It is currently Thu Sep 10, 2026 18:26
PostPosted: Tue Jul 13, 2004 12:20
I connected an nokia 3310 lcd to my lpt port using this howto
It worked great with LCDinfo but now I'm trying to write my own code. But I don't seem to get it working. I think my problems is in the initialization part.
I hope one of you guy's can find my fault.
here's my code is delphi:
procedure PortOut(Port : Word; Data : Byte); stdcall; external 'io.dll';
function PortIn(Port:Word):Byte; stdcall; external 'io.dll';
function writeport(dc:integer;db:integer):integer;
var
databyte:integer;
begin
        databyte:=32+4+2*db+16 ;
        PortOut(888,databyte);
        //sleep(10);
        PortOut(888,databyte+1);
        //sleep(10);
       // sleep(10);
end;
function dataport(dc:integer;db7:integer;db6:integer;db5:integer;db4:integer;db3:integer;db2:integer;db1:integer;db0:integer):integer;
begin
    writeport(dc,db7);
    writeport(dc,db6);
    writeport(dc,db5);
    writeport(dc,db4);
    writeport(dc,db3);
    writeport(dc,db2);
    writeport(dc,db1);
    writeport(dc,db0);
end;
procedure TForm1.Button1Click(Sender: TObject);
begin
    PortOut(888,63);
    sleep(20);
    PortOut(888,59);
    sleep(250);
    PortOut(888,63);
    sleep(20);
    PortOut (888,54);
    sleep(10);
    dataport(0,0,0,1,0,0,0,0,1);
    dataport(0,1,0,0,1,0,0,0,0);
    dataport(0,0,0,1,0,0,0,0,0);
    dataport(0,0,0,0,0,1,1,0,0);
    dataport(1,0,0,0,1,1,1,1,1);
    PortOut(888,56);
end;
procedure TForm1.Button3Click(Sender: TObject);
begin
       PortOut (888,00);
end;
procedure TForm1.Button2Click(Sender: TObject);
begin
end;
end.
[/code]
PostPosted: Tue Jul 13, 2004 22:18
Delphi isn't my strongest point but I have seen some code in web for this. I haven't tested it myself though or know what wiring it expects or checked how close the initialization is to my LCDInfo driver but it should give some ideas and hints for you.
I think it's originally from this site: http://rifer.narod.ru
unit controller;
interface
uses
  SysUtils;
const ID = 'Nokia 3210/3310 (Philips PCD8544)'; //ID sets the description of the dll
      MAX_RESPIXELS = 4032;
type TCharData = record
                  position : byte;
                  data : array[0..7,0..7] of byte;
                 end;
     TDLLInfo = record
                 IDArray : array[0..255] of byte;
                 SupportGfxLCD : Boolean;
                 SupportTxtLCD : Boolean;
                 SupportSlider : Boolean;
                 CCharWidth : Byte;
                 CCharHeight : Byte;
                 FontPitch : Byte;
                end;
     TSymbolInfo = record
                    SymbolData : array[0..19] of boolean;
                   end;
     TArrayType = array[0..MAX_RESPIXELS-1] of byte;
var
  Ports: INTEGER;
//Sends Data to the Controller Chip
procedure LCD_SendToController(Value : Byte); stdcall;
//Sends Data to the integrated LCD Memory
//on adress specified by LCD_SetOutputAdress
procedure LCD_SendToMemory(Value : Byte); stdcall;
//Sends Data to LCD Gfx Memory
procedure LCD_SendToGfxMemory(Pixels : TArrayType; X1,Y1,X2,Y2 : Word; inverted : boolean); stdcall;
//Sets the LCD RAM Adress for Outputs
procedure LCD_SetOutputAddress(x,y : Longword); stdcall;
//Sets a LCD Custom Char specified in cdata
procedure LCD_SetCGRAMChar(cdata : TCharData); stdcall;
//Returns the Custom Char bytecode for the current display
//Based on the HD44780 eg. the input for the first Custom Char
//is position=0 and the return value is the equivalent bytecode
//to the HD44780 Custom Char bytecode
function LCD_GetCGRAMChar(position : Byte) : Byte; stdcall;
//Initialize the LCD
procedure LCD_Init; stdcall;
//Called when DLL released
procedure LCD_CleanUp; stdcall;
//Sets the Port Adress where the LCD are connected and
//the lcd execution time for processing sended data
procedure LCD_SetIOPropertys(Port : pchar;
