It is currently Tue Nov 10, 2026 3:40
Post new topic Reply to topic  [ 70 posts ]  Go to page 1, 2, 3, 4, 5  Next
PostPosted: Sun Aug 08, 2004 0:18
I have read about the great work on interfacing the Nokia Color lcd's. I havn't the manufactor that was recomended to proceed with my experiments on this lcd.
I'm still trying to get a lcd to work with a PIC micro and the SonyEricsson T68 display is one that a have a couple of and it has nice pads to solder on.
I know that I have seen the Pinout somewhere but can't find it right now. If you have it, please post it for me.
All information on manufactors and communication specifications you might have would be great!
Best regards
Mippen
PostPosted: Sun Aug 08, 2004 14:37
Best regards
Mippen
See link http://sandiding.tripod.com/lcdt68.html
---=[ Junior ]=---
www.lcdmania.net
PostPosted: Sun Aug 08, 2004 15:26
Thanks!
Great info.
pin1 Vlogic ( 2.8 - 3.2 V)
pin2 Gnd
pin3 _Reset ( active and for iic interface)
pin4 Sdata
pin5 Sclck
pin6 +Led1
pin7 Gnd (leds)
pin8 +Led2
I2c address:0x72 Only write mode
Resolution: 101x80 RGB
Is there a "standard" on what commands that is used on I2C?
I guess that one needs some kind of communication specification to be able to get any information on the LCD?
PostPosted: Mon Aug 09, 2004 3:29
I found this information for T68 LCD.
IC Controller: UPD161401
Liquid Crystal Display (LCD)Controller/Driver IC
Vendor: NEC
Number of Characters 101 x 80 pixels (256 colors)
Logic Voltage (V)/ Drive Voltage (V) 1.8 to 3.6/ 18
I not found data-sheet for NEC UDP161401
---=[ Junior ]=---
www.lcdmania.net
PostPosted: Mon Aug 09, 2004 9:29
@lcdmania:
where have you found this information? (i'm searching for voltage info and pinout for ericsson r520)
@mippen:
yes, but the i2c-protocl only standardises the way of how commands and data is exchanged between i2c-devices.
for the commands you need a datasheet. without you're lost (or you may try sniffing the i2c-communication. there're some programs and tutorials floating around the net).
but if you'll find the datasheet for 'nec udp...' it's very ease to drive an i2c-display
greetings
/mrwastl
edit: incorrect end-tag, typo
PostPosted: Mon Aug 09, 2004 18:43
All I have found on the NEC LCD Driver uPD161401 is the following:
Full-dot driver
101x80 dots output
1.8 to 3.6 Logic voltage, 18v drive voltage(???)
Seems that there is some other models in the same family, maybe the same communication protocol on these? If one could find it?
uDP161401 (101x80 dots)
uDP16686 (128x128 dots)
uDP16687 (128x128 dots)
PostPosted: Mon Aug 09, 2004 22:04
@mippen
i have the opposite problem: i know the controller, but i don't know pinouts and voltages :-(
maybe you know something about this (or you have found something about) for ericsson r520.
PostPosted: Mon Aug 09, 2004 22:23
@mippen
good news for you, i've found the document you're searching for, but i don't want to direct-link it (dunno if nec would be happy about that). so here's a 'how to':
go there:
http://www.necel.com/en/search/index.html
at 'Document Search' field 'Product Name' enter:
*161401
and press enter.
(the * at the beginning is necessary!)
the document you need will be loaded by acroread ;-)
and also bad news:
are you sure that this is the right controller?
udp161401 has two parallel, one serial, but no i2c transfer mode. either berty's pinout is wrong, or t68 doesn't use this controller or i overlooked something
PostPosted: Tue Aug 10, 2004 12:15
mrwastl wrote:
@mippen
go there:
*161401
and press enter.
and also bad news:
i2c is serial mode.
