It is currently Sun Oct 04, 2026 4:54
 Post subject: serial t23a connection
PostPosted: Mon Jan 31, 2005 17:51
Can someone tell me how to connect the Noritake T23A via serial. I've only been able to find parallel connection info.
PostPosted: Thu Feb 03, 2005 0:50
It just needs a level converter with MAX232 or some equivalent function IC.
The serial input pin is pin 11 in the IDC data connector or then the middle pin in the 3 pin power connector. You can use either one of these.
Here is an example using MAX232:
http://chaokhun.kmitl.ac.th/~kswichit/MAX232/MAX232.htm
So you just connect the signal coming from the PC serial port TXD pin through the level converter to the VFD serial input pin.
PostPosted: Mon Mar 07, 2005 19:59
Thanks Henri. Is there a benefit to serial. Lower CPU usage? High compatability? Easier to program?
PostPosted: Mon Mar 07, 2005 22:52
I don't know if there's that much benefit using serial. Parallel should be faster but with a character display like this speed should't be a problem. Someone might like to connect it to serial port and someone to parallel.
Then there's of course the issue that some PC's don't have parallel port. Anyway if you have a display wired with either way and it's working I don't see reason to change. Also if you're just planning to wire the display it's up to you to decide which method to use. There shouldn't be any difference in functionality.
Users browsing this forum: No registered users and 74 guests