                             Exectime : Longword;
                             ExectimeGfx : Longword;
                             X,Y : longword;
                             GX,GY : Longword;
                             LightOn : Boolean;
                             SliderValue : Byte;
                             UnderlineMode : Boolean;
                             UnderlineOutput : Boolean); stdcall;
//This is a routine for customizing output,
//by default only used by m50530 symbol lcd
procedure LCD_Customize(SymData : TSymbolInfo); stdcall;
//Caller of this function gets some info about the DLL
function DLL_GetInfo : TDLLInfo; stdcall;
//Signals if the write sequence to LCD is ended or not
function LCD_IsReadyToReceive : boolean; stdcall;
//Imported DLL Routine from DriverLinx PortIO DLL Driver
function DlPortReadPortUchar(Port:longint):byte;stdcall;external 'DLPORTIO.DLL';
procedure DlPortWritePortUchar(Port:longint;Value:byte);stdcall;external 'DLPORTIO.DLL';
implementation
procedure Command (Value: Byte);
var i : Byte;
begin
DlPortWritePortUchar(Ports-2 , 254);
For i := 7 downto 0 do
if (Value And Round(exp(i*ln(2))))>0 then
  begin
//   DlPortWritePortUchar($37A , 0) ;
   DlPortWritePortUchar(Ports , 2) ;
   DlPortWritePortUchar(Ports , 0) ;
  end
else
  begin
//   DlPortWritePortUchar($37A , 1);
   DlPortWritePortUchar(Ports , 3) ;
   DlPortWritePortUchar(Ports , 1) ;
  end;
end;
procedure Data (Value: Byte);
var i : Byte;
begin
DlPortWritePortUchar(Ports-2 , 255);
  begin
  end
else
  begin
  end;
end;
//a small routine for generating very short delays
procedure Wait(x : longword);
var c : longword;
begin
     for c:=0 to x do  ;
      DlPortReadPortUchar($220); //read = 1 microsecond delay
end;
                             Exectime : longword;
                             X,Y : Longword;
                             GX,GY : Longword;
                             LightOn : Boolean;
                             SliderValue : Byte;
begin
Ports:=StrToInt('$'+Port)+2;
DlPortWritePortUchar(Ports-2,255)
//if LightOn then DlPortWritePortUchar(Ports-2,255)
//  else DlPortWritePortUchar( Ports-2,31) ;
end;
var c : integer; x : TDLLInfo;
begin
     //copy lcd driver name to structure
     for c:=0 to 255 do x.IDArray[c] := 0;
     for c:=1 to length(ID) do begin
      x.IDArray[c-1] := ord(ID[c]);
     end;
     x.SupportGfxLCD := true; //do we support gfx output?
     x.SupportTxtLCD := false;  //do we support txt output?
     x.SupportSlider := false; //do we support the slider in lcdhype output?
     x.CCharWidth := 0; //max custom char width in pixels
     x.CCharHeight := 0; //max custom char height in pixels
     x.FontPitch := 6; //fontpitch of lcd
     result := x;
end;
begin
result:=true;
end;
begin
end;
var
  j ,i , z , Bitmap: byte;
begin
Command ($40)   ;
Command ($80)   ;
j:=0 ;
while j<47 do
 begin
   for i := 0 to 83 do
     begin
      Bitmap := 0;
      for z:=0 to 7 do
       if Pixels[i+ (z*84)+(j*84)]>0 then Bitmap :=Bitmap + Round(exp(z*ln(2))) ;
       data (Bitmap);
     end;
   j:=j+8 ;
  end;
end;
begin
end;
begin
end;
begin
end;
begin result := position;
end;
procedure LCD_Init;
var
i : integer ;
begin
Command ($21) ;
Command ($b7) ;   //  VOLTAGE  $80-&FF  (äîáàâèòü íàñòîðîéêó)
Command ($6)  ;   //  TEMP
Command ($13) ;   //  BIAS
Command ($20) ;
Command ($9)   ;
Command ($8)   ;
Command ($C)   ;
Command ($40)   ;
Command ($80)   ;
Command ($C)    ;
For i := 0 To 504 do data (0) ;   //clear lcd
end;
begin
DlPortWritePortUchar(Ports-2 , 0);  //lcd off
end;
begin
end;
end.
PostPosted: Wed Jul 14, 2004 13:17
Thank you very much Henri!
I found the bug.. I forgot to make the dc pin dependent of the kind of byte I wanted to send.
If I come up with some nice features (for LCDinfo) I will let you know.
Users browsing this forum: No registered users and 180 guests