---=[ Junior ]=---
www.lcdmania.net
PostPosted: Tue Aug 10, 2004 12:22
mrwastl wrote:
@lcdmania:
@mippen:
greetings
/mrwastl
I found this information in:
http://www.mcu.cz/modules/news/article.php?storyid=368
---=[ Junior ]=---
www.lcdmania.net
PostPosted: Tue Aug 10, 2004 13:45
@lcdmania
i2c is serial mode.
i2c is a serial protocol. but if you would have read the datasheet you would have seen that the controller does not support i2c but a proprietary serial communication protocol (look at figure 5-1) - some protocol similar to those protocols used by certain nokia-displays (and certain other ones) using serial communication.
i programmed a library with support for such displays: http://serdisplib.sourceforge.net (there's also support for ericsson t2x displays: these are i2c-displays ..)
so there's either a i2c-chip BEFORE this nec-controller or the search has to continue ;-)
greetings
/mrwastl
PostPosted: Fri Aug 27, 2004 18:48
I spend like 2 weeks getting info in the T68i's , and im 99% sure there are 3 versions of that disp.
Version 1: name=S-4595;type=01;address=72
Version 2: name=HD66760;type=02;address=74
Version 3: name=S-43200A;type=03;.address=70
The ones i have ansvers on I2C addr 70 , so i Suppose its a S43200A , and i can find NOTHING on that one or the S-4695 (well i got one hit on a S-4595b i think)
I have the Hitachi manual , but no Hitachi LCD :evil:
Im 95% sure the S-controllers are Seiko OEM controllers ......
Here are some hits ...
The 2 first made by my selve
http://www.eio.com/public/lcd/1309.html
http://www.eio.com/public/lcd/1313.html
Another one
http://www.esato.com/archive/t.php/t-14585
My assumptions are based on the firmware dump of the T68i and the section that contains this...
I'm sorry the paste is a bit of a mess , but its a hex dump with the Ascii part at the end of each line.
/Bingo
004FEBDB 5332 844D 0000 7665 7273 696F 6E3D 3230 3031 3039 3131 303B 696E
7465 7266 6163 653D 6932 S2.M..version=200109110;interface=i2
004FEBFF 6331 3B7B 6E61 6D65 3D53 2D34 3539 353B 7479 7065 3D30 313B 6164
6472 6573 733D 3732 3B72 c1;{name=S-4595;type=01;address=72;r
004FEC23 6573 6F6C 7574 696F 6E3D 3635 2035 303B 636F 6C6F 7572 733D 3038
2030 3320 3033 2030 323B esolution=65 50;colours=08 03 03 02;
004FEC47 6F66 6673 6574 3D31 4220 3030 3B6F 6666 7365 745F 7064 3D31 4220
A653 3284 4D00 8030 303B offset=1B 00;offset_pd=1B .S2.M..00;
004FEC6B 7064 5F72 6563 7461 6E67 6C65 3D30 3320 3030 3030 2030 3030 3420
3030 3635 2030 3031 4320 pd_rectangle=03 0000 0004 0065 001C
004FEC8F 3030 3030 2030 3031 4320 3030 3635 2030 3033 3420 3030 3030 2030
3033 3420 3030 3635 2030 0000 001C 0065 0034 0000 0034 0065 0
004FECB3 3034 433B 706E 705F 6465 7465 6374 3D25 6120 3030 2030 303B 696E
6974 3D25 6120 3033 2030 04C;pnp_detect=%a 00 00;init=%a 03 0
004FECD7 3120 3032 2030 3020 3030 2034 3620 3031 2012 5332 844D 0100 3030
2030 3620 3031 2030 3720 1 02 00 00 46 01 .S2.M..00 06 01 07
004FECFB 3142 2030 3820 3746 2030 3920 3030 2030 4120 3446 2030 4520 3446
2030 4620 3130 2031 3020 1B 08 7F 09 00 0A 4F 0E 4F 0F 10 10
004FED1F 3032 2031 3120 3137 2031 3220 3235 2031 3320 3031 2031 3520 3030
2031 3620 3143 2031 3720 02 11 17 12 25 13 01 15 00 16 1C 17
004FED43 3030 2031 3820 3030 2031 3920 3030 2031 4120 3030 2031 4220 3530
2031 4320 3530 2031 4420 00 18 00 19 00 1A 00 1B 50 1C 50 1D
004FED67 3236 2031 4520 3236 3753 3284 4D01 8020 3146 2030 3020 3230 2030
3020 3334 2032 3720 3335 26 1E 267S2.M.. 1F 00 20 00 34 27 35
004FED8B 2037 3320 3336 2030 3420 3337 2033 3120 3338 2030 3620 3339 2032
4320 3341 2032 3420 3430 73 36 04 37 31 38 06 39 2C 3A 24 40
004FEDAF 2030 3820 3431 2030 3020 3432 2030 3720 3433 2030 3820 3434 2030
3920 3435 2030 4120 3436 08 41 00 42 07 43 08 44 09 45 0A 46
004FEDD3 2030 4220 3437 2030 4420 3438 2031 3020 3439 2030 3020 3441 2030
3520 3442 2030 3720 34D3 0B 47 0D 48 10 49 00 4A 05 4B 07 4.
