It is currently Sun Oct 04, 2026 3:38
PostPosted: Tue Apr 05, 2005 23:22
I have problem with the configuration of my driver,
I get the following message when I try to finish the configuration or start to configure plugins for winamp,
"No configuration dialogue available"
Will probably need easy and clear instructions, have just begun to use LCDInfo and LCD's on the whole for that matter :wink:
PostPosted: Wed Apr 06, 2005 7:57
Well that simply means it's not implemented yet, you'll need to create & configure the winamp screens manually in .xml files
PostPosted: Wed Apr 06, 2005 10:38
How do you do that? :?
PostPosted: Thu Apr 07, 2005 20:04
How do I implement it then?
And how do I create the screens?
PostPosted: Thu Apr 07, 2005 20:16
http://forum.lcdinfo.com/viewtopic.php?t=1147
A getting started manual is in the making. Hey Syridian, where you at :wink:
PostPosted: Thu Apr 07, 2005 20:18
have you even looked through the forum ?
http://forum.lcdinfo.com/viewtopic.php?t=403
and there is a winamp screen , a 128x64 in the default download of info.
EDIT :D
PostPosted: Fri Apr 08, 2005 9:56
Yes I have,, but I don't understand,,
When I try to select "Configure plugin" and choose winamp2, I get
"No configuration dialog available"
Why? how do you correct it?
Can you somehow autostart winamp and lcdinfo, when the computer starts, so the visulization starts when the computer has started?
Users browsing this forum: No registered users and 184 guests
