It is currently Mon Nov 09, 2026 19:16
PostPosted: Wed Dec 25, 2002 16:49
Can I use the -12v to give the LCD -8v using a pot ?
All i need is pot ? which one ?
Y r u guyz using all the other options to give the -8v if this is possible and most simple... ?
PostPosted: Wed Dec 25, 2002 19:23
Yes you can use that. 10 Kohm potentiometer should work and no other parts are needed. Connect one end of the potentiometer to -12v and other end to GND. Middle pin will then be the variable output.
I don't know for others but the reason I'm using inverter circuits is that I don't feel comfortable modifying the ATX power connector for this purpose. There's nothing wrong doing it that way but it's just not the way I do it. I also like the fact that I can power the display using just one +5v line.
Also some of my displays have internal negative voltage converter and pot, some have negative voltage but need external pot and some don't have any negative voltage generator at all.
Users browsing this forum: No registered users and 74 guests
