It is currently Sat Nov 14, 2026 3:08
PostPosted: Sat May 07, 2005 2:25
Hello,
I'm from Germany and Im looking for the technical datasheet of a Sharp 14,1" UXGA Notebook TFT (especially the PIN-Assignement and timings would be interesting). The TFT was used in Dell Inspirion 4100 Notebooks. Manufacturer is Sharp.
Dell Service and Sharp also couldn't or wouldn't help me with the Datasheet or specs of this TFT. Sharp said that they manufactured those Displays exclusively for Dell and aren't allowed to give third persons those specs. So you are my last hope!
The Label on the Back of the TFT shows the Part Number used by Sharp Part Number: LQ141U1LH02 and the Dell Part Number: 05D366 :
and this is another label on the back of the TFT:
Please help me! Where can I get this Specs / Datasheet from, if not from the manufacturer? I need the PIN-Allocation and Vltage specs. I assume that other Displays from Dell which have SXGA+ have the same specs, because Dell remarked, that you can use a UXGA Panel instead of a SXGA+ Panel in an Inspirion 4100 with the same Flat Flex cable for both TFT's for example. Maybe someone has a Datasheet from an other Sharp SXGA+ or UXGA TFT wit 30 PIN LVDS-connector?
Tom
PostPosted: Tue May 10, 2005 22:52
I have a sheet for the LQ141X1LH01, this one has a 20 pin LVDS connector. PDF can also be found here http://members.lycos.co.uk/eleewhmaus/comp/
PostPosted: Thu Jul 27, 2006 6:02
Accurate: Blurred Search:Numeral A B C D E F G H I J K L M N O P Q R S T U V W X Y Z
Down LCD Module Specification
LTD79M476LG LTD170LL1SG LTD154LX0S-Z LTD154EZ0S-V04
LTD141LM0S-181 LTD141LM#S LTD141EM4V-11 LTD121LA#S-V02
LTD121GA0S-V04R LTD121GA0S_V04 LTD121C31S LTD121C30S-V07R
LTV350QV-F04 LM-EA53-24NTK LTV350QV-F09 LTV350QV-F 09
LTM190E4-L02 LTI460WS-L01 LTI460HS-L01 LTI400W2-L01
LTI400HS-L01 LTG430WQ-F02 LTE430WQ-F05 LS037V7DW01
LQ315T3LZ49 LQ281L1LW11 LQ150X1LGN2E LQ121S1LG61
LQ104V1DW02 LQ043T3DX02 LQ035Q7DH06 LM300W01-A3
LM201U04-SL02 LM190E05-SL03 LM170E01-TLA1 LC550W01-A5
LC420W02-B6 LC370WX1-SL01 LC370W01-A6S LC260WX2-SLB3
All 1505 1/38[ Home Back Next End ] To Page
http://www.lcdfriends.com/spzs/ENZL1.ASP?num=L
PostPosted: Sun Nov 04, 2007 22:24
I was not able to figure out the objective of this post in helping the OP find the LCD Specs.
I need to find out if this LCD Panel Sharp LQ141U1LH02 can be installed in a thinkpad T60 or T61. If someone can point out a forum or place where I can find enough information about the LCD "Interfaces" for LCDs used in the T42, T43 and T60, T61 series of laptop LCDs that would be great as well.
