.de/pdfs/pdfgraphic/WG240128A.PDF
PostPosted: Mon Jul 05, 2004 11:22
So you got all dark display or nothing at all ?
Maybe if you presented all your connections here we could check if there was anything that might be wrong.
PostPosted: Mon Jul 05, 2004 15:35
AmigaMentor
Yes it is !!!
Henri
nothing at all :( :( :(
I'm check my connctions, but it don't wrong ....
LPT LCD
1 5(WR)
2 11(DB0)
3 12(DB1)
4 13(DB2)
5 14(DB3)
6 15(DB4)
7 16(DB5)
8 17(DB6)
9 18(DB7)
14 7(C\E)
16 8(C\D)
17 6(RD)
+5V 3(Vdd),19(FS),10(RESET)
GND 2(GND)
--------- 9(Vee)
10K <------4(Vo)
-------- GND
PostPosted: Wed Jul 07, 2004 12:20
If you can't even adjust contrast you might not have enough contrast voltage. You could try connecting the other end of the contrast potentiometer to +5V instead of GND.
How about the REVERSE pin ? Try connecting it to +5V or GND.
PostPosted: Thu Jul 08, 2004 11:51
Now I can adjust contast !!! I'm connect 20pin(REVERSE) to +5V and it work !!! But I'm see garbage on my screen ( i mean my LCD connecting wrong ? )
maybe connect LCD like this :
LPT -> LCD
1-----7(C\E)
2-----11(DB0)
3-----12(DB1)
4-----13(DB2)
5-----14(DB3)
6-----15(DB4)
7-----16(DB5)
8-----17(DB6)
9-----18(DB7)
14-----6(RD)
16-----5(WR)
17-----8(C\D)
+5V------3(Vdd),10(RESET),19(FS),20(REVERSE)
GND-----2(GND),1(FG)
PostPosted: Fri Jul 09, 2004 13:33
Henri
I do it !!!! All works !!!!
I'm check my connections and find bad contact between LCD - LPT !!!
P.S. I can post you my shematic to wire my LCD ( and photo too ).
