It is currently Fri Nov 06, 2026 10:37
PostPosted: Tue Oct 05, 2004 3:01
Hey this is my first post, and i'm about to get an LCD
i found this one
http://www.futurlec.com/LED/LCD128X64.shtml
and i dont understand how to power it, do i only use +5volts? or is there some negative voltage that everyone is talking about that i'm missing ?
PostPosted: Tue Oct 05, 2004 22:18
dit you use a corect pinout to your LPT port?
like: http://www.fractronics.com/koppling_ks0108.gif
I used tis one for the smae controler / screensize. only my screen has EL backlight. and this picture uses a LED. but that should not be a problem.
What doe jou see on your screen. things like all random pixels going on and of. or all pixels on. last case: your wirrering is allwrite and the LCD is ready to recive signals from the LPT poort.
1 case ( the random pixels) jour wirering is wrong. I had it a lot but after a lot of trail and error it worked.
good luck
as we say is in Dutch: prutst vrolijk aan zijn LCD.
or in English : stumbles happy on with his LCD. :P
PostPosted: Wed Oct 06, 2004 17:16
Yes looks like you need a negative voltage to the Vo pin. I think -5v could be close to the correct value. Without further specs you can only try what the correct negative voltage needed is.
PostPosted: Thu Oct 07, 2004 18:14
alright, so i guess i just have to guess and check ? i'm new to this whole negative voltage thing, will this do ?
http://www.aaroncake.net/circuits/vinvertr.htm
PostPosted: Sat Oct 09, 2004 11:37
I suppose it would work. Not familiar with that circuit but any circuit that gives the negative voltage should work.
I have used the 7660 / 7662 IC's before and the circuit using them is very simple.
PostPosted: Sat Oct 09, 2004 12:54
can u give me directions on how to biuld one using this IC ?
PostPosted: Sat Oct 16, 2004 12:51
Datasheet can be found from here: http://www.intersil.com/data/fn/fn3072.pdf
On page 6 there is a basic circuit in figure 13A. So you need the 7660 IC and two 10uF capacitors, pretty simple.