004FEDF7 5332 844D 0200 4320 3038 2034 4420 3039 2034 4520 3041 2034 4620
3043 2035 3020 3130 2035 S2.M..C 08 4D 09 4E 0A 4F 0C 50 10 5
004FEE1B 3120 3030 2035 3220 3037 2035 3320 3039 2035 3420 3130 2035 3520
3030 2035 3620 3036 2035 1 00 52 07 53 09 54 10 55 00 56 06 5
004FEE3F 3720 3037 2035 3820 3038 2035 3920 3039 2035 4120 3041 2035 4220
3042 2035 4320 3130 2035 7 07 58 08 59 09 5A 0A 5B 0B 5C 10 5
004FEE63 4420 3030 2035 4520 3036 2035 4620 3037 2036 3020 3038 2036 3120
E153 3284 4D02 8030 3920 D 00 5E 06 5F 07 60 08 61 .S2.M..09
004FEE87 3632 2030 4120 3633 2030 4220 3634 2031 3020 3635 2030 3020 3636
2030 3720 3637 2030 3920 62 0A 63 0B 64 10 65 00 66 07 67 09
004FEEAB 3638 2031 3020 3738 2030 3120 3030 2034 3220 3034 2031 4220 3035
2030 3020 2577 3131 383B 68 10 78 01 00 42 04 1B 05 00 %w118;
004FEECF 7265 696E 6974 3D3B 7265 696E 6974 5F70 643D 3B70 6F77 6572 5F6F
6E3D 2561 2033 3820 3032 reinit=;reinit_pd=;power_on=%a 38 02
004FEEF3 2030 3020 3532 3B70 6F77 6572 5F6F 6666 3D46 5332 844D 0300 2561
2030 3020 3432 2033 3820 00 52;power_off=FS2.M..%a 00 42 38
004FEF17 3041 2033 3920 3030 2025 7737 3820 2561 2030 3020 3436 2025 7731
3743 3B6E 6F72 6D61 6C5F 0A 39 00 %w78 %a 00 46 %w17C;normal_
004FEF3B 7064 3D25 6120 3030 2034 3220 3338 2030 4120 3031 2030 3820 3136
2025 7064 5F73 7461 7274 pd=%a 00 42 38 0A 01 08 16 %pd_start
004FEF5F 726F 7720 2577 3332 2025 6120 3338 2030 3620 2577 3936 3B70 645F
6E6F 726D 616C 3D25 6120 row %w32 %a 38 06 %w96;pd_normal=%a
004FEF83 3030 2034 3220 3338 7D53 3284 4D03 8020 3041 2030 3120 3030 2025
7743 383B 7365 745F 7363 00 42 38}S2.M.. 0A 01 00 %wC8;set_sc
004FEFA7 616E 726F 775F 706F 733D 2561 2030 3420 2578 2030 3520 2579 3B73
6361 6E72 6F77 3D25 6120 anrow_pos=%a 04 %x 05 %y;scanrow=%a
004FEFCB 3843 3B73 6574 5F76 6C63 643D 2561 2033 3920 2576 6C63 643B 7365
745F 766C 6364 5F70 643D 8C;set_vlcd=%a 39 %vlcd;set_vlcd_pd=
004FEFEF 2561 2033 4120 2576 6C63 645F 7064 3B7D 7B6E 616D 653D 4844 3636
3736 303B 7479 7065 3D8B %a 3A %vlcd_pd;}{name=HD66760;type=.
