It is currently Sun Sep 27, 2026 5:57
 Post subject: Curious
PostPosted: Tue Jun 14, 2005 23:17
my 5 year old laptop has died and I was considering putting the beautiful LCD to use, but I have no idea where to start. I have much experience with electronics but I can't seem to find the pinout for my model. I've emailed sony about it, but am doubtful at the moment. the model number is as follows; A8045754A
thanks for any information anyone can provide.
p.s. it's a samsung display, their site is less than helpful, and I've not recieved a reply from them for quite some months.
PostPosted: Wed Jun 15, 2005 0:04
Sony VAIO PCG-F20 and PCG-XG9 LCD
.... A8045754A 13.3 A-8045-754-A
.... Samsung part number: LT133X7-124
As far as I can make out, it's a 3.3 volt, LVDS panel.
I have a good collection of LCD pinouts and datasheets, but I don't have this one. Maybe the above info will help you find it. Unfortunately, LCD manufacturers who sell to other manufacturers rarely like to give out specs - they are generally considered confidential.
Try looking at these two - they are not for your model, but often they use the same pinouts. If they look similar, try tracing the power and ground connections on the LCD or laptop board to see if they match. If so, its a fair bet...
http://www.axiomtek.com.tw/Download/Manual/PK898B.pdf
http://www.axiomtek.com.tw/Download/Manual/PK898G.pdf
Maybe try to identify the video controller on the laptop board, get its datasheet (probably easier than the LCD one) and trace out the connections? There aren't that many for an LVDS panel.
That's what I would do, anyway. I've done it on a few panels with ultimate success.
If you do work it out, please post the info so we can share it.
Best of luck,
FoxyRick.
PostPosted: Wed Jun 15, 2005 5:12
For a LVDS panel, you'll have to get a VGA->LVDS converter.. which will cost more than a brand new 15" LCD monitor. ;)
PostPosted: Wed Jun 15, 2005 19:04
Not if you connect it to a suitable LVDS-enabled board, like many of the small form factor boards out now. Makes a *very* nice embedded system.
FoxyRick.
PostPosted: Sat Jun 18, 2005 19:50
here's the letter I got back from sony;
Thank you for contacting Sony's Direct Accessories and Parts Center (DAPC USA).
Your question was: I have this LCD panel from a Vaio PCG-F630 that I've used for the past five years. The purpose of my email is to request information of the LCDs pinout.
Thank you.
The items you requested are listed below.
You may place your order using the link below or call 1-800-488-7669.
Shipping charges and local taxes will be added to your order at checkout.
Sony Direct Accessories & Parts Center web site - http://www.sony.com/accessories
Detailed specs on LCD are not available. Specs may possibly be found by searching the internet using the model number off the back of the LCD.
Thank you for your interest in Sony.
... not vera helpful.
PostPosted: Sun Jun 19, 2005 2:23
*groan*
anyways, I'm willing to experiment and ty to pigure out the pinout myself - where, and how, would I get started?
PostPosted: Thu Jun 23, 2005 16:52
... should I just start protting it with 3v here and there to see if I get anything?
lol, would that even work?
PostPosted: Thu Jun 23, 2005 16:56
No, you need a controller which will output the "correct" signals with correct timing to the panel.
PostPosted: Fri Jun 24, 2005 16:33
I don't know the pinout nor the type of controller I need for the panel.
my trial-and-error approach was going to be a blind attempt at determining this.
PostPosted: Sat Jul 02, 2005 20:13
I think I found the controller.
THine
TI000704
THC63LVDM63A
... alas I can't seem to find a pinout for it as of yet.
Also, upon further inspection, there are 18 wires [ on a 20-pin header ];
Black
Grey
White
Orange
Yellow
Red
- [ no/use ]
BW--GOYGOYGOYGOYBRBR
[ printed on a piece of tape with, what looks like, Japanese lettering, that holds the wires together ]
1-906-645-21
and there's a chip under a flaxable PCB that's taped pretty firmly to the back of the LCD - I've not succeeded in pulling it back to read what's on the chip, but what I do know is that it's square with hookups on all sides.
... And now for some more numbers printed on the back of the panel;
F8575E-X(47L7106)
HY6802-01
FDK24786(04)
//edit
"Library for National Semiconductor DS90CF363 LVDS encoder for flat panel display. Also suitable for pin-compatible THiNE THC63LVDM63A. "
quote from http://www.cadsoft.de/cgi-bin/download. ... /libraries
Users browsing this forum: No registered users and 58 guests
