It is currently Wed Aug 19, 2026 13:25
Post new topic Reply to topic  [ 19 posts ]  Go to page Previous  1, 2
PostPosted: Mon Mar 07, 2005 23:18
I had a quick look into the OEM module datasheet and I can see it outputs data via serial interface.
Then to draw waveform to the display you could for example define some points based on the data and draw lines between them to form the waveform.
Maybe these might help:
http://forums.bit-tech.net/showthread.php?t=57010
http://users.cableaz.com/~cappels/dproj/wfcp/wfcp.htm
Google could give you some libraries for graphics functions or maybe even something is in this forum.
PostPosted: Tue Mar 29, 2005 3:18
Thank you guys for the help on the Noritake LCD.
I have successfully plotted the graph onto the LCD.
But now my school actually gave me a bigger GLCD to work with. I was given a Hitachi LMG7420PLFC-X Graphic LCD with a T6963C controller. I now have problem trying to get it powered up.
The Link for the Datasheet of LCD:
http://www.baso.no/content/pdf/LMG7420PLFC-X.pdf
I have connected the pins as the following
VSS - GND
VDD - (+5V)
VO - (-10.8V)
/WR - P2.6
/RD - P2.5
D0-7 - P1
/EN - P2.7
C/D - P2.4
/RET - P2.3
After connecting the pins and applying the voltages, the screen is still blank, so I was wondering whether I need an inverter. Anyone who has used this LCD please give me some advice.
PostPosted: Sun Apr 03, 2005 11:13
I see you also posted in the other topics about this and I already answered there so maybe it's better to continue there about the LMG7420PLFC-X problem:
http://forum.lcdinfo.com/viewtopic.php?t=1134
PostPosted: Fri Apr 08, 2005 4:39
I have managed to get the waveform onto the Hitachi LCD, but the problem is it only display 1 pixel at a time so the waveform is pretty faint. Can it display all the points plotted instead of displaying only 1 point at a time.
$include (c8051f200.inc)
RST EQU P3.1
CD EQU P3.0
CE EQU P2.7
RD EQU P2.5
WR EQU P2.6
IN EQU P3.3
COM EQU 32H
DAT1 EQU 30H
DAT2 EQU 31H
O_Y EQU 35H
O_X EQU 36H
ORG 00H
START:
NOP
NOP
NOP
MOV OSCXCN,#0E7H
NOP
NOP
NOP
ORL OSCXCN,#00H
NOP
NOP
MOV OSCICN,#08H
NOP
NOP
MOV PRT0MX,#01H
MOV PRT1MX,#00H
MOV PRT2MX,#00H
MOV P0,#0FDH
MOV PRT0CF,#00H
MOV P0MODE,#02H
MOV P1,#0FFH
MOV PRT1CF,#0FFH
MOV P1MODE,#0FFH
MOV P2,#0ffH
MOV PRT2CF,#0ffH
MOV P2MODE,#000H
MOV WDTCN,#0DEH
MOV WDTCN,#0ADH
MOV TMOD,#20H ; T1 IN MODE 2
MOV TH1,#-3
MOV SCON,#50H
SETB TR1
CLR RI
CLR IN
SETB RST ;
