It is currently Wed Nov 25, 2026 9:13
 Post subject: A file. dll !!
PostPosted: Thu Jan 27, 2005 13:07
Hi !!
How can one to modify a plugin??
A file. dll !!
thank-you in advance:)
PostPosted: Thu Jan 27, 2005 15:28
You need the source code and also the compiler environment to rebuild the project.
Here you can get some plugin sources: http://forum.lcdinfo.com/viewtopic.php?t=855
PostPosted: Fri Jan 28, 2005 0:28
Or found the compileur decompileur??
PostPosted: Fri Jan 28, 2005 14:27
Decompiling could be an option but do you know how to do that ?
PostPosted: Fri Jan 28, 2005 21:25
I will be to intervene in the code but I know not with which software it is created, and if it exists another methode for the modofier can you m'expliqué!!??
thank you :)
PostPosted: Mon Jan 31, 2005 23:32
LCDInfo plugins that I have made have been done using Visual C++ 6.