004FF013 5332 844D 0400 3032 3B61 6464 7265 7373 3D37 3420 3736 3B72 6573
6F6C 7574 696F 6E3D 3638 S2.M..02;address=74 76;resolution=68
004FF037 2035 303B 636F 6C6F 7572 733D 3038 2030 3320 3033 2030 323B 6F66
6673 6574 3D30 3020 3030 50;colours=08 03 03 02;offset=00 00
004FF05B 3B6F 6666 7365 745F 7064 3D30 3020 3030 3B70 645F 7265 6374 616E
676C 653D 3033 2030 3030 ;offset_pd=00 00;pd_rectangle=03 000
004FF07F 3020 3030 3034 2030 3036 3520 3030 3143 2030 3030 3020 3030 3143
1953 3284 4D04 8020 3030 0 0004 0065 001C 0000 001C.S2.M.. 00
004FF0A3 3635 2030 3033 3420 3030 3030 2030 3033 3420 3030 3635 2030 3034
433B 706E 705F 6465 7465 65 0034 0000 0034 0065 004C;pnp_dete
004FF0C7 6374 3D25 6120 3030 2030 303B 696E 6974 3D25 6120 3030 2030 3320
2561 3120 3141 2033 3420 ct=%a 00 00;init=%a 00 03 %a1 1A 34
004FF0EB 2577 3936 2025 6120 3030 2030 3120 2561 3120 3032 2030 3920 2561
2030 3020 3032 2025 6131 %w96 %a 00 01 %a1 02 09 %a 00 02 %a1
004FF10F 2030 3020 3436 2025 6120 3030 2030 3420 253A 5332 844D 0500 6131
2030 3520 3445 2025 6120 00 46 %a 00 04 %:S2.M..a1 05 4E %a
004FF133 3030 2031 3420 2561 3120 3446 2030 303B 7265 696E 6974 3D3B 7265
696E 6974 5F70 643D 3B70 00 14 %a1 4F 00;reinit=;reinit_pd=;p
004FF157 6F77 6572 5F6F 6E3D 2561 2030 3020 3037 2025 6131 2030 3020 3033
3B70 6F77 6572 5F6F 6666 ower_on=%a 00 07 %a1 00 03;power_off
004FF17B 3D25 6120 3030 2030 3720 2561 3120 3030 2030 3020 2561 2030 3020
3033 2025 6131 2030 3020 =%a 00 07 %a1 00 00 %a 00 03 %a1 00
004FF19F 3030 3B6E 6F72 6D61 E153 3284 4D05 806C 5F70 643D 2561 2030 3020
3037 2025 6131 2030 3020 00;norma.S2.M..l_pd=%a 00 07 %a1 00
004FF1C3 3030 2025 6120 3030 2030 3320 2561 3120 3139 2030 3420 2577 3041
2025 6120 3030 2030 3120 00 %a 00 03 %a1 19 04 %w0A %a 00 01
004FF1E7 2561 3120 3032 2030 3220 2561 2030 3020 3034 2025 6131 2030 3320
3544 2025 6120 3030 2031 %a1 02 02 %a 00 04 %a1 03 5D %a 00 1
004FF20B 3420 2561 3120 2570 645F 7374 6F70 726F 7720 2570 645F 7374 6172
7472 6F77 3B70 645F 6E9D 4 %a1 %pd_stoprow %pd_startrow;pd_n.