CLR CE ; CHIP ENABLE
LCALL INIT ; CONTROLLER INITIALIZATION
LCALL ALL_ON ; ALL PIXEL ON
LCALL ALL_OFF ; ALL PIXEL OFF
MAIN:
MOV O_X,#00H ; X COOR = 0
MOV O_Y,#00H ; Y COOR = 0
GO:
JNB RI,GO
MOV R7,SBUF
CLR RI
CJNE R7,#1,GO
MOV R5,#0
SCAN:
JNB RI,SCAN
INC R5
CLR RI
CHECK2:
CJNE R5,#2,SCAN ; CHECK IF BYTE3 IS IDENTIFIED
MOV @R0,SBUF
MOV A,@R0
MOV B,#11
DIV AB
SUBB A,#2
MOV O_Y,A
INC O_X
MOV R3,O_X
CJNE R3,#50,GRAPH
JMP MAIN
GRAPH: ; ( PROCEDRUE FOR DISPLAY IMAGE )
MOV COM,#9EH ; CURSOR ON
LCALL C_DW2
MOV DAT1,O_X
MOV DAT2,O_Y
; MOV COM,#021H
LCALL C_DW
JMP GO
C_DW: ; 2 DATA AND 1 COMMAND WRITE
LCALL CS
MOV A,DAT1
LCALL C_DW3
C_DW1: ; 1 DATA AND 1 COMMAND WRITE
LCALL CS
MOV A,DAT2
LCALL C_DW3
C_DW2: ; 1 COMMNAD WRITE ONLY
LCALL CS
MOV A,COM
LJMP C_DW4
C_DW3:
CLR CD ; COMMAND OR DATA SELECTION
C_DW4:
MOV P1,A
CLR WR
SETB WR
RET
CS: ; CHECK STATUS
LCALL R_STATUS
JNB ACC.0,CS ; CHECK COMMAND EXECUTION CAPABILITY
JNB ACC.1,CS ; CHECK DATA READ / WRITE CAPABILITY
RET
CS_2:
LCALL R_STATUS
JNB ACC.2,CS_2 ; CHECK AUTO MODE DATA READ CAPABILITY
RET
CS_3:
LCALL R_STATUS
JNB ACC.3,CS_3 ; CHECK AUTO MODE DATA WRITE CAPABILITY
RET
R_STATUS:
MOV P1,#0FFH ; READ THE STATUS
SETB CD
CLR RD
MOV A,P1
SETB RD
RET
INIT: ; ( PROCEDRUE FOR INITIALIZATION )
MOV DAT1,#00H
MOV DAT2,#00H
MOV COM,#40H ; SET TEXT HOME ADDRESS TO 0000H
LCALL C_DW
MOV DAT1,#20H
MOV DAT2,#00H
MOV COM,#41H ; SET TEXT AREA TO 32 COLUMNS
LCALL C_DW
MOV DAT1,#00H
MOV DAT2,#08H
MOV COM,#42H ; SET GRAPHIC HOME ADDRESS TO 0800H
LCALL C_DW
MOV DAT1,#20H
MOV DAT2,#00H
MOV COM,#43H ; SET GRAPHIC AREA TO 32 COLUMNS
LCALL C_DW
MOV COM,#0C0H ; SET CURSOR TO 8-LINE CURSOR
LCALL C_DW2
MOV COM,#0A5H ; SET CURSOR TO 8-LINE CURSOR
LCALL C_DW2
MOV COM,#80H ; DISPLAY MODE AS "OR" MODE
LCALL C_DW2
MOV COM,#9EH ; TEXT ON, GRAPHIC ON, CURSOR DISPLAY ON, CURSOR BLINK OFF
LCALL C_DW2
RET
ALL_OFF: ; ( PROCEDRUE FOR PIXEL OFF )
MOV DAT1,#00H
MOV DAT2,#00H
MOV COM,#24H ; SET ADDRESS POINTER TO 0000H
LCALL C_DW
MOV R3,#00H ; SET Y COUNTER = 256
MOV R4,#20H ; SET X COUNTER = 32
MOV COM,#0B0H ; SET DATA AUTO WRITE
LCALL C_DW2
ALL_OFF1:
LCALL CS_3
MOV A,#00H ; PUT 00000000 TO DATA BYTE
LCALL C_DW3
DJNZ R3,ALL_OFF1
DJNZ R4,ALL_OFF1
MOV COM,#0B2H ; RESET AUTO
LCALL C_DW2
RET
ALL_ON: ; ( PROCEDRUE FOR PIXEL ON )
MOV DAT1,#00H
MOV DAT2,#00H
LCALL C_DW
LCALL C_DW2
ALL_ON1:
LCALL CS_3
MOV A,#0FFH ; PUT 11111111 TO DATA BYTE
LCALL C_DW3
DJNZ R3,ALL_ON1
DJNZ R4,ALL_ON1
LCALL C_DW2
RET
END
