It is currently Wed Aug 19, 2026 0:20
Post new topic Reply to topic  [ 174 posts ]  Go to page Previous  1 ... 6, 7, 8, 9, 10, 11, 12  Next
PostPosted: Thu Jul 29, 2004 7:53
As far as i know, you'll need to rescue one from an old nokia; the page here shows how: [url]serdisplib.sourceforge.net/ser/pcd8544.html[/url]
:D
PostPosted: Thu Jul 29, 2004 15:10
The link doesn’t work :cry:
PostPosted: Thu Jul 29, 2004 20:44
Hayden wrote:
Where can I get the driver chip for the 3310 screen in Australia e.g. (jaycar or dickmiths) etc. etc
I have looked everywhere in my town
You mean the level converter IC 74LCX245/74LVC245 here ? The lcd driver/controller (PCD8544) is integrated to the display glass and the 74LCX245/74LVC245 is just used for converting the 5v parallel port signal levels to 3.3v for the PCD8544.
I know some have used it even without any level converters but I haven't tested it myself so I don't know how well that works.
PostPosted: Fri Jul 30, 2004 1:36
What about using a regulator or resistor to drop the voltage instead of the 74LCX245/74LVC245 chip?
PostPosted: Fri Jul 30, 2004 7:48
The link works fine, copy and paste it. :D
PostPosted: Fri Jul 30, 2004 10:32
Hi! i'm new user. I made interface for my nokia 3210 display with the
schematics with resistors, and for sure i can say it doesn't work :? .
I used multimeter to measure values when LCDinfo is started, and i get voltage to high. 4,28 V. So i can say that i will try to make some conversion circuit with trasistor if i couldn't find 74LCX245 in my elec. store.
BTW. for the Henri:
i have old ericsson phone AH-320 and from it display: LPH3789
6 pin LCD
Could u have maybe pin info?
PostPosted: Sat Jul 31, 2004 16:05
Sorry the link does work I just put www. In front that’s why :wink:
PostPosted: Sat Sep 11, 2004 9:21
does anybody had connected nokia 3310 lcd vith rezistors? does it work?
PostPosted: Fri Sep 17, 2004 1:48
An alternative to resistors is diodes. The voltage drop across a resistor depends on what is at the other end, the current, etc. The voltage drop a diode is generally fixed at around 1 volt regardless of those things. So try using two diodes in series to drop from 5v to 3v.
PostPosted: Sun Sep 19, 2004 0:43
To be honest normal silicon diode drops voltage by 0.7 volt. If you have 2diodes it means 1,4 volt and it not determined by current (in normal conditions).
PostPosted: Sun Sep 19, 2004 22:34
I donwloaded lcdinfo_test.zip but I don't know what to do next. There is no readme in the archive. I am wanting to drive the PCD8544 from a DOS Basic (Power Basic) program and/or from a picaxe (www.picaxe.co.uk) so I need to see the actual code that drives it, not just DLL's.
PostPosted: Fri Sep 24, 2004 15:24
hello, i have connected nokia 3310 lcd
using schematic from
http://users.skynet.be/fa358153/david/t ... /index.htm
i think everything should be ok, but my display doesn normaly work
i dont know were is the problem, maybe the capacitors are wrong?
i have used capacitors without marked + and - ( i dont know how in english " ne elektrolitinis")
how many volts does it should have?
when i touch VOUT pin , lcd generates noise.
does anybody have similar problem like i have? can anybody help me?
p.s i have used Bzx85 3v9 diodes(not bzx85 3v3) maybe this is problem?
why these diodes are for?
(sorry of my bad english :oops: )[/img]
PostPosted: Mon Sep 27, 2004 9:13
I'm pretty sure there is some code posted or at least a link to some example code in the Development forum. You can try searching there.
PostPosted: Mon Sep 27, 2004 9:18
I'm not familiar with this connection method personally but the capacitors voltage rating should be probably 10V at least.
The diodes are to lower the voltage from parallel port (+5v) to lower levels that should be better for the display. 3.9v diodes should work just fine I believe.
PostPosted: Tue Sep 28, 2004 11:42
i connected a variable resistor for Vin, and i can adjust contrast with it.