004FF22F 5332 844D 0600 6F72 6D61 6C3D 2561 2030 3020 3037 2025 6131 2030
3020 3030 2025 6120 3030 S2.M..ormal=%a 00 07 %a1 00 00 %a 00
004FF253 2030 3320 2561 3120 3141 2033 3420 2577 3041 2025 6120 3030 2030
3120 2561 3120 3032 2030 03 %a1 1A 34 %w0A %a 00 01 %a1 02 0
004FF277 3920 2561 2030 3020 3034 2025 6131 2030 3520 3530 2025 6120 3030
2031 3420 2561 3120 3446 9 %a 00 04 %a1 05 50 %a 00 14 %a1 4F
004FF29B 2030 303B 7365 745F 7363 616E 726F 775F 706F 733D 2561 2030 3020
FF53 3284 4D06 8032 3120 00;set_scanrow_pos=%a 00 .S2.M..21
004FF2BF 2561 3120 2579 2025 782F 323B 7363 616E 726F 773D 2561 2030 3020
3232 2025 6131 3B73 6574 %a1 %y %x/2;scanrow=%a 00 22 %a1;set
004FF2E3 5F76 6C63 643D 2561 2030 3020 3034 2025 6131 2030 3520 2576 6C63
643B 7365 745F 766C 6364 _vlcd=%a 00 04 %a1 05 %vlcd;set_vlcd
004FF307 5F70 643D 2561 2030 3020 3034 2025 6131 2030 3320 2576 6C63 645F
7064 3B7D 7B6E 616D 653D _pd=%a 00 04 %a1 03 %vlcd_pd;}{name=
004FF32B 532D 3433 3230 3041 3B74 7970 653D 3033 3B75 5332 844D 0700 6164
6472 6573 733D 3730 3B72 S-43200A;type=03;uS2.M..address=70;r
004FF34F 6573 6F6C 7574 696F 6E3D 3635 2035 303B 636F 6C6F 7572 733D 3038
004FF373 6F66 6673 6574 3D30 3020 3030 3B6F 6666 7365 745F 7064 3D30 3020
3030 3B70 645F 7265 6374 offset=00 00;offset_pd=00 00;pd_rect
004FF397 616E 676C 653D 3033 2030 3030 3020 3030 3034 2030 3036 3520 3030
3143 2030 3030 3020 3030 angle=03 0000 0004 0065 001C 0000 00
004FF3BB 3143 2030 3036 3520 3C53 3284 4D07 8030 3033 3420 3030 3030 2030
3033 3420 3030 3635 2030 1C 0065 <S2.M..0034 0000 0034 0065 0
004FF3DF 3034 433B 706E 705F 6465 7465 6374 3D25 6120 3030 2030 303B 696E
004FF403 3120 3032 2030 3020 3030 2030 3620 3031 2030 3020 3045 2034 4620
3046 2031 3020 3130 2030 1 02 00 00 06 01 00 0E 4F 0F 10 10 0
004FF427 3220 3131 2031 3720 3132 2032 3520 3133 2030 3120 3135 2030 3020
3136 2031 4320 3334 202A 2 11 17 12 25 13 01 15 00 16 1C 34 *
004FF44B 5332 844D 0800 3246 2033 3520 3733 2033 3620 3034 2033 3720 3331
2033 3820 3036 2033 3920 S2.M..2F 35 73 36 04 37 31 38 06 39
004FF46F 3243 2033 4120 3234 2034 3020 3038 2034 3120 3030 2034 3220 3037
2034 3320 3038 2034 3420 2C 3A 24 40 08 41 00 42 07 43 08 44
004FF493 3039 2034 3520 3041 2034 3620 3042 2034 3720 3044 2034 3820 3130
2034 3920 3030 2034 4120 09 45 0A 46 0B 47 0D 48 10 49 00 4A
004FF4B7 3035 2034 4220 3037 2034 4320 3038 2034 4420 3039 2034 4520 3041
E753 3284 4D08 8020 3446 05 4B 07 4C 08 4D 09 4E 0A.S2.M.. 4F
004FF4DB 2030 4320 3530 2031 3020 3531 2030 3020 3532 2030 3720 3533 2030
3920 3534 2031 3020 3535 0C 50 10 51 00 52 07 53 09 54 10 55
