It is currently Wed Nov 25, 2026 1:07
Post new topic Reply to topic  [ 40 posts ]  Go to page 1, 2, 3  Next
PostPosted: Mon Dec 13, 2004 18:35
POP3 E-Mail Checker Plugin (v1.01)
What is it?:
This plugin allows you to display statistics concerning un-downloaded e-mails that use the POP3 protocol. This generally means any e-mail address you use in Microsoft Outlook/Outlook Express or other. This plugin will NOT support Hotmail unless you have a paid account. Please stay tuned for a HTTP E-Mail plugin. The plugin can tell you how many un-read/un-downloaded messages you have, the total bytes or kilobytes that the e-mails are using and the latest e-mail's subject.
How to Use:
  1. Copy the DLL file into your main LCD Info directory.
  2. Set up your e-mail details by right clicking on the LCD Info icon in the system tray, going to
    "Configure Plugins" > Click "E-Mail Checker" > Click "Configure" > Enter your details > Click "Save" > Click "Test" (optional) > Close the dialog boxes.
  3. Put the pluginvar "E-Mail.Update" somewhere in your XML file. This variable does not return anything unless there is an error and should be refreshed approximately every 5000ms.
  4. Set up your other variables as described below.
Variables:
  • E-Mail.Update: MUST be Called.
  • E-Mail.TotalMessages: Total E-Mail Messages on Server.
  • E-Mail.TotalBytes: Total Bytes on Server.
  • E-Mail.TotalKilobytes: Total Kilobytes on Server.
  • E-Mail.LastSubject: Last Recieved E-Mail Subject.
Download:
http://users.on.net/~krakken/LCD/e-mail_plugin.dll
PostPosted: Mon Dec 13, 2004 22:59
Ah great a new plugin, i'll have a go at it. Thanks for you efforts!
PostPosted: Mon Dec 13, 2004 23:07
Very nice to have a good new plugin. Thanks a lot! :D
PostPosted: Tue Dec 14, 2004 1:10
Krakken,
You are a genius. ;) Thank you. ;)
When are you releasing that other one? ;)
PostPosted: Tue Dec 14, 2004 9:41
Now let's hope i don't get any embarassing headers, showing dirty spam subjects :wink:
'Re: your approved Cialis order #32143'
edit: just tried it on the Noritake T23, works like a charm! Thanks again :D
PostPosted: Tue Dec 14, 2004 14:41
Thanks for the comments :). I'll finish the SETI plugin as soon as I get LCDInfo build 19 out. So far I don't think the improvements I have made are enough to warrant a release. I'll probably release them both tomorrow so long as Mario 64 DS doesn't arrive.
PostPosted: Wed Dec 15, 2004 18:20
An update is released (Version 1.01) to fix a small bug.
PostPosted: Thu Jan 27, 2005 11:05
Hi !
You could give a configuration example, for I do not there arrive :-( !!
thank-you
PostPosted: Thu Jan 27, 2005 11:19
I have some problems getting started with this plugin.
How do I apply:
E-Mail.Update
Can someone give us an example for the plugin?
That would be very much appreciated.
PostPosted: Thu Jan 27, 2005 13:03
OK his works:)
PostPosted: Thu Jan 27, 2005 13:37
This one i made for my 4x20 Noritake VFD;
<screen>
   <name>mail</name>
   <action>
      <id>Core.NextScreen</id>
      <delay>20000</delay>
   </action>
   <item type="plugintext" x="7" y="0">
      <scrolltype>left</scrolltype>
      <textpos>left</textpos>
      <fieldsize>3</fieldsize>
      <varid>E-Mail.Update</varid>
      <refresh>5000</refresh>
   </item>
   <item type="text" x="0" y="0">
      <scrolltype>none</scrolltype>
      <fieldsize>20</fieldsize>
      <textdata>XS4ALL      e-mails</textdata>
      <refresh>500</refresh>
   </item>
      <varid>E-Mail.TotalMessages</varid>
      <refresh>700</refresh>
   </item>
   <item type="text" x="0" y="1">
      <textdata>Mailbox          kb</textdata>
   </item>
   <item type="plugintext" x="8" y="1">
      <fieldsize>7</fieldsize>
      <varid>E-Mail.TotalKilobytes</varid>
   </item>
   <item type="text" x="1" y="2">
      <fieldsize>19</fieldsize>
      <textdata>Last email subject</textdata>
   </item>
   <item type="plugintext" x="0" y="3">
      <varid>E-Mail.LastSubject</varid>
      <refresh>250</refresh>
   </item>
</screen>
PostPosted: Thu Jan 27, 2005 14:06
Okay thank you Coorz, found the fault :D
I've got it working now, i made 2 faults, specially one, i didn't knew XML is capital sensitive :oops:
I'm very new in XML programming so I didn't even look at it 8)
Its working now on my Nokia 3310 display :D
PostPosted: Thu Jan 27, 2005 14:10
A little info here , this plugin will only work with my default mail address, all my alias ( still pop3 ) accounts will not update ( i have 4 extra-each family member has one ) dont know why ? Any idea's folks ?
PostPosted: Thu Jan 27, 2005 14:34
Mayb that is that you only can add 1 E-mail account when configuring the plugin
PostPosted: Thu Jan 27, 2005 14:58
nope not that, my alias addys just wont login/update , even if used 1 at a time ( they do work with smartie and lcdc on my M/O though), passwords etc are correct maybe something to do with my dsl provider grrrrrr :D
