It is currently Sat Nov 07, 2026 19:25
PostPosted: Thu Apr 14, 2005 9:25
I have an old ipaq 3950 that i messed up by trying to flash a linux boot rom to and now will not boot at all....
Would it be possible to hook this up as a display and also keep the touchscreen facility also.
while i understand that this may need some extra software/hardware to actually implement i would be interested to see if it was possible...
BulletMag
PostPosted: Mon Apr 18, 2005 23:02
Yes ofcourse, find the datasheet and you can build the proper LCD controller for it. For the touchscreen you can find a suitable controller once you know it's specs.
PostPosted: Thu Apr 21, 2005 19:11
If you open the unit you might find some type markings from the lcd that might lead to more information about the lcd used.
PostPosted: Tue Apr 26, 2005 7:38
I wouldn't use that ipaq for spare parts just yet... even an ipaq with a corrupt bootloader can be un-bricked. Compaq will do it (for a fee) but it's cheaper than a new pda. You could even do it yourself if you fit a JTAG connector to it.
PostPosted: Wed Apr 27, 2005 14:54
That's a good suggestion. Flashing a new firmware through JTAG should be easier than doing the hardware that would allow using the display othewise.
Users browsing this forum: No registered users and 37 guests