004FF4FF 2030 3020 3536 2030 3620 3537 2030 3720 3538 2030 3820 3539 2030
3920 3541 2030 4120 3542 00 56 06 57 07 58 08 59 09 5A 0A 5B
004FF523 2030 4220 3543 2031 3020 3544 2030 3020 3545 2030 3620 3546 2030
3720 3630 2030 3820 3631 0B 5C 10 5D 00 5E 06 5F 07 60 08 61
004FF547 2030 3920 3632 2030 4120 3633 2030 4220 367E 5332 844D 0900 3420
3130 2036 3520 3030 2036 09 62 0A 63 0B 6~S2.M..4 10 65 00 6
004FF56B 3620 3037 2036 3720 3039 2036 3820 3130 2030 3020 3032 2030 3420
3030 2030 3520 3030 2025 6 07 67 09 68 10 00 02 04 00 05 00 %
004FF58F 7731 3138 3B72 6569 6E69 743D 3B72 6569 6E69 745F 7064 3D3B 706F
7765 725F 6F6E 3D25 6120 w118;reinit=;reinit_pd=;power_on=%a
004FF5B3 3338 2030 3220 3030 2031 323B 706F 7765 725F 6F66 663D 2561 2030
3020 3032 2033 3820 3041 38 02 00 12;power_off=%a 00 02 38 0A
004FF5D7 2033 3920 3030 2025 E853 3284 4D09 8077 3738 2025 6120 3030 2030
3620 2577 3137 433B 6E6F 39 00 %.S2.M..w78 %a 00 06 %w17C;no
004FF5FB 726D 616C 5F70 643D 2561 2030 3020 3032 2033 3820 3041 2030 3120
3038 2031 3620 2570 645F rmal_pd=%a 00 02 38 0A 01 08 16 %pd_
004FF61F 7374 6172 7472 6F77 2025 7733 3220 2561 2033 3820 3036 2025 7739
363B 7064 5F6E 6F72 6D61 startrow %w32 %a 38 06 %w96;pd_norma
004FF643 6C3D 2561 2030 3020 3032 2033 3820 3041 2030 3120 3030 2025 7743
383B 7365 745F 7363 6116 l=%a 00 02 38 0A 01 00 %wC8;set_sca.
004FF667 5332 844D 0A00 6E72 6F77 5F70 6F73 3D25 6120 3034 2025 7820 3035
2025 793B 7363 616E 726F S2.M..nrow_pos=%a 04 %x 05 %y;scanro
004FF68B 773D 2561 2038 433B 7365 745F 766C 6364 3D25 6120 3339 2025 766C
6364 3B73 6574 5F76 6C63 w=%a 8C;set_vlcd=%a 39 %vlcd;set_vlc
004FF6AF 645F 7064 3D25 6120 3341 2025 766C 6364 5F70 643B
7D d_pd=%a 3A %vlcd_pd;}
PostPosted: Fri Aug 27, 2004 23:41
Hi.
Anyone here that knows anything about the LCD used on Nokias 3300&6800 models?
Looking for Pinouts, controllerinfo and datasheet or just about anything I can find.
TIA
/Jimmy
PostPosted: Tue Aug 16, 2005 15:41
Are there any progress in identify the controller chip of T68. I found this web site http://www.dainau.com/T68LCD.htm
Phtos shown the T68 LCD panel is driven sucessfully but the gug did not release any technical details. He wants to sell the whole package with US89?
There is a "T68 color LCD download program" in the free download section. I guess it is demo codes for PIC. May be somebody familar with PIC can get some useful information and may confirm which controller chip is used.
Best regards,
PostPosted: Sun Jan 14, 2007 22:51
thx for dump Bingo! its working for me :lol:
Users browsing this forum: No registered users and 82 guests
